#30 |
Re: How To Restore and Detail an Original Gauge Cluster
Aluminum tape inside the tubes will melt the high beam lens if you live out in the country and can drive for a while without meeting oncoming traffic to dim your lights... I found out the hard way when my dash started smoking late one night. The stock bulb in the stock tube is plenty bright enough to indicate that your high beams are on, so it's not something I would recommend. Should work fine for intermittent use lights like the turn signals, but not steady on use.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
