Old 04-20-2021, 04:31 PM   #1
kevinmfduane
86 4 spd won’t shift
Guys,
I have an 86 that someone added an older Muncie 4spd to at some point. I had a new clutch installed and then it sat for 2 years. I just charged the battery and sprayed some carb cleaner in the Holley. It fired right up. The clutch pedal presses down like I remember but the shifter won’t go into gear now that it’s running. Just earlier today it would go into gear before I had it running. The reservoir for the clutch was almost empty. I added dot 3 fluid. What should I do next?
kevinmfduane is offline   Reply With Quote
Old 04-20-2021, 05:16 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: 86 4 spd won’t shift
Bleed the slave cylinder.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-20-2021, 07:04 PM   #3
84 400
Sb 400 club
84 400's Avatar
Bleeding these clutches can be hard. I normally remove the master and slave and resivour as a unit and hold the slave above the resivout to bleed.
With the engine off and you put it in granny or reverse? Holding the clutch down start the truck does it move with the clutch depressed? Clutch disc could be stuck but I bet it's just air or a bad hydro component.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 04-20-2021, 07:37 PM   #4
hatzie
Moderator
hatzie's Avatar
The squarebody hydraulic clutches were a pain in the neck to bleed out.
You can do it with just the slave off. Tip the slave to put the bleeder at the top and push the slave plunger in and out.
The new parts quality was poo in the late 1990's. I went through five new master cylinders and more slave cylinders before I got one that didn't leak on my 1985 C10.
Old 04-22-2021, 02:41 PM   #5
Jeepwm69
Originally Posted by kevinmfduane View Post
Guys,
One of my Jeeps does that after sitting for long periods. The clutch rusts to the flywheel.
Try putting it in 3rd gear, push the clutch, and then try to start it. Make sure no one is in front of you when you do it, as it will likely roll forward until the flywheel breaks loose.
If the clutch reservoir was "almost empty" it shouldn't have air in the lines, IMO.
Jeepwm69 is offline   Reply With Quote
