04-17-2021, 12:45 AM | #101 |
Re: 1970 C30 Car hauler Buildish thread.
Unfortunately No real progress has been made on the truck. I've been busy redoing the bead roller. The forward and reverse switch broke a few years ago and I have been wanting to finish it for a while now, That and I needed to make a table for it, it keeps leaving scratch marks when I make a turn.
20210414_161705 by jarrod vanwinkle, on Flickr I made a table out of leftover scraps. 20210406_203427 by jarrod vanwinkle, on Flickr 20210408_182344 by jarrod vanwinkle, on Flickr 20210408_182339 by jarrod vanwinkle, on Flickr 20210408_182351 by jarrod vanwinkle, on Flickr I made some stand off to mount the table 20210408_165554 by jarrod vanwinkle, on Flickr I started tearing it down, I built it 9 or 10 years ago when I only had a cheap stick welder and just started to learn to weld, I warped it really bad and had to put it in a press to fix it. 20210411_154614 by jarrod vanwinkle, on Flickr 20210411_155115 by jarrod vanwinkle, on Flickr 20210411_155609 by jarrod vanwinkle, on Flickr 20210411_161756 by jarrod vanwinkle, on Flickr 20210411_164225 by jarrod vanwinkle, on Flickr 20210411_202307 by jarrod vanwinkle, on Flickr 20210411_202249 by jarrod vanwinkle, on Flickr 20210411_202619 by jarrod vanwinkle, on Flickr I ended up redoing the reinforcements 20210411_203241 by jarrod vanwinkle, on Flickr 20210411_213657 by jarrod vanwinkle, on Flickr 20210411_213704 by jarrod vanwinkle, on Flickr Added some die holders. 20210413_203809 by jarrod vanwinkle, on Flickr 20210414_134951 by jarrod vanwinkle, on Flickr 20210414_201258 by jarrod vanwinkle, on Flickr 20210414_201311 by jarrod vanwinkle, on Flickr 20210414_202912 by jarrod vanwinkle, on Flickr 20210414_205023 by jarrod vanwinkle, on Flickr 20210414_205026 by jarrod vanwinkle, on Flickr Ready for paint. I was going to paint it the same color of the truck but I ended up finding some left over paint I used on the engine in a rat rod I had build a few years ago. 20210415_155158 by jarrod vanwinkle, on Flickr 20210415_155150 by jarrod vanwinkle, on Flickr 20210415_160607 by jarrod vanwinkle, on Flickr 20210415_163947 by jarrod vanwinkle, on Flickr 20210415_163955 by jarrod vanwinkle, on Flickr I started making a enclosure for the electronics 20210416_160202 by jarrod vanwinkle, on Flickr 20210416_210118 by jarrod vanwinkle, on Flickr 20210416_210108 by jarrod vanwinkle, on Flickr |
04-17-2021, 06:29 AM | #102 |
Nice work on the Bead Roller
04-22-2021, 05:29 AM | #103 |
6>8 Plugless........
Wow! You have a lot of time in that bead roller and it is sweet! I really like your garden area too. My wife wants to do another garden this year. We had an area tilled and I'm glad we didn't plant anything yet. It keeps dipping below freezing here still. Keep up the great work!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
04-24-2021, 11:23 PM | #104 | |
Thanks! I'm happy with it so far.
I finally finished the bead roller it only took me 9 years. 20210419_194536 by jarrod vanwinkle, on Flickr 20210419_194546 by jarrod vanwinkle, on Flickr 20210421_204516 by jarrod vanwinkle, on Flickr 20210421_211022 by jarrod vanwinkle, on Flickr I finished up the the brackets and painted the rails and installed the fuel tanks hopefully for the final time. 20210419_204015 by jarrod vanwinkle, on Flickr 20210419_204012 by jarrod vanwinkle, on Flickr 20210419_204020 by jarrod vanwinkle, on Flickr 20210419_204031 by jarrod vanwinkle, on Flickr I also installed the fuel filler neck. 20210421_194758 by jarrod vanwinkle, on Flickr 20210421_194750 by jarrod vanwinkle, on Flickr 20210422_153828 by jarrod vanwinkle, on Flickr I also started to install sound deadening mat its MAT66 80 mil 20210422_214829 by jarrod vanwinkle, on Flickr 20210423_211037 by jarrod vanwinkle, on Flickr 20210423_210910 by jarrod vanwinkle, on Flickr 20210423_210904 by jarrod vanwinkle, on Flickr 20210423_214152 by jarrod vanwinkle, on Flickr |
04-25-2021, 10:29 AM | #105 |
This is a fun build to see progress, keep up the great work
1972 C30 2WD 157” WB |
05-04-2021, 03:24 AM | #106 |
Thanks! Unfortunately this will probably be the last update for a while as i'm getting ready to have replacement hip surgery in a few hours.
