![]() Join Date: Dec 2009
Door Hinge: Friction Pad / Check Link Solution?
I have questions below
![]() I have been searching the Forum and found some old threads on this subject. ![]() If there was some new threads I missed them ![]() So I thought I would start this one. If you know of one please add the link to help others in the future ![]() #1 =There is this Reproduction Kit in the link below. Link: https://www.classicparts.com/1967-72...ctinfo/18-432/ #2 NOS friction pads = hard to find Borrowed picture from member that I have purchased many parts from. Thanks Question #1 - Is the Kit a decent replacement? Question #2 - Has anyone found a comparably material to make these out of? I prefer not to mess with asbestous ![]() One member on here used Nyltron. His update was: {The Nylatron sheet that I used in the hinges for friction pads didn’t perform as good as I wanted them to.} Question #3: What have you used as a successful replacement if they are missing ? Thanks ![]() .
Who Changed This?
![]() Join Date: Jan 2013
Re: Door Hinge: Friction Pad / Check Link Solution?
I forget where I bought the kit, but I have yet to get the pin out of the hinge. Guess I'll spray some more penetrating oil on it and have at it again. They are the nylon(?) pads. Only the driver's door needs them.
#3 | |
From the picture ,I thought they might be nylon. If so I can make some/ If they work okay? About that pin ![]() I have had some that come out okay and one that is still soaking ![]() .
20' Daredevil (Ret)
![]() Join Date: May 2003
From a 9 year old thread:
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#5 | |
Who Changed This?
#6 | |
20' Daredevil (Ret)
The hinge has a 1/4" diameter hole top & bottom, but the roll pin is 3/16". If you try to drive the pin out with a 1/4" drift, you'll be stopped by the 3/16" section at the center of the hinge. A smaller drift, 3/16" or less, will drive the pin out. HTH, good luck!
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 03-20-2021 at 06:25 PM. |
This is an option. I just wonder how a person could get it to size, Without breathing or dealing with the asbestos or nasty stuff. .
#8 | |
That pin that holds the check link arms is 3/16. I read where another member replaced these with 1/4 " after he got them out. .
#9 | |
20' Daredevil (Ret)
http://67-72chevytrucks.com/vboard/s...=318544&page=5
#10 | |
That build thread is Over the Top ![]() He has not logged in in Years. .
I used a set like these. I think it is nylon. Worked great. I think mine from classic industries but they looked identical.
https://www.ecklers.com/1967-1971-ch...oaAh7mEALw_wcB |
#12 | |
That's good info. I may give the Nylon a shot. Thanks .
#13 | |
Who Changed This?
![]() Join Date: Mar 2015
One doesn't have to remove the pin or the link to replace the pads.
I have attempted to get the pin out many times with no luck. If you pull the hinge pin you can drive the link out between the pads. Typically the hinge pin has to come out to replace the bushings anyway. Sometimes they come apart easy, sometimes hard. One picture of a pin I had to drill out. If the pin is rusted in soild you can bend the hinge ears if you use a press. Sometimes an air hammer can be used effectively. I like to powder coat them when I am done. Rick Last edited by Accelo; 03-21-2021 at 03:30 AM. |
#15 |
Okay
Here is what I have found ![]() I purchased some big Sheet material and machined it to size ![]() I still have to machine the notches in the ends ![]() It has Copper emebeded in it. .
#16 | |
20' Daredevil (Ret)
#17 | |
Time will tell ![]() .
