04-03-2021, 09:45 PM | #1 |
Heater core shut off valve
Hey everyone!
I read somewhere on here that someone had put a valve on their heater core inlet hose. So that the hot water would not circulate in the heater core. I'm interested in this fix as summer approaches. My heater shut off is worn out and allows hot air into the cab all the time. My question: Will adding a valve in my system cause any problems? Any advice is much appreciated.
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning! |
04-03-2021, 09:51 PM | #2 |
Old member
Re: Heater core shut off valve
I have run them for years with no problems. If you have AC in the truck it's worth every penny. When I installed the one in my 71 C 10 I got 5* more out of my AC.
Pictures are of the one in my Ramp truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-03-2021, 09:59 PM | #3 |
I've had one on my 69 Cougar for 20 years with no problems. I used a solder connection type brass ball valve and soldered on a couple inches of copper pipe and put two clamps on each side.
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
04-03-2021, 10:08 PM | #4 |
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
04-03-2021, 10:44 PM | #5 |
Mr. Cheyenne
So which line to you put it on, from the block or the Radiator?
I ask since the A/C shop put one on for me but it shuts off from the Radiator. Seems it would work better from the block side, in front of the vacuum control shut off valve.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
04-04-2021, 12:18 AM | #6 |
20' Daredevil (Ret)
Put the valve on the hose from the engine -- that is the heat source. The hose to the radiator is for water exiting the heater core.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
04-04-2021, 02:03 AM | #7 |
The vacuum shut off valve should be standard on an A/C truck. Basically does not matter what hose it is installed in, will stop the flow, in the heat side does make make sense.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-04-2021, 03:57 AM | #8 |
Ok, laugh at me...
This is to reduce hotness in the cab in the summer? I've seen them in a few trucks and wondered... |
04-04-2021, 07:08 AM | #9 | ||
Mr. Cheyenne
Now I need to decide when/if to move it over to the inlet/engine source side. It's one of those things I look at and scratch my head about .... "is that right?". At some point I suppose I'll just do it because it will get on my nerves LOL Edit: NM my hoses are actually correct. That pretty much it, to 100% stop hot water flow in the cab. If any hot water flow gets to the coil it affects the efficiency of the A/C (and I'd image any cool air you are trying to get if you haven't A/C).
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 04-04-2021 at 08:01 AM. |
04-04-2021, 07:18 AM | #10 | |
Mr. Cheyenne
04-04-2021, 08:05 AM | #11 |
They've been around forever , it's inexpensive at around $10.00 at your local parts house and installed in minutes .
And they look good , Not like you stole the plumbing off your grandmothers water heater !
04-04-2021, 08:30 AM | #12 |
Mr. Cheyenne
ya, I am pretty sure you (or someone else) commented on one of my post where the A/C guy installed a setup much like Andy's. Which is exactly the same cut off valve I installed on my water heater LOL!
04-04-2021, 08:46 AM | #13 |
Hey , it's your truck use whatever makes you happy .
04-04-2021, 09:36 AM | #14 |
Mr. Cheyenne
Well, I didn’t do it and I can say I was all that happy. But now I am, since I just changed it.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 04-04-2021 at 10:28 AM. |
04-04-2021, 10:07 AM | #15 |
Really appreciate the posts, stories, and replies.
Always learning from you all here. Happy Easter! Now I'm going to go shut off the hot water flow!
04-04-2021, 10:36 AM | #16 |
Mr. Cheyenne
Your post helped me as much as you External - got me motivated to sort mine out! I even did a bit more rerouting and the inlet line isn't touching any of the A/C lines now. I also cut down the water reserve line as it was like a mile long - so it's nice and tidy all around on that side with water lines.
Have fun - the more you visit these forums the more you learn you need to do to your truck LOL!
04-04-2021, 12:38 PM | #17 |
If your looking for original GM look, early 60's AC cars ( I would start with Cadillac or Buick or Olds) had a vacuum shut off valve.
04-04-2021, 01:41 PM | #18 |
I installed Vortec heads, which are lacking a coolant hole that older heads have for recirculation before the thermostat opens. I am relying on my heater core for recirculation, so installing a manual shutoff valve to the heater core would be a bad move in my case. I would have to install a thermostat bypass hose between the water pump and front of the intake manifold. I really don't like how those bypass hoses look. I will have to do that eventually though if I add AC to my truck.
04-04-2021, 08:23 PM | #19 |
Old member
Well I was going to post something but I want since it's Easter Sunday.
Both my trucks perform well and I'll just leave it at that. There is always someone. Good luck with it. I hope you figure it out.
04-04-2021, 09:49 PM | #20 |
I hope I didn't say anything that upset you. I was talking about the little hose people have to add to the front of the intake manifold when running Vortec heads on trucks with AC.
04-06-2021, 10:02 AM | #21 |
Apparently some later model vehicles require flow on the path to the heater core or suffer cavitation issues. I recently learned this & was not aware. These set-ups actually have a bypass that stops flow to the heater core (similar to these cut-off valves) yet allows for the loop to still circulate.
I learned about them on various LS swaps I've seen on the web.
04-06-2021, 10:27 AM | #22 |
Can this be done on a non-ac truck ?
350/th350 Sportsman2 heads Performer Intake 1406 carb 3.42 Eaton Posi |
04-06-2021, 10:46 AM | #23 |
Old member
My Ramp truck isn't AC truck and it cuts the heat off totally in the summer which helps a lot.
SCOTI, I have the valve in my 71 C 10 with the vacuum valve in the other line with the LS 6.0 and not had any problems before. Can you share some links on the problems are symptoms of it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 04-06-2021 at 10:52 AM. |
04-06-2021, 10:52 AM | #24 | |
04-06-2021, 11:19 AM | #25 |
The first image below from Summit looks very close to the cross-over used with 60's 289 fnords. The other images, also on Summit are from 4 Seasons that have internal valves. 4 seasons has a variety of manual cross-over styles, also shown in Summit.
'67 GMC 2500, 292, 4spd, AC |
Tags |
heater core |
