Old 02-11-2021, 08:26 AM   #76
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Working on the motor wiring. This motor came out of a swap, who ever did this swap should not do wiring. I already cleaned up a bunch when I got the motor running, now on to the rest.
This is what I started with last night and this is the type of thing I found 2 wires in 2 wires out and a ball of extra taped up, like just cut it and twist the wires together with tape would be better imo.
Now its all cleaned up ready to make the harness fit.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 02-11-2021, 08:59 AM   #77
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: 1950? S-10 tdi
Great build!
Steve
1997 Tahoe LT 4D 2WD (DD)
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 02-11-2021, 09:18 AM   #78
6DoF
6DoF's Avatar
Re: 1950? S-10 tdi
awwww ... no MTDI conversion?!?!
6DoF is offline   Reply With Quote
Old 02-12-2021, 07:59 AM   #79
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Originally Posted by 61_FL_Apache View Post
Great build!
Thank you
Ya I thought about that.
1951 MG TD
Old 02-16-2021, 11:57 PM   #80
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
I have been working on the wiring getting things terminated. Motor wiring is in and hooked up, so much neater. Also running the wires under the dash, it's all coming together. I never thought I would end up with 8 relays.
1951 MG TD
Old 02-17-2021, 09:24 AM   #81
youngrodder
youngrodder's Avatar
Re: 1950? S-10 tdi
Looks good. Wiring neatly sure does chew up time.
I'm running the same nostalgic shifter. I need to switch it over yet. I have been using a regular one for mock up.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-18-2021, 12:25 AM   #82
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
You got that right.
1951 MG TD
Old 02-19-2021, 12:53 AM   #83
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Got the rad back from the rad shop for a test fit today. they put in a new modern 3 core and new bottom tank, I wanted to keep the top tank to look original. Needs one minor change on my part then they will test and paint. My dog CJ had to inspect the whole thing.
1951 MG TD
Old 02-19-2021, 09:24 AM   #84
61_FL_Apache
Who Me?
Re: 1950? S-10 tdi
Looks like CJ gives his stamp of approval!
Steve
Old 02-23-2021, 09:41 PM   #85
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Yes I think so he sniffed the entire thing twice over lol
1951 MG TD
Old 02-23-2021, 09:44 PM   #86
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
So test fit went well, changed the mounting a little and made my brackets to install the fan. It is back to the rad shop for them to finish up and paint. A few more little goodies came in the mail still waiting on the intercooler.
1951 MG TD
Old 02-24-2021, 10:03 AM   #87
6DoF
6DoF's Avatar
Re: 1950? S-10 tdi
wait, what are they painting it? the whole thing? why paint that pretty thing?
Old 02-24-2021, 09:10 PM   #88
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Ya they paint it black with a special paint to dissipate heat better and stop the copper from turning green.
1951 MG TD
Old 03-11-2021, 01:11 AM   #89
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Well some parts arrived I have been waiting on. I ordered the inter cooler mid January, mid February it got turned around at the border? and sent back to supplier. So I ordered another one from a different place and it showed up today The door seals I ordered December 7 and they showed up on Tuesday. Nothing like taking 4 months to get here, lets hope the seals work better than the ones on my other truck.
1951 MG TD
Old 03-11-2021, 08:41 AM   #90
6DoF
6DoF's Avatar
Re: 1950? S-10 tdi
that intercooler is like 3x the factory jobbie, should be great
Old 03-12-2021, 12:08 AM   #91
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
That's the idea. I have a similar size intercooler in my Jeep and seems to work well.
1951 MG TD
Old 03-15-2021, 06:13 PM   #92
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Well I'm finally back on the truck, spent 3 weeks helping my son work on his Jeep CJ6 it's almost ready for the road.
I got the intercooler mounted up used some of the packaging to help mock it up and the pipes run. It's going to work really nice.
1951 MG TD
Old 03-15-2021, 10:48 PM   #93
6DoF
6DoF's Avatar
Re: 1950? S-10 tdi
i was so weirded out by the pipe going all the way across the engine bay ... then remembered it wasn't a crossflow head. at least you got room!
Old 03-16-2021, 01:26 PM   #94
61_FL_Apache
Who Me?
Re: 1950? S-10 tdi
Like the Jeep CJ6.
Steve
Old 03-16-2021, 03:51 PM   #95
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Ya lol I will be making the pipe a bit more shinny.
Like the Jeep CJ6.
It's cool eh
1951 MG TD
Old 03-18-2021, 10:07 PM   #96
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Took the front clip apart to finish up a few things before the front end goes to get blasted. Now you can see the bumper support and front cross member.
1951 MG TD
Old 03-30-2021, 02:07 AM   #97
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
So Saturday I took the fenders and rad support to to the sand blaster, should have them back in a week. I got all the brake lines run, cleaned up the motor, then I started putting power to the truck. I got the trans fan, heater, ignition, motor computer, glow plugs, head light circuit, starter, and gauges all hooked up and working. I just work a fuse at a time. Once all the wires are run it is going to end up nice and neat.
1951 MG TD
Old 03-30-2021, 07:49 AM   #98
6DoF
6DoF's Avatar
Re: 1950? S-10 tdi
unless you have 1 bad ground somewhere .... then it's going to end a rats nest of sorrow.
Old 03-30-2021, 09:50 AM   #99
Tempest67
Tempest67's Avatar
Re: 1950? S-10 tdi
that sits in there nice,
I think it is cool to have something different, no one will ever guess what that motor is from
nice job and thanks for sharing (hope your helpers are doing well - dogs)
Tempest67 is offline   Reply With Quote
Old 03-30-2021, 10:50 PM   #100
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Ya, I make sure my - are as good as my +
Thanks, I have always liked the strange motor swaps.
Yes they are good and help whenever they can.
1951 MG TD
chevy, custom, diesel, gmc, s10
