04-03-2021, 01:14 PM | #1 |
1975 C10 with Volt Meter
Hi Guys,
I was hoping that someone might have some experience wit my situation. I have a 75 C10 Silverado with the factory gauges. All the inetrnet stuff I read says this truck should have an ammeter, but this one has a voltmeter. Anyone ever seen this ? Maybe a changeover model? It was sold new 10/13/74. |
04-03-2021, 01:34 PM | #2 |
Re: 1975 C10 with Volt Meter
Someone probably swapped that at some point in time.
Notice the difference of the (Tick) lines. .
04-03-2021, 01:50 PM | #3 |
Moderator
The diameter of the needle base is larger on the volt meter and the number font is wider with a different character spacing from the oil pressure gauge.
1975 still had lettering rather than hieroglyphs. A 1975 VOLT gauge would've had VOLT at the bottom rather than the battery hieroglyph. Someone retrofitted a later volt meter into that cluster.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
04-03-2021, 01:51 PM | #4 |
The 'font' is '81 up later model. It was swapped @ some point.
*Hatzie beat me to the punch*
04-03-2021, 01:54 PM | #5 |
Thanks guys, I thought it looked "newer", truck is pretty unmolested. It has a parasitic load problem.. Battery dies overnight. Probably get in there and find the original ammeter burned up and a short somewhere.
04-03-2021, 02:14 PM | #6 |
Here is a picture of my 84 and 77 and 73.
The 73 was modified with new gages though 1984 1977 1973 modified .
04-03-2021, 02:15 PM | #7 |
Moderator
Both of the ammeter shunt wires will have a Bumble Bee inline glass cartridge fuse holder or something similar.
I'd start by removing those fuses.
04-03-2021, 02:31 PM | #8 |
Possible the clock is a retrofit as well. On my 75, that is where the Brake light went. I think clocks rated a separate SPID listing.
I had a parasite drain issue on my 75. Turned out it was from the alternator. One of the diodes had partially broke down. It still charged normally, but would also drain the battery after a few days. |
04-03-2021, 04:08 PM | #9 |
My 75 with Amp Gauge.
04-04-2021, 11:00 AM | #10 | |
I think the clock is stock, its a Silverado with the gauge package, gas gauge is where a tach would be. That is the next project. . . . |
04-04-2021, 11:01 AM | #11 |
04-11-2021, 04:16 PM | #12 |
I think the first year 81-up needle are plastic, 80 down are stamped alloy needles for the gauges if not touched.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
