04-15-2021, 04:48 PM | #1 |
67 gmc
I figure that the carrier has been mismatched. This is a series 3 rear end I think? Give some suggestions on direction. Thanks
Posted via Mobile Device |
04-16-2021, 04:58 AM | #2 |
Re: 67 gmc
I have never seen that. You are probably correct. More info would help. How long have you had the truck and how much have you driven it? What ratio is that ring gear (tooth count stamped into outer edge)? What was the reason for pulling the cover to inspect? It looks like pitting on that ring gear, so a good time to match it all up if that was the issue
04-16-2021, 09:28 AM | #3 |
Re: 67 gmc
It looks like old damage to me. The ring gear looks fairly new. I bet the rear end blew up a few years back and has been rebuilt. I don't see a problem. Was there a problem (noise, etc) that led you to open it up, or just a lubricant change?
04-16-2021, 10:54 AM | #4 |
Re: 67 gmc
My guess po changed the pinion seal sometime in the past never used a a new nut with lock tite
That is damage from the pinion biting the carrier You could check the pinion for chipped teeth I fixed a 10 bolt that had this happen to it 5 years latter still driving fine |
04-16-2021, 11:11 AM | #5 |
Re: 67 gmc
Here is a a mid 90s truck 10 bolt had the pinion let go looked high and low for another diff with the same gear set
My cousin pointed out did you check the pinion teeth sure enough no damage to the pinion picked up a new nut lock tited it in checked with inch lbs torque wrench |
04-16-2021, 11:59 AM | #6 | |
Re: 67 gmc
This one may be savable also. depending on the condition of the pinion gear. I can't really tell what's going on with the ring gear, from a photograph... |
04-16-2021, 02:53 PM | #7 | |
All about them K’s
Re: 67 gmc
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
