Old 04-22-2021, 12:18 PM   #51
C101972
My truck has been off road for 30years, it’s a 72 Cheyenne so just getting back to it now. Interior parts, seat belts, door panels, I don’t have seats. Took it apart back then and now trying to build it back up. So what do you have? Thanks
C101972 is offline   Reply With Quote
Old 04-22-2021, 09:30 PM   #52
GSFMECH
On the road
GSFMECH's Avatar
Re: “Castro” my new 72 build
Sorry but I don't have much that I would get rid of, my brother and friends are all building trucks so the parts pretty much stay local.
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
Old 04-22-2021, 11:31 PM   #53
C101972
Thanks anyway. Keep up the great work!
Old 04-23-2021, 11:01 AM   #54
GSFMECH
On the road
GSFMECH's Avatar
With the original hub caps and stock wheels. Took it out for a final drive as a LWB.
Mike
Old 04-23-2021, 11:05 AM   #55
GSFMECH
On the road
GSFMECH's Avatar
Random photos of the QA1 Stuff
Mike
Old 04-23-2021, 11:07 AM   #56
GSFMECH
On the road
GSFMECH's Avatar
I picked up a set of NOS rockers off the board. I have a set of repops that came with the truck, but these work way better. Old Castro will like these, they fit like a glove but are not cheap when you find them. Worth every penny for the labor you save.
Mike
Old 04-23-2021, 11:09 AM   #57
GSFMECH
On the road
GSFMECH's Avatar
Also picked up a new Big Block fan shroud and fan here off the board, mine were smashed. I wound up not using this fan and used a mid-80’s C-30 5 blade fan for a 454 or diesel and an ECP radiator.
Mike
Old 04-23-2021, 11:11 AM   #58
GSFMECH
On the road
GSFMECH's Avatar
Picked up these slick QA1 tie rod adjusters, got them on and have the sway bars installed front and rear.
Mike
Old 04-23-2021, 11:13 AM   #59
GSFMECH
On the road
GSFMECH's Avatar
Time to pull the body off, it gave a fight, but I won, front clip off and started gutting the cab for removal.
Mike
Old 04-23-2021, 11:14 AM   #60
GSFMECH
On the road
GSFMECH's Avatar
The cab on jack stands for cleaning and rust repair.
Mike
Old 04-23-2021, 11:19 AM   #61
GSFMECH
On the road
GSFMECH's Avatar
The original jack and handle were still in it.
Mike
Old 04-25-2021, 12:10 PM   #62
GSFMECH
On the road
GSFMECH's Avatar
Fitting up the new right-side rocker
Mike
Old 04-25-2021, 12:12 PM   #63
GSFMECH
On the road
GSFMECH's Avatar
Test fitting the door and here you can see the cab corner repair. I didn’t take pictures on this side but, I also installed a new partial inner rocker, kick panel patch and also replaced both the lower A and B pillars
Mike
Old 04-25-2021, 12:14 PM   #64
GSFMECH
On the road
GSFMECH's Avatar
Starting to fit up the left side. You can’t beat OEM rockers, they fit like a glove.
Mike
Old 04-25-2021, 12:18 PM   #65
GSFMECH
On the road
GSFMECH's Avatar
Cut out the inner rocker, both lower A and B pillars and the rusty section of the kick panel. I like to the cut the inner rockers in half and fit the front and rear separately, I sometimes find the length a little off. Also replaced the cab corner
Mike
Old 04-25-2021, 12:20 PM   #66
GSFMECH
On the road
GSFMECH's Avatar
A couple more shots
Mike
Old 04-25-2021, 12:21 PM   #67
GSFMECH
On the road
GSFMECH's Avatar
FOR SALE genuine GM patch panels, some assembly required.
Mike
Old 04-25-2021, 12:25 PM   #68
GSFMECH
On the road
GSFMECH's Avatar
The driver’s side is done.
Mike
Old 04-25-2021, 12:28 PM   #69
GSFMECH
On the road
GSFMECH's Avatar
Door bottoms are so much fun
Mike
Old 04-25-2021, 12:32 PM   #70
GSFMECH
On the road
GSFMECH's Avatar
Consolidated my parts onto the frame so I would have a bit more room to work but the cab will come back off to finish the bottom. It looks cool and at this point I needed a little motivation
Mike
Old 04-25-2021, 12:36 PM   #71
GSFMECH
On the road
GSFMECH's Avatar
Started on the Passenger door
Mike
Old 04-25-2021, 12:39 PM   #72
GSFMECH
On the road
GSFMECH's Avatar
Test fit the doors and fenders to be sure I didn't screw it up and to check alignment.
Mike
Old 04-25-2021, 12:47 PM   #73
GSFMECH
On the road
GSFMECH's Avatar
3 partial cab braces installed, one was still good. I cut out the floor board for a high hump, went with a repop high hump which works fine. This was to give me a little more room to shim the trans upward to better align the driveshaft. I dressed all the welds underneath and scrubbed, scraped and wire wheeled for hours but finally got the bottom of the cab cleaned up and coated with Ospho. I installed the high hump temporarily, so I could weld the nuts to the floor pan.
Mike
Old 04-25-2021, 12:50 PM   #74
GSFMECH
On the road
GSFMECH's Avatar
Masked it up and undercoated it so now I'm done underneath
Mike
Old 04-25-2021, 09:45 PM   #75
cj847
cj847's Avatar
It appears that the aftermarket panels do not have the drain slots built into the bottom. There must be a way for water to get out of the door. The reason the doors rust out is that the factory holes (slots) get clogged allowing dirt and water to pool in the bottom of the door. At least drill as couple of holes in the bottom of each door.
cj847 is offline   Reply With Quote
