Old 01-04-2021, 09:47 PM   #26
dsraven
Re: Tie rod and steering linkage
maybe daveschilling could help you out.
http://67-72chevytrucks.com/vboard/s...d.php?t=816489
dsraven is online now   Reply With Quote
Old 01-05-2021, 10:49 AM   #27
regan56
I do get it figured out, after reading the previous posts. Thx for all the help though.
regan56 is offline   Reply With Quote
Old 01-05-2021, 11:27 AM   #28
frkennyg
My driver’s side with plate and spacers
frkennyg is offline   Reply With Quote
Old 01-05-2021, 05:07 PM   #29
1project2many
I believe a front sway bar does help a 1/2 ton truck with stock springs feel better in town or on the highway. I used a homemade setup to install a front bar from a square body truck into mine years ago. Last summer I replaced it with a stock bar that I removed from a GMC Panel. Both bars make a noticeable difference. If I were junkyard scrounging for a bar I'd start with a YJ Jeep. I did some quick measuring last summer and I believe the YJ bar(s) could be installed fairly easily.
1project2many is offline   Reply With Quote
Old 01-05-2021, 05:30 PM   #30
regan56
Current progress. (Added shocks since)
Old 01-05-2021, 11:07 PM   #31
nvrdone
looks very much like my AD. the only other thing to think about is if you have a dropped I beam, the tie rod needs to mount UNDER the spindle arms. otherwise the tie rod will inter fear with the springs.
And yes, sway bars help alot. Ive got both front & rear. Doesnt handle like my Grand Cherokee, but the difference is noticable.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's
Bought in 1973 for $235.00. Had it longer than my wife & Kids!!
nvrdone is offline   Reply With Quote
Old 01-06-2021, 01:18 AM   #32
dsraven
shiny. looks good.
will you keep the stock ride height?
Old 01-06-2021, 10:15 PM   #33
regan56
Originally Posted by dsraven View Post
shiny. looks good.
Went with Posies drop springs is all, probably 2” in front. Other than that a flipped rear axle should lower it a touch as well.
Old 01-09-2021, 02:43 PM   #34
mr48chev
mr48chev's Avatar
G&R's57GMC photo of the right spindle shows the spacer at the top.
A design difference between TF and earlier trucks.
Looking at the photo of my spindle I posted earlier in the thread That has 54 car backing plates I have spacers top and bottom. I know I had to make one set or the other when I did the swap. That is a 54 3100 axle.
My ongoing truck projects:
