Old 04-08-2021, 05:02 PM   #1
gsharp
64 C10 12 Bolt Rear Axle
Couple things, I want to convert the rear axle on my 64 to 5 lug and put a 3.08:1 ring and pinion in. Question is the 64 12 bolt not the same as the up to 72 rear ends? What size carrier is in my 64 12 bolt with the factory 3.73:1 gears?
gsharp is offline   Reply With Quote
Old 04-08-2021, 05:07 PM   #2
gmc684x4
Re: 64 C10 12 Bolt Rear Axle
The carrier will be the same
The axles are the same up to early 70
Late 70 to about 81 the 12 bolt is slightly wider taking a different axle set
Summit Moser and many others have 5 bolt axles for the pre 70 12 bolt
gmc684x4 is offline   Reply With Quote
Old 04-08-2021, 09:11 PM   #3
cwcarpenter98
cwcarpenter98's Avatar
The 63-64 12 bolts used 17 spline axles and spider gears. I've read that the axle bearing is different as well, but can't confirm myself as the previous owner swapped in a 65-70 12 bolt a long time ago
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 04-08-2021, 09:50 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
I bought an entire kit hub to hub from Quick for my 64 12 bolt. Moser 31 spline, Detroit gears, Eaton posi, bearings seals etc.
However the seals were different than what came with the kit, the ones I needed were National Oil Seals 8871.
Old 04-09-2021, 02:02 AM   #5
gmc684x4
I thought they where all the same spline
all my diffs are 67 to 77 I have in my collection
early 12 bolt truck axles are 30 3/4 " long
late 70 up are 31 7/16 " long
you can contact Usa standard Gear ask about the axle bearings difference use a newer 30 spline carrier posi or open in a 3 series
or look for a newer diff with 3.08 in it already
this is the 5 bolt swap axles from rock auto for a 67 diff
https://www.rockauto.com/en/moreinfo...321108&jsn=984
