04-23-2021, 07:49 AM | #2076 |
Re: What did you do to your truck today.The 3rd chapter
Door panels look great! Your little helper looks like my 2 YO son, he is my wheel washer man as well. You can’t tell them no, gotta get them involved young as they grow up too fast.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
04-25-2021, 10:29 AM | #2077 |
Mr. Cheyenne
Wished I had a helper when I was washing the truck yesterday LOL!
A few days ago I replaced my PCV valve. The one on the truck "seemed" okay, it rattled okay but I wondered about it. So I got a ACDelco Professional one. The one on my truck had a right angle on it, where as the ACDelco one is straight up (every part search shows this is the correct one). It definitely flows better when I blow air back and forth compared to the old one (I bought a elbow adapter so its not sticking straight up). Though the real test was driving around, way much better. The biggest difference is very low speeds, say under 25 MPH and you are barely giving any gas. Like you do (or should) when driving around a neighborhood full of kids running around. Before I'd have like a deadzone at this speed, like she didn't want to really go until I gave her more pedal. After this, I did some vacuum hose rerouting. Bought a vacuum kit off Amazon with a ton of T-adapters of various sizes. I also cut the hoses so there isn't any extra flapping around. I think this helped too, since this was mainly the manifold to distributor advance line. Now after letting all of that settle for about a week, I finally installed my divorced electronic choke. It mounts right where the OEM one goes, then has a sensor on the forward intake manifold bolt (for GND) and then I tied it to the Stop Solenoid power. Man, it is nice to watch that choke warm up and move the plate and hold it solid in place. Oh, I also fixed a fuel pump oil leak, which I caused myself when I replaced my fuel pump a month or so ago. I did a crappy job by allowing the lower part of the gasket to fold onto itself at the bottom. Got to love re-doing stuff that you messed up yourself... but perhaps that is why two gaskets are sent with these pumps LOL! PS: I was at Sonic last night and a fellow pull up in the next stall. He gets out, knocks on the passenger's window, scares the poo out of my daughter LOL. He asks, "do you mind if I take a photo of your Truck??". I say sure, I don't mind. Then he says, "Thanks, your truck is cherry!". That my friends made my day, heck even my week! Ha!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 04-25-2021 at 11:41 AM. |
04-25-2021, 12:56 PM | #2078 |
Mr. Cheyenne
Just replaced my old oil line to gauge, thanks to LockDoc! The old line had like 4ft under the dash. Though I don't think it is any quieter that the old one but it is nice any shinny and nicely looped in the engine bay. Perhaps not professionally looped but it looks a lot better than the old one, that's for sure!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
04-25-2021, 06:22 PM | #2079 |
Got my cargo light and my cab lights installed.... Baby steps
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. Last edited by FL71C10; 04-25-2021 at 06:24 PM. Reason: Pics |
04-25-2021, 08:27 PM | #2080 |
Pulled my drive shaft to put a new output shaft seal in the transmission. Old seal fought me on the way out but I got it in pieces. Tailshaft had very little play so figur the bushing is not too bad - great. But wait, looks like more gear oil is coming from the speedometer gear housing than the rear seal.
I reached over to give it a wiggle and it came out of the transmission in my hand! The lock plate and screw are gone and have been for quite a while because the bolt hole was completely full of crud. Glad this thing hasn't gone more than about two miles since I got it running. Should I make myself a lock plate or purchase a new speedo gear housing and all?
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
04-25-2021, 08:32 PM | #2081 |
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra Last edited by 67C10Step; 04-25-2021 at 08:33 PM. Reason: double post |
04-25-2021, 09:43 PM | #2082 |
Who Changed This?
If the rear seal is shot I'd put the bushing in when I was there. I'd make a lock plate instead of buying the whole magilla, personally.
04-26-2021, 02:54 PM | #2083 |
Installed the short tilt I purchased from 70shortfleet took about an hour. Nice having the wheel further away and up . Makes getting in and out much easier but I’m a little stumped on the grey wire I’m assuming it’s for the indicator light but I can’t find where it would connect. Mine had the fiber optic wire from the dash bulb
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 05-03-2021 at 04:55 PM. |
04-26-2021, 03:10 PM | #2084 |
Mr. Cheyenne
that wire goes to the fuse box, where it powers on when you turn on your lights.
04-26-2021, 03:50 PM | #2085 | |
Anybody got dimensions on the speedo gear housing retainer? Doesn't look like something that would be hard to fab up.
04-26-2021, 04:22 PM | #2086 | |
Found it it's where the light for the cigarette lighter lite is plugged into. For now I put the indicator there and I'll write up a pigtail
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 04-26-2021 at 06:05 PM. |
04-26-2021, 04:36 PM | #2087 |
Went to a large regional truck meet
Yesterday. Won the award for nicest truck bed.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
04-26-2021, 04:52 PM | #2088 | |
Who Changed This?
04-26-2021, 08:18 PM | #2089 |
04-27-2021, 12:00 AM | #2090 |
This was put together by the Northwest C10 group (can be found on Facebook) and the cruise was in Enumclaw, WA. It is planned to be there again next Spring.
04-30-2021, 05:36 PM | #2091 |
Painted inside of my 72 K20 cab today.....getting there, slowly but surely!
04-30-2021, 05:52 PM | #2092 |
Proprietor of Dale's Corner
Looks good, I like the color.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
04-30-2021, 06:01 PM | #2093 |
04-30-2021, 07:14 PM | #2094 |
Lookin good 30772!
04-30-2021, 11:46 PM | #2095 |
Big shout out to Wes Hepp!
For the first time, my heater control is alive!!! |
05-02-2021, 10:43 AM | #2096 |
Mr. Cheyenne
At Sunday cars and coffee. Think time I parked next to a C10 lol
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 05-02-2021 at 11:10 AM. |
05-02-2021, 12:19 PM | #2097 | |
Mr. Cheyenne
What else did I do today? I got my email from Quadrajet Power they have started on my rebuild and now have paid for the work! It should be here soon! YAY!!
05-02-2021, 05:47 PM | #2098 |
This past Tuesday, I pulled the uno barrel carb off my truck to check for a leak. Nothing was wet, but I haven't run it much since November, so everything in the bowl likely leaked out & dried. Found a bolt was missing that held the base part to the midsection. Went on a mad hunt for another screw at every hardware store in town. Had to settle for a bolt. Just got the tags legal on Friday. As long as the weather will cooperate, I'll get the tires dirty tomorrow.
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
05-03-2021, 01:50 PM | #2099 |
I picked it up at the detailer. A little before and after.
I hope to get the rockers changed soon and I sure need a nice dark gold tailgate.
05-03-2021, 08:04 PM | #2100 |
Just finished under hood refurb and repaint and Vintage Air install. 1970 C10 Short bed Fleetside. 350/th400. |
