Old 12-30-2020, 01:01 PM   #401
jkeating1
jkeating1's Avatar
Re: SkinnyG's '61 Apache
Originally Posted by SkinnyG View Post
Challenge accepted!
Turns out you did it on cruise control
JK
jkeating1 is offline   Reply With Quote
Old 12-30-2020, 05:17 PM   #402
SkinnyG
SkinnyG's Avatar
And the driver's side step is done. I had some measurement irregularities, so this one didn't weld up as tastily. I know you just buy reman ones of these, but they are $150CDN each - I save $300 cutting them down myself
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 12-30-2020, 10:27 PM   #403
SkinnyG
SkinnyG's Avatar
Also started figuring out the gas tank, and then started making a trailer hitch.
Old 01-01-2021, 01:03 AM   #404
SkinnyG
SkinnyG's Avatar
Reused the original in-cab tank straps, but I'm not sold on that yet.
Old 01-01-2021, 11:11 PM   #405
SkinnyG
SkinnyG's Avatar
I wasn't happy with the first version of the upper straps, so I made new ones out of 1-1/4" square tubing sliced to 3/8". The top straps had to be removable, because the back panel had to be removable, because the hitch had to be removable, and this arrangement made sense to me. Which, of course, required finishing the trailer hitch (yes, the chain loop thingies are not on yet). Truck is only rated to pull 6000lbs.
Old 01-02-2021, 05:22 PM   #406
SkinnyG
SkinnyG's Avatar
And here is where I got by the end of Christmas break 2020:
And you can hardly tell the bed was raised 4":
Old 01-02-2021, 07:05 PM   #407
WunTon
Wow!! That looks awesome!
WunTon is offline   Reply With Quote
Old 01-02-2021, 07:42 PM   #408
cwcarpenter98
cwcarpenter98's Avatar
Dadgum, that looks great!
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-02-2021, 08:43 PM   #409
53Sparky
53Sparky's Avatar
x2!
Great progress!
We'll burn that bridge when we get there
My current project: Rust Therapy 62 C10
Numbers 6:24-26
53Sparky is offline   Reply With Quote
Old 01-02-2021, 11:13 PM   #410
caseyjones
Awesome work!
caseyjones is offline   Reply With Quote
Old 01-02-2021, 11:31 PM   #411
SCOTI
SCOTI's Avatar
That's some fine work being done!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-03-2021, 11:51 AM   #412
88Stanger
88Stanger's Avatar
Damn SkinnyG, that is some awesome work!!!
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 01-05-2021, 12:51 PM   #413
aggie91
I'm just glad to be here!
aggie91's Avatar
Looking good there sir!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-05-2021, 04:10 PM   #414
Ronzo
Ronzo's Avatar
Great work bud
Ronzo is offline   Reply With Quote
Old 01-07-2021, 11:36 PM   #415
SkinnyG
SkinnyG's Avatar
Latest video:
Old 01-09-2021, 09:41 PM   #416
SkinnyG
SkinnyG's Avatar
I reinforced the Sheet Metal Brake I made last spring and was successful in folding 30" of 18ga.
Also used my Nutsert tool for the first time, installing 5/16-18 nutserts into the passenger door for a mirror. The skin is already braced from the underside, but no factory weld nuts to fasten. While these stick a little proud of the surface, it's going to be fine.
Also spent a LOT of time corresponding with Universal Air regarding bag choice on the '61, and after we talked about motion ratio, sprung weight, suspension frequency, ride height, and air pressure, I think I have finalized the way I want to go about this - this will be documented later. Universal Air gave me fantastic customer service over this (thank you!).
Old 01-10-2021, 12:54 PM   #417
Duncan K
Great idea using the nut serts for the mirrors! I'm gonna copy that one when I get back to working on my doors
66 GMC 910
My Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=754257
Duncan K is offline   Reply With Quote
Old 01-10-2021, 02:03 PM   #418
pdxhall
pdxhall's Avatar
Great idea on the nutserts for your mirror. I just bought a nutset tool and I'm planning to use it for my roof lights. Seeing yours gives me the confidence that they are going to work. Thanks for the post.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is online now   Reply With Quote
Old 01-10-2021, 11:18 PM   #419
SkinnyG
SkinnyG's Avatar
This will be roughly ride height. Needs a bit more rake - front could easily go down an inch, rear could go up some.
Not sure to start on the fender rust repair, so I'm starting with the nose. This is just behind the headlights. I'll need to drag this outside for sand blasting, then epoxy primer, before I weld it in.
Old 01-12-2021, 11:45 PM   #420
SkinnyG
SkinnyG's Avatar
And another patch:
Old 01-13-2021, 11:01 AM   #421
88Stanger
88Stanger's Avatar
nice damn work sir....
Old 01-13-2021, 09:32 PM   #422
SkinnyG
SkinnyG's Avatar
And another patch:
Old 01-14-2021, 12:01 AM   #423
SkinnyG
SkinnyG's Avatar
And another patch. Ready for blasting and epoxy priming underneath Friday or Saturday.
Old 01-15-2021, 10:21 PM   #424
SkinnyG
SkinnyG's Avatar
Repair area blasted and primed:
Unrelated - anyone ever widen the rear fenders to better match the front?
Old 01-15-2021, 11:10 PM   #425
cwcarpenter98
Bringing up the wheel opening?
Member vin63 brought the wheel opening down some on the front fenders to better match the rears.
Also, your work with the sand blaster makes me want to get one before I start the rest of my rust repair
Christian Carpenter
