Old 04-14-2021, 10:06 AM   #1576
Gregski
Gregski's Avatar
Re: A '54 named Busty
Originally Posted by 8man View Post
You are going to be done soon. Also, agree with the crimp, solder and heat shrink everything.
thanks bro, Progress not Perfection!
Gregski is offline   Reply With Quote
Old 04-15-2021, 01:05 AM   #1577
Gregski
Gregski's Avatar
so new smaller tires showed up today so I got them mounted up and installed on the front and that seemed to have fixed the rubbing issue on the driver side only but the passenger side still dragged over the speed bumps but only at higher speeds
so I decided to trim about a foot off the front fender antler bracket and hammer flatter the wheel well ridge thingie and that finally did the trick, now I need to put a gentle bend in the cut off fender bracket and extend it a couple inches
Old 04-15-2021, 07:40 AM   #1578
6DoF
6DoF's Avatar
haha, can't hit nothing if nothing is there to hit!
6DoF is offline   Reply With Quote
Old 04-15-2021, 08:24 AM   #1579
youngrodder
youngrodder's Avatar
On my last few builds I always removed that brace and also rolled the fender edges. These were a must running 20" wheels and a decent sized tire not to mention on bagged truck. I never seen any issued not running those braces.
Nice fix
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 04-15-2021, 10:03 AM   #1580
Rickysnickers
Were you tires marked with "Prop 65?" HAHAHAHAHAHAHA!!!
Old 04-15-2021, 10:07 AM   #1581
Gregski
Gregski's Avatar
Nice fix
Marc
hey bud I really appreciate this type of feedback I was wondering which way to go on these, I notice the fender now flops and rattles in the front because I don't have the grille on her yet, but once that goes on it should pull it in nice and tight, I still may fandangle that bracket a little bit and weld it back on
Old 04-15-2021, 10:10 AM   #1582
Gregski
Gregski's Avatar
LOL, yeah they're the 215/P65R15
Old 04-15-2021, 10:19 AM   #1583
Gregski
Gregski's Avatar
aint that rights?! now come over please and help me find that annoying squeak coming somewhere, exactly, specifically in the TRUCK, ha ha that's as far as we've narrowed it down
seriously though it's coming from the front and only when we are driving, that or when we try to jack up the front end up from the front with the jack right under the engine crossmember, something will squeak for the first 2 to 3 pumps of the jack as we take the stress off the suspension then no more squeaking the rest of the way up, and I've re greased both the upper and lower ball joints on both sides again last night and still no dice!
we can also recreate the noise, with the wheels on the ground by rocking the top of the cab with our hands above the doors, it honestly sounds like two teenagers in a drive in
should we start removing parts until the noise goes away, or until there's nothing left, ha ha
Old 04-15-2021, 10:25 AM   #1584
Gregski
Gregski's Avatar
alright, so now with the smaller tires and the "trimmed" antler I'm thinking about pushing my luck and removing these knuckles out of the front coil springs!?
Old 04-15-2021, 10:43 AM   #1585
Gregski
Gregski's Avatar
well this puts a guy in a better Moog
and HECHO EN E.U.A to boot!
Old 04-15-2021, 10:47 PM   #1586
Gregski
Gregski's Avatar
got some important stuff done did today
Old 04-15-2021, 11:02 PM   #1587
Gregski
Gregski's Avatar
Safety Third... let's see how many of you will get that? ha ha
of course we only did one side, and won't get back to it for six months
and we shrimp wrapped that sucker
Old 04-16-2021, 08:15 AM   #1588
youngrodder
You should be good once the grille is bolted in place. On the rear fender braces I scored the flanges so I could pound the braces flat. It offers support but it makes the bracket thinner and it didn't interfere with the tires. Again this was on a bagged truck with 20" rims and large sidewall tire. I mention it because you could have done the same to the front braces. I chose to remove them all together and I also shaved the mount location on the inside fender lip to roll the fender edges to provide move tire clearance when turning. These mods were a must with a bagged truck with 20"+ rims. I did the same mod on my current product (53 Suburban).
Marc
Old 04-16-2021, 09:41 PM   #1589
Gregski
Gregski's Avatar
time to go fishing
Old 04-16-2021, 09:55 PM   #1590
Gregski
Gregski's Avatar
we got one in a beautiful 1993 GMC Sierra 1500 in a fully reclined position no less
not sure I'm a fan of the head rest, we shall see
Old 04-16-2021, 10:00 PM   #1591
Gregski
Gregski's Avatar
I prefer the ones like this one which came out of a 1991 Chevrolet GMT 400 K2500
note the full base without the notch for the handle like the one above, that's the good stuff right here
and since it has a tear it is a good reupholster in black pleather candidate to boot
Old 04-16-2021, 10:03 PM   #1592
Gregski
Gregski's Avatar
did I mention these seats were only $15 bucks, and this one came equiped with a "gold" handle
I think this one came with no Ace of Base but we found a matching base bracket on a different style seat later on in the day and snatched that
Old 04-16-2021, 10:09 PM   #1593
Gregski
Gregski's Avatar
I also scored this center console cup holder thingie out of a 2005 Pontiac Montana and let me tell you it weighs 712 lbs it is not all plastic by any means
lemme tell you it is covered in some funky stuff, these people knew how to party, but it ought to should clean up real nice and fill that gap between them buckets
Old 04-16-2021, 10:14 PM   #1594
Gregski
Gregski's Avatar
and the new (old) proper length Pitman Arm arrived today off of eBay
Old 04-16-2021, 11:00 PM   #1595
8man
Great deal on seats! Wish we had them around here.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 04-17-2021, 09:13 AM   #1596
Gregski
Gregski's Avatar
please check out the Vehicle Search on Row52.com maybe you will find something close by, and I may be letting some of mine go as I have three sets I think now
https://row52.com/Search
Old 04-17-2021, 09:22 AM   #1597
8man
Thank you sir. I see some screen time in my future.
8man-aka Robert
Old 04-17-2021, 10:11 AM   #1598
Gregski
Gregski's Avatar
I can always count on you Robert bright and early to be trucking or doing truck related stuffs, ha ha
Old 04-17-2021, 01:54 PM   #1599
Gregski
Gregski's Avatar
so the Jumagee cleaned up nice
why did it have candle wax on it? don't tell me
Old 04-17-2021, 01:56 PM   #1600
Gregski
Gregski's Avatar
I should be chasing those front suspension squeaks, I know that, you know that, we all know that, alright!? ha ha
so....
