#176 |
![]() Join Date: Apr 2010
Re: Orson the 49 GMC ~ Chris C.
today we modified the sender and installed an in-tank pump. we also cleaned/painted Orson's accessories.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
#177 |
I know it may not look like much, but cleaning/painting those accessories is very time consuming! we also put on the intake and mapped out the fuel system. it appears that when Alex took this motor apart he must have tossed the bolts/re-usable gaskets, cause we sure as hell can't find 'em!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by skymangs; 01-05-2021 at 09:47 PM. |
#178 | |
![]() Join Date: Sep 2016
Never mind, just realized it's an ls lol maybe it doesn't have the same problem as a sbc 350
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
#179 |
nope, I use a Canton straight thermostat housing. makes it a nice straight shot!
#180 |
![]() Join Date: Sep 2017
Please show pictures of the radiator hook up when done. Thanks.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
#181 |
will do!
#182 |
spent most of the day looking for bolts, but we managed to get the accessories on, and start building the exhaust.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 01-07-2021 at 11:08 AM. Reason: Rotated pictures |
#183 |
I realize it 's not a Chevy, but here's another project we're working on https://67-72chevytrucks.com/vboard/...d.php?t=816579
#184 |
my son, Michael, threw a tantrum and quit yesterday! it's just as well, he was a terrible employee! I've wanted to fire him for the last year, but haven't because he's my son! he was actually costing me money! so for the next few days I'll be moving stuff off the x's property. today we got the dipstick in, the intake manifold torqued, and some other odds and ends that needed to be done. only spent about 2 hours on it.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 01-08-2021 at 11:13 AM. Reason: flipped photo |
#186 |
![]() Join Date: May 2007
well that sucks plenty but the truck is looking good
#187 |
yeah, he acts like I should be sucking without him, but I'm just not!
#188 |
we got the coil packs cleaned and mounted yesterday. today we'll work on wiring it and the fuel system.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 01-13-2021 at 12:23 AM. Reason: flipped photo |
#189 |
so we discovered a problem yesterday, the hole that we had drilled and tapped was inaccessible when the pump was mounted ! so today we corrected that. a 1/8 pipe plug was put in the hole and a new hole was drilled and tapped on top.
#190 |
we also got the exhaust built back to the muffler. that's as far as we go until the bed's back on (for aesthetics) almost ready for initial start up! yesterday we discovered that the harness I had ordered was for a car manifold! luckily, I found one on LS1TECH!
#191 |
looking really nice chris
i think we might need an update on who is left when you say "we". do you have a mouse in your pocket? ![]()
#192 |
I'm sorry, my son threw a tantrum and quit (that's OK he was a ****ty employee anyway) I have 2 in my employ currently, Wyatt (he's my go to guy) and JP(he is still very much learning)
#193 |
here's what we've been doing the last few days. we made the upper radiator mounts and made all the battery cables, no crimps, only solder! it seems I ordered a harness for a car intake and injectors. so now we are waiting on the car intake to arrive for initial start up.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 01-21-2021 at 11:37 AM. Reason: flipped photo |
#194 |
we discovered that Alex had placed the motor several inches to far forward, at first I tried to compensate, but it became obvious after we got the accessories on, so we spent yesterday prepping the cab and driveline to move back. bummer, I know, but it's the only way to do it right!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 01-22-2021 at 11:13 AM. Reason: flipped photo |
#195 |
more pictures of the process
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 01-22-2021 at 11:15 AM. Reason: flipped photo |
#196 |
we spent the whole day preparing to move the driveline. monday we move it! we also discovered that Michael did a piss poor job of welding the floors, so we'll be redoing that too. (he no longer works for me)
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 01-23-2021 at 12:04 PM. Reason: flipped photo |
#197 |
here's what we got done today, old motor mount pedestals were cut out, and the new ones will go in tomorrow
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 01-26-2021 at 06:25 PM. Reason: flipped photos |
#198 |
we got the engine repositioned today, it's a little far to the right. we need to cut the steering linkage tomorrow and redo the steering geometry. on the trans dipstick, we had to cut and reweld the mounting bracket to move it from behind the head to next to it.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 01-27-2021 at 11:54 AM. Reason: flipped photos |
#199 |
looking good
good to see you back at it On your exhaust I would of put the left pipe behind the trans output shaft about 6" so if the trans ever needs to be removed it makes it a lot easier jim |
#200 |
thanks
