Old 03-22-2021, 08:52 PM   #1
NathanC
Guest
Posts: n/a
CPP drop spindles
I have a 1965 that I want to convert to disk breaks and later model stock calipers, disks, ball joints.
CPP has two options for the 2.5 inch drop spindles;
1963-1970
1971-72
What’s the actual difference between these two products?
I thought parts for 63 - 80 were pretty much interchangeable from a tire width pov.
Old 03-22-2021, 09:38 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: CPP drop spindles
There’s also a 73-87 version.
Same spindle casting.
They are just reamed for different year ball joints and outer tie rods.
Keith
Convert to disc brakes.
Old 03-22-2021, 09:43 PM   #3
NathanC
Guest
Posts: n/a
Thanks. Can I use the 71-72 version?
Old 03-22-2021, 09:49 PM   #4
cwcarpenter98
cwcarpenter98's Avatar
You can use the 71-72 version only if you are also running the 71-72 ball joints
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 03-22-2021, 09:59 PM   #5
NathanC
Guest
Posts: n/a
Last question
Any reason not to use the 71-71 ball joints in my 65?
Old 03-22-2021, 10:05 PM   #6
lolife99
lolife99's Avatar
Originally Posted by NathanC View Post
Last question
What steering components are you using. The outer tie rods have to match also.
Keith
Old 03-22-2021, 10:10 PM   #7
lolife99
lolife99's Avatar
The easiest would be to use 63-70 conversion spindles and use your 1965 centerlink and tie rods.
71-72 or 73-87 is going to require the same year ball joints and tie rods to be swapped.
You would also need a used 71-72 or 73-87 centerlink. These aren’t sold new.
Then you’ll need to swap pitman arm and idler arm.
It’s a domino affect.
The 67-70, 71-72, and 73-87 idler arm mounts differently on the frame. You’ll have to locate it a drill new holes.
Do you currently have some of these parts?
Keith
Old 03-23-2021, 11:50 AM   #8
Chevy Fleetside
Chevy Fleetside's Avatar
http://www.67-72chevytrucks.com/vboa...isc+brake+swap This is basically what you need if you are using 73-87 spindles. I used the 75 spindles I had laying around.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 03-23-2021, 12:32 PM   #9
Freaky1
Freaky1's Avatar
I just got through getting my '65 front end finished & all I'm going to say is this, stick with the 63-70 option. Unless you plan to swap the entire thing out, or like me have some reason to use this year & that year, stick with the 63-70 spindles.
I'd like to propose a toast... to internal combustion and wind in the face. ~Michael Sarrazin "The Gumball Rally"
Freaky1 is offline   Reply With Quote
Old 03-30-2021, 10:06 PM   #10
NathanC
Guest
Posts: n/a
I have sets of both.
I have a complete 1965 cross member with all original parts..
I also recently purchased a power steering box from a friend that also included the 73-87 components..see pic.
stick with 63-67 parts/spindles or use these 73-87 parts and spindles? any pros/cons either way?
thanks!
Old 03-30-2021, 10:57 PM   #11
cwcarpenter98
If you want power steering, use the 73-87 stuff. If you want to keep it manual steering, use the 65 stuff
Christian Carpenter
Old 03-30-2021, 11:08 PM   #12
Chevy Fleetside
thanks!
If you use the 73 and up you will need the control arms also. I believe they are wider then the 65 control arms. Been 20 years I might have forgot something.
Old 03-30-2021, 11:11 PM   #13
cwcarpenter98
I put the 73-87 ball joints in my 63 control arms. I'm technically running the 73 rotors but they are aftermarket ones. Purchased before I knew I could get junkyard parts
Christian Carpenter
Old 03-30-2021, 11:21 PM   #14
lolife99
lolife99's Avatar
The 73-87 ball joints will work in the older control arms.
The later control arms aren’t any wider.
Keith
Old 03-30-2021, 11:23 PM   #15
lolife99
lolife99's Avatar
thanks!
I agree.
Use all the 73-87 parts with a p/s box.
You’ll need an adapter plate from Captain Fab on here to bolt the p/s box to your frame.
Keith
Old 03-31-2021, 02:31 AM   #16
Chevy Fleetside
Yes I know. I set one of my trucks up like that. I even have a thread on it. It the other truck I used all 75 components except the cross member.
Old 03-31-2021, 01:10 PM   #17
Freaky1
Freaky1's Avatar
This is what '73 tie rods look like in '65 spindles.
Just my 2 cents...
Sorry it's sideways.
