Old 03-23-2021, 01:33 PM   #201
EagleChief
EagleChief's Avatar
Re: Doing LS Swap - I have no idea what I'm doing!
Originally Posted by notsolo View Post
Congrats on getting engine set, frame inside to inside is 33 1/2.....33 5/8....the shape of the after market cross member will cause you some grief....the flared ends don't make it easy....I am close behind you, engine is in but also motor mounts are a bugger....I am using OEM crossmember for the trans, it may need moved, maybe next week...aarrrgh.
Congrats on getting it set in! That's awesome! I'm using original motor mounts as well, and they are a pain in the butt!
I appreciate the measurements. I'll check mine and see what I come up with.
1971 C10 - Hugger Orange/White
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197
LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460
EagleChief is offline   Reply With Quote
Old 03-24-2021, 11:05 AM   #202
EagleChief
EagleChief's Avatar
Pulled some measurements last night. It's going to be a tight fit! My frame is showing about 33-1/2" inside-to-inside. I measured the crossmember, and it is 33-1/4" out-to-out of the brackets. Soooo, theoretically, it will fit. I may have to get a hammer and force it in there. I'm probably going to call CJ Pony Parts and see what their info is on the placement of the crossmember. Maybe I'm missing something... there weren't any install instructions that came with it - but, probably shouldn't "have" to be any, either - except for me.
Old 03-29-2021, 12:21 PM   #203
EagleChief
EagleChief's Avatar
Got my motor mounts in yesterday! Driver's side mount had a bunch of rubber down in the threads. Had to pull the motor mount off the motor, clean it out, and run the bolt through it to make sure it would work. Once I got that done, it mounted right up.
Now, to get time to tackle the crossmember.
Old 03-29-2021, 01:35 PM   #204
notsolo
notsolo's Avatar
HammerTime...good luck, I test fit speed headers...Look good and fit good, working on my own motor mounts, need clearance for stock compressor so far so good. Tight, but fits with some trimming of the plate.
notsolo is offline   Reply With Quote
Old 03-30-2021, 07:46 AM   #205
jjzepplin
jjzepplin's Avatar
Check out the transmission crossmember I used in my No Daggum Money build. It was cheap and very well built and fits like it was custom made just for my truck. http://www.67-72chevytrucks.com/vboa...=550804&page=7 IFS is the builder.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 03-30-2021, 11:38 AM   #206
EagleChief
EagleChief's Avatar
Looked through some of the pages of your build. Nice job on your stuff! I did see that crossmember before... can't remember why I ended up with something different. I do like that there is plenty of room for exhaust.
Doing a quick search for it, though, I can't get their website to come up. Maybe work settings.
Old 03-30-2021, 04:39 PM   #207
bigmoe
bigmoe's Avatar
My partially restored truck came with an aftermarket crossmember from the po but I modified it to allow for better exhaust routing.
bigmoe is offline   Reply With Quote
Old 03-30-2021, 09:20 PM   #208
jjzepplin
jjzepplin's Avatar
This one is very close to mine and may be a clone. https://www.ebay.com/itm/Transmissio...cAAOSw-Rle~Enr
Old 03-31-2021, 11:07 AM   #209
EagleChief
EagleChief's Avatar
Thanks for the link! If I can't get the one I have to work, I'll probably go this route.
Old 03-31-2021, 11:56 AM   #210
bigmoe
bigmoe's Avatar
The one you have from CJ Pony will likely work. I kinda remember it took some twisting and turning to get mine in. Kinda like getting a couch through a doorway.
Old 04-05-2021, 11:06 AM   #211
EagleChief
EagleChief's Avatar
Got the crossmember in place. Not bolted in, but in place.
It looks like the holes will line up and work, I just have to "flex" the frame a little to get the bolts in place. Ordered a new transmission mount, as I forgot to do that.
Old 04-06-2021, 12:22 AM   #212
jjzepplin
jjzepplin's Avatar
Awesome! got a pic?
Old 04-06-2021, 07:53 AM   #213
notsolo
notsolo's Avatar
Also would like to see what you did with your motor mounts.
Old 04-06-2021, 08:09 AM   #214
EagleChief
EagleChief's Avatar
Awesome! got a pic?
I'll try and get some tonight.
Old 04-13-2021, 01:17 PM   #215
EagleChief
EagleChief's Avatar
A few days late, but here we go...
Old 04-13-2021, 05:30 PM   #216
notsolo
notsolo's Avatar
Thanks for posting, good to see what others are doing. I'm going to use the OEM A/C compressor, so I need to shift mine back as far as possible...got my computer back from LT1....and almost done reworking harness.
Old 04-13-2021, 06:23 PM   #217
Davidf
Your a bit ahead of me with my swap. Branden has my computer as of today and will start on harness tomorrow. Ordered some parts for the LM7 planned refresh. I decided to go with Hooker Blackheart engine mounts so I don't have to mod anything to keep the low mount compressor.
Davidf is offline   Reply With Quote
Old 04-14-2021, 10:56 AM   #218
EagleChief
EagleChief's Avatar
I think I'll try and put the A/C compressor in to see if it will fit. I found a bracket the other day that is a "low profile" a/c bracket that is supposed to move the compressor in closer to the engine.
https://www.ictbillet.com/ls-truck-l...-7176-lq4.html
Maybe that'll work?
I have an a/c truck, but, I have no idea when it worked last. So, it's not a huge priority to get it going. Would it be nice? Sure. But, in the "older" vehicles I've had, a/c hasn't worked, so I'm used to it.
Old 04-14-2021, 11:03 AM   #219
notsolo
notsolo's Avatar
If you have the extra mounting holes in the plate, you might gain some room behind the compressor moving the mount back to the 2nd hole in the frame top.
Old 04-14-2021, 11:08 AM   #220
ls1nova71
ls1nova71's Avatar
Maybe that'll work?
That link is for an aftermarket Sanden compressor, not the factory one. Also, I don't think with the conversion motor mounts, you will be able to get a compressor in there. Some times you can trim them and make one fit, but the mount really needs to be further back.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-14-2021, 11:21 AM   #221
EagleChief
EagleChief's Avatar
Here's another bracket that I saw: https://www.ictbillet.com/ls-engine-...ls1-block.html
It may be another option, I don't know.
Old 04-14-2021, 11:26 AM   #222
EagleChief
EagleChief's Avatar
I tried to mock up the stock a/c compressor mount when I put the adapter plates on. There was a pretty good chunk of the bracket that I would have had to cut out. I think it would be "doable", but I don't really have the time or "want to" at the moment to trim the bracket.
Old 04-14-2021, 02:30 PM   #223
Davidf
Your solution is here:
https://www.holley.com/blog/post/hoo...y_c10_pickups/
F-body mount (Anchor 3064) bolts directly to LS block in factory location, so no interference with A/C compressor. The stands then move the engine reward to stock location. So, keep low mount compressor, no trimming required. But, may still need to figure out how to mount refrigerant lines...lot's of options to solve that problem which I plan to address when I get to it.
I plan to use the Hooker Blackheart crossmember as well to ensure proper driveline angles.
Old 04-16-2021, 10:45 AM   #224
EagleChief
EagleChief's Avatar
Got everything bolted up last night! Engine and transmission are now fully bolted in. Now to start figuring out the fuel situation. At my pace, I should have that wrapped up by, say, July?
Old 04-16-2021, 05:28 PM   #225
notsolo
notsolo's Avatar
Forward progress...Good...I'm right behind you, probably August - September.... Need to get my mounts complete...I have a Boyd tank and in the process of custom -redo-finagle a OEM 2001 fuel pump onto this tank.
