03-05-2021, 08:54 AM | #676 |
Re: Ok Boys and Girls it's Storytime
The passenger side was the worse. There wasn't much holding it together.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
03-05-2021, 08:58 AM | #677 |
The drivers side was a much cleaner break.
03-05-2021, 09:01 AM | #678 |
The drivers side went back together pretty smooth.
03-05-2021, 09:05 AM | #679 |
The passenger side was a *****. We had to twist it and use the jack and jack stands with a ratchet strap to pull it together. Weld here weld there and then it started pulling itself together. We weren't gong for pretty we were going for strength.
03-05-2021, 09:11 AM | #680 |
Tony went ahead and rewelded around the C notches on both sides and we called it a day. We will clean it up and plate the outside. Once we are done with that we will get the weight distributed right and start on adding tubing over the shock mounts to tie everything. I may have to do some adjusting and shimming on the bed. All in all a for a near disaster I think it went back together pretty well.
03-06-2021, 09:14 AM | #681 |
The rig I tried to get it home from the track with. It worked for awhile.
03-06-2021, 10:23 PM | #682 |
Damn $hitty deal, but good thing you caught it before it completely broke.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
03-08-2021, 07:52 AM | #683 |
Yes it sucks Monty. In the end I'm glad it happened just not the 800 mile round trip and missing a race. I was able to rearrange my schedule so we are going to start back on it at 8am this morning. Maybe we can get it finished and I can get it home I hope.
03-08-2021, 03:19 PM | #684 |
I'm just glad to be here!
Glad to see you progressing. You know Tony will make it right!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
03-08-2021, 08:56 PM | #685 |
Success?
03-09-2021, 06:58 AM | #686 |
When I got there yesterday morning he was doing some welding. He found one or two small cracks and welded them up too. Then we had to determine bar placement in the back. There was only a 4 inch long area to use. I got them marked and cut some holes in the bed.
03-09-2021, 07:02 AM | #687 |
I left out that I worked on the bed shimming it in the back .I think the bed gap looks as good or better than it ever has. It was never perfect because the of the way I had the cab mounted before the cage was built. If I don't like it when I get it home I can still play with it some more.
03-09-2021, 07:08 AM | #688 |
We sampled different angles of tubing bends with some templates. We decided on a 45 degree I kinda liked a 30 better but it would have been harder to weld at the bottom.
03-09-2021, 07:10 AM | #689 |
We sampled different angles of tubing bends with some templates. We decided on a 45 degree I kinda liked a 30 better but it would have been harder to weld at the bottom. There will be some 90 degree struts where the floor is cut. Then hopefully we can get all that mess put back together.
NHRA Super Street 469C It only runs 10.90 at 156 mph Last edited by regan wilson; 03-09-2021 at 07:20 AM. |
03-09-2021, 07:22 AM | #690 |
We got both bars bent and mocked up. Then had to call it a day.
03-09-2021, 07:23 AM | #691 |
oops
03-09-2021, 07:27 AM | #692 |
This is turning out to be exactly what I wanted to do for awhile.
03-09-2021, 10:00 AM | #693 |
Definitely looks like those will help the effort.
03-10-2021, 09:15 AM | #694 |
I got it home yesterday evening. He didn't have time to help me with the floor and the tubs. I'm going to have to fix that mess myself. I've already gotten the tubs pretty straight. I need to cut up the pieces of the floor I took out and fit them around the 90 degree braces. Then clean this mess up and do some bedliner and paint the bars.
03-10-2021, 10:40 AM | #695 |
It will be interesting to see if it reacts differently now.
03-10-2021, 01:34 PM | #696 |
That’s kinda the same idea behind how mine is done, sample principal anyway.
03-10-2021, 02:31 PM | #697 |
Looks good!
03-10-2021, 09:03 PM | #698 |
I'm sure it will. If it picks up R/T that's not a bad thing. I hope it picks up a ton.
03-10-2021, 09:04 PM | #699 |
Leave it to me to wait until it breaks .Lol
03-10-2021, 09:04 PM | #700 |
