#576 |
Re: Used Parts Build
Those little lights work good. I might have to get me some for under the Jeep.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
#577 |
I'm just glad to be here!
How well has that Krylon coating on the exhaust holding up?
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#578 | |
I haven't driven it much but it seems to be holding up. The exhaust turbine is painted with the same stuff and under a blanket and its held up the same. While it scratched easily pre cured it seems to be okay now. Id try it again.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#579 |
My transmission was making a howling noise while in gear and stopped. It would go away in park and once driving though. After some research I figured the torque converter was bad. Bought a new one but hurt my back so it took a lot longer to get it in.
![]() My wife got me this sticker. Hope it works through the computer so you can see it. ![]()
#580 |
#581 |
hahahahah yep. Figured people would get a good laugh thinking it was something truck related when it is really a Rick roll.
#582 |
You can make your own custom ones so I was thinking maybe a link to your build here or something... This was better.
#583 |
I'm glad someone appreciates it! I picked it for the recessional song at our wedding. She got to pick the processional song so I figured it was my time to shine.
#584 |
Replaced the leaking output shaft seal. Seems to be leaking a tiny bit still though from the yoke though. Any thoughts?
I have been driving it around my neighborhood a bit to get some shake down miles on it and not be to far from home if I don't make it. ![]() Cut part of the bed mounts I made off so I can have them slotted for adjustment. Adding a bit more tube as well. ![]() I would like to say I planned on removing the bed gap but I set my rear end to be centered at ride height and not when laid out. So I pushed the bed forward a bit to make up the difference. The black strip is primer that I need to rattle can white or something for the mean time. The bedside isnt mounted or anything since I need to tweak a few things first. [url=https://flic.kr/p/2kJbn9C] ![]()
#585 |
![]() ![]() Join Date: Aug 2013
Looking good.....finally comes together.....you might check the yoke center plug....knowned to leak ...several methods of repair but the most common one is JB weld coated...just a thought
Joe |
#586 |
Did you put rtv under that yoke nut? I'm not sure if it is necessary there as I don't have any 2wd stuff myself. I know I needed it on my transfer case output.
#587 | ||
I got the bed on and have been driving it a bit. Lots of little things to do. I need to run my airlines and valves next. ![]() ![]()
#588 |
Congrats...this is a big achievement......hard work and great results....inspiring to follow you through this and I'm looking forward to the future work...it's just the beginning lol
Joe |
#589 |
Looks good out there on the street... Congrats
#590 |
Thanks guys. I appreciate it. Been taking care of all the little things while I drive it around.
Added a second tab to the exhaust to keep it from pivoting. The bushing came apart since the exhaust was twisting on it. ![]() The blinkers wouldnt cancel and it felt funky when I went to signal so I replaced the cam. ![]() Been driving it a few times a week to try to find all the bugs and break the rear end in before I get it turned and try to turn it up. ![]() ![]()
#591 |
That last pic! Truck looks really good. Honestly giving me more motivation to finish mine.
#592 |
Looks great. Glad you are putting miles on it.
#593 |
Took way to long to get this done. Finally finished welding, stripped, and painted my raised bed floor.
![]() Had to cut off my shock mount and move it down a quarter inch since my initial measurements were off and it hit the bed floor. ![]() Finally got to play around with CAD and used Send Cut Send to make some tabs and brackets I needed. ![]() I bought line lock because Amazon told me too... and drew up the bracket in CAD. ![]() Need to plumb and wire it ![]()
#594 |
Great skills.....enjoying your build
#595 |
Thanks Joe.
Got my truck back together so I could take it to a few meet ups. Did my first wash is like 8 years. ![]() Now I need to figure out how to cover this all up. ![]() Here is my idea. I plan on having the pivot on the forwardmost tube which means I have to pull the floor away from the cabside a bit before pivoting. I plan to run a wood floor and have maybe 3ish feet in the center that pivots. I saw this thread: https://67-72chevytrucks.com/vboard/...d.php?t=819450 and started playing with cardboard. This is roughly what I ended up with. You can click on it for the video. ![]() I drew it up in QCAD (free software) and sent it over to Send Cut Send. Hopefully it works...I'll be out of town for the next week so hopefully I return to cool parts!
#596 |
I drew it up in QCAD (free software) and sent it over to Send Cut Send. Hopefully it works...I'll be out of town for the next week so hopefully I return to cool parts![/QUOTE]
I see big things happening with "Send cut Send". Didn't know they existed? Thanks for the info. |
#597 |
I heard about Send Cut Send from another you tube account I follow. I see it as a great way for a lot of builders to step up their builds from the old methods of doing things with a cut off wheel and a drill.
From the pictures you shared, the parts looks great and come all deburred and looks like they used a surface belt sander on the face of the parts.
#598 | ||
I hope to start learning the 3D program so I can really make cool stuff!
#599 |
A machine cut bracket is hands down better for repeatability vs. hand made. I go that route as much as I can when building things now.
#600 | |
Drew up the brackets. Had them cut. ![]() Here is a video of them in action. I think I would do them a bit different next time but they will work well enough (I hope). ![]() Picked up this little fixture table off a company on Instagram (Dayton CNC). Was really cheap ($125) and seems to be high quality. Its small 6''x12'' but I figure Ill put it to good use some how. ![]() Went to drive it tonight after being out of town and decided to look it all over first... ![]() Universal coolant apparently doesnt work with dexcool. I didnt flush the engine before I hooked it all up. The rest of the system is new. I spend an hour or so flushing it with the hose. I ordered some radiator flush and will start again tomorrow. Ugh.
