11-18-2020, 11:27 AM | #1051 |
Re: Project: Recycle
I'll just leave these while I'm here....
11-18-2020, 11:42 AM | #1052 |
Love watching your build. It is like a machinist class online at times, then an engineering class, and ..... You are one amazing builder. There are a couple of you on the site that are awesome to learn from. Thank you!
11-18-2020, 12:43 PM | #1053 | |
Thank you for your contributions as well.
11-19-2020, 11:03 AM | #1054 |
Played around until the wee hours. Connected but I don't think the angles will play nice. Prob going to need to trim @ least another 1-2" off to get a better angle @ the top u-joint.
11-19-2020, 02:19 PM | #1055 |
Moderator
One option might be to get a High Angle U-Joint such as this: http://www.borgeson.com/xcart/product.php?productid=425
11-19-2020, 03:25 PM | #1056 | |
I used one of the steel joints I've had on a shelf & drilled the splines out to get it to that point in that last image. I'm going to try & determine the angles & will go from there. Borgeson states up to 35° working angles but my understanding is they need to be under 30° for a normal life.
11-20-2020, 08:29 AM | #1057 |
Watching closely as I always learn something from your build. Looking at the pictures, is there 2" there to remove without getting into the shift linkage and/or the firewall mount?
Rick |
11-20-2020, 11:33 AM | #1058 | |
I have probably ~1" material that could be cut from both sides of the firewall w/o issue. The engine compartment side would possibly also require slimming the firewall bracket slightly as well. Trimming that much total would put the column 'cone' less than a fingertips width gap from the dash & likely shorten the engine compartment side to the point of the shifter arm opening being immediately after the firewall bracket. I put a plastic angle template against it last night. It's more than 30° so the column will need to be shorter (which should decrease the angle @ the shaft/joint) or option 'B' (having to add the 3rd joint/adding complexity). My dilemma is, the shorter the column end = the better the angle @ the joint. But, moving the shaft over for the better angle is going to start getting closer than I want to the collector flange of the already built exhaust. I built the exhaust after confirming a PBDM/SBC was done w/the 2-joint combo on my buddys truck/s w/o issue. It was tight, but it cleared. I've been in contact w/him for more info. He used different u-joints (UniSteer vs. Borgeson) & his trucks were 68's so slightly different & he didn't shorten his 67-72 tilt columns (he said he didn't need to):
11-21-2020, 02:27 AM | #1059 |
Another long day/night....
I pulled the column, disassembled, cut the tack welds apart, & then chopped another inch off. Re-tacked the outer housing back together & same to the shift tube. Assembled/aligned the two tubes & slid the steering shaft in place. I bolted the assembly back into the truck. This is now as short as it can get w/o getting creative @ the lower/firewall mount. I have ideas for that but not until I could get past verifying the angle @ the joints. The column can't get closer to the dash; it's maxxed out w/o making contact. The open slot for the shift tube rotation is right @ the edge of the firewall mounting bracket. I'll need a steering shaft @ least 1" longer but it appears the additional cut was a positive adjustment.
11-21-2020, 02:31 AM | #1060 |
The angle looks better joint-to-joint. Not by much, but better regardless.
It actually wound up centering the shaft between the manifold flange & the C/O bracket upright (it was touching the rear upright of the C/O bracket). I grabbed my angle template, centered it on the column housing, & adjusted the arm to align it as close as possible to the shaft. I checked the angle & it's close enough to 30° that it should work w/o bind.....
11-21-2020, 07:35 AM | #1061 |
Scotti, nice work glad the angle line up for you. The only way that I see you would be able to move it any more would be to recess the firewall at the mounting area. I would hate to open that can of worms. I may have missed it in the thread, what's the finish on your Ram head manifolds?
Rick |
11-21-2020, 02:44 PM | #1062 | |
The manifolds are ceramic coated inside/out. The top coat I recall was 'titanium'. It has a satin, cast appearance. I had the headers on my dually done w/the same stuff & it wears well. I have 6yrs/7500miles on the headers & they still look decent. The collectors are the worst as they see the harsh conditions (water/grime/road debris) but still better vs a painted header.
11-23-2020, 04:24 PM | #1063 | |
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
11-23-2020, 05:27 PM | #1064 | |
11-23-2020, 05:53 PM | #1065 |
I don't believe there was any sort of seal between the column and the dash on the 60-66 trucks. There's not one on my 63, and it doesn't seem like there ever was one
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
11-23-2020, 06:16 PM | #1066 |
Shoot, yeah I forgot your year of truck. My bad.
11-23-2020, 07:30 PM | #1067 | |
Not going to lie.... I assumed they didn't have anything since mine didn't. BUT, I never actually researched what the automatics might have came with. I wasn't going to use anything but after wrestling the column in/out probably a dozen times by myself I managed to scratch/scuff the u-shaped opening when it slid down too far against the dash while adjusting things on the engine compartment side. So, I have to touch-up the paint or hide the damage. Sometimes hiding damage in plain site is easier (It's not what you know; it's what you see....).
11-29-2020, 09:39 PM | #1068 |
Your out of your analytical mind, mate ! Clean work, no surprise. Im still way ahead of you, bess step up those hours.
11-30-2020, 11:48 AM | #1069 | |
With the holidays, we still haven't gotten the sway bar arms done. Yes, I can do them by hand but I prefer the accuracy of machining for stuff like this if/when possible. I also reached out to a board member for steering column parts sources to obtain some rebuild parts. Again, holidays slowed that as well. Hopefully the next week or two will be productive.
04-09-2021, 06:08 PM | #1070 |
Slow progress....
Got the steering shaft machined for the DD joint. I'll do one more test fit of the partially assembled column/housing this weekend before finishing the rebuild.
04-10-2021, 09:14 AM | #1071 |
PROJECT 7DEUCE
Nice work scoti..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-10-2021, 07:22 PM | #1072 |
67-72 parts collector,…
SCOTI what was the advantage of machining round stock for your dd fittings over using production dd shaft material?
04-10-2021, 07:25 PM | #1073 |
Never mind.
I see yours is splined on the top end.
04-10-2021, 08:24 PM | #1074 |
Correct. It's the original main shaft for a tilt column.
04-16-2021, 02:05 PM | #1075 |
Column housing and shift tube welded up....
