Old 12-27-2020, 08:57 PM   #176
7D2N
7D2N's Avatar
Re: My winter project
I did some panel alignment before I cut and weld the door skins
Just for the fun of it
7D2N is offline   Reply With Quote
Old 03-20-2021, 04:59 PM   #177
7D2N
7D2N's Avatar
It's running good and I drove it a bit, how time flies.
Old 04-09-2021, 11:05 PM   #178
7D2N
7D2N's Avatar
I decided to stay away from welding the door patchs because I'm not much of a welder. I used a panel step tool and adhesive to glue the door patch skins together. I will use a tack weld in a couple of spots when I fold the edges over.
Old 04-10-2021, 07:57 AM   #179
jaros44sr
jaros44sr's Avatar
Nice work! Truck is looking great, almost done?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-11-2021, 08:10 PM   #180
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
. I like the adhesive idea..
Tom Vogel is offline   Reply With Quote
Old 04-14-2021, 08:21 PM   #181
7D2N
7D2N's Avatar
Thanks, guys. I thought I would have been a lot further down the road on my metal repair but door repairs have taken me a ton of time. Put doors on then take them off, line this up with that then do it again and again.
Old 04-14-2021, 09:42 PM   #182
Spf79
Spf79's Avatar
Looks great!!!
Full top blazer or bust....
Spf79 is offline   Reply With Quote
Old 05-26-2021, 07:45 PM   #183
7D2N
7D2N's Avatar
More rust repair, this time in the bed. Send in the donor.
Old 06-04-2021, 10:23 AM   #184
raggedjim
raggedjim's Avatar
You're doing a great job. Keep at it! Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 07-07-2021, 09:52 PM   #185
7D2N
7D2N's Avatar
I have the donor bed pieces prepped to go in and there is still a bunch of work ahead.
Old 07-08-2021, 01:22 PM   #186
YellowK5
Active Member
Nice work...Want to sell the donor tail gate?
YellowK5 is offline   Reply With Quote
Old 07-11-2021, 08:45 PM   #187
7D2N
7D2N's Avatar
Thank you. Starting the inside cutting.
K5, not at this time.
Old 07-11-2021, 09:06 PM   #188
7D2N
7D2N's Avatar
A lot of cutting and welding will be coming so protecting the front.
Old 07-22-2021, 09:56 PM   #189
7D2N
7D2N's Avatar
I found there is a lot of spot welds holding these pieces together. I had to be real careful cutting the welds on the inner wheel lip and outer skin.
Old 07-23-2021, 11:24 AM   #190
YellowK5
Active Member
Great work..
Old 07-24-2021, 12:37 PM   #191
LT7A
Wow, that pile of shrapnel really tells the story. How did it drive? It sure looks good. Thanks for telling about the build process and posting pictures. I actually can relate a lot more to a build like this than the custom ones.
Old 08-17-2021, 10:58 PM   #192
7D2N
7D2N's Avatar
Patching the tailgate/bed floor area.
Old 08-18-2021, 09:38 PM   #193
7D2N
7D2N's Avatar
Wheel tubs are undercoated and painted.
Old 08-19-2021, 11:19 PM   #194
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Keep at it. 👍
Old 08-26-2021, 09:40 PM   #195
7D2N
7D2N's Avatar
I have the wheel tubs in and the floor painted, a lot of time for what seemed like a little rust repair.
Old 09-02-2021, 09:06 PM   #196
7D2N
7D2N's Avatar
I have the fuel tank ready to go in and checking the length of the vent and fuel lines. I will need to put some on before the tank is in place. I did get a real dress-up kit.
Old 09-20-2021, 10:59 PM   #197
7D2N
7D2N's Avatar
New/old dress-up kit installed, pretty sure I lose some horsepower from removing the chrome/painted stuff but things we do.
Old 10-09-2021, 05:17 PM   #198
7D2N
7D2N's Avatar
Well after recovering from the shock of my paint job quote I decided to work on the refurbished parking lenses I got from a board member and all installed.
Old 10-16-2021, 11:26 AM   #199
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Where did you get the quote on paint?
Old 10-16-2021, 01:38 PM   #200
7D2N
7D2N's Avatar
Hi Tom, I got the quote from a shop that has been around for years and I have had them do a lot of work for me from full paint down to accident damage. They want to take the blazer down to bare metal for warranty purposes, I can understand that since their name is on it but 25k + is just a bit steep for me. Maybe I will have to learn paint.