Not much progress has been made, I cut another hole in the cab, It goes from my switch panel to the box that the air compressors sit in. I will be wiring up a six way relay box that will be going inside of the box it will control the air compressors, the roof rack lights, rear light bar, the tie down bed lights, Maybe an air horn or something? 20210425_153415 by jarrod vanwinkle, on Flickr 20210425_195849 by jarrod vanwinkle, on Flickr 20210425_200110 by jarrod vanwinkle, on Flickr stripped the switch panel down for paint. 20210425_165721 by jarrod vanwinkle, on Flickr relocated the tab to clear the gauges, 20210425_171905 by jarrod vanwinkle, on Flickr Painted 20210425_200236 by jarrod vanwinkle, on Flickr gauges and switches installed 20210426_205754 by jarrod vanwinkle, on Flickr |
05-04-2021, 07:21 AM | #107 |
Jarrod good luck with your hip surgery. Where did you get your wheels? Also are you running a steel inside dual?
NHRA Super Street 469C It only runs 10.90 at 156 mph |
05-04-2021, 08:20 AM | #108 |
Oh man!!!
Praying for a great surgery!!! |
05-04-2021, 11:19 PM | #109 |
Been following your Build.
For some-Time now Thinking of you. With this surgery. Hope it makes you feel younger Keep in touch for sure .
05-19-2021, 07:19 PM | #110 | ||
That said the wheels are off ebay, One was a return with a few scratches that I got for half price! and I ordered the other from the same seller. You can also find them on amazon https://www.amazon.com/dp/B07RJZK4X7...v_ov_lig_dp_it Thank you, I really appreciate that! I sure need it, my hip is doing good so far but I went in to get my staples out yesterday and they gave me the second covid shot while i was there, and man I feel worse than I did when I first got out of sugary. Quote:
Here is a pic of the new upgrade lol 20210504_130142 by jarrod vanwinkle, on Flickr Last edited by jarrodblake; 05-19-2021 at 07:50 PM. |
05-19-2021, 10:47 PM | #111 |
Looks good.
Well wishes for you. .
05-20-2021, 08:03 AM | #112 |
I thought you were older, 31 is young. Good luck with the recovery.
08-31-2021, 02:29 AM | #113 | |
Thank you!
I'm finally able to get back to work, I still have to be careful but Its good to get back to work. I painted the side panels for the truck. 20210710_155259 by jarrod vanwinkle, on Flickr 20210710_155251 by jarrod vanwinkle, on Flickr 20210710_194333 by jarrod vanwinkle, on Flickr 20210711_152643 by jarrod vanwinkle, on Flickr 20210713_165654 by jarrod vanwinkle, on Flickr 20210731_135304 by jarrod vanwinkle, on Flickr 20210731_201450 by jarrod vanwinkle, on Flickr Did a test fit of the front wheels on the rear. 20210806_125258 by jarrod vanwinkle, on Flickr 20210806_125310 by jarrod vanwinkle, on Flickr installed the floor mat 20210812_165321 by jarrod vanwinkle, on Flickr 20210812_182616 by jarrod vanwinkle, on Flickr Made a bracket for my switch panel dimmer, 5 volt out to the crank sensor, GPS antenna and some relays 20210816_160448 by jarrod vanwinkle, on Flickr 20210816_160450 by jarrod vanwinkle, on Flickr 20210816_160454 by jarrod vanwinkle, on Flickr 20210816_161013 by jarrod vanwinkle, on Flickr Installed some universal seat belts 20210828_171914 by jarrod vanwinkle, on Flickr 20210828_171920 by jarrod vanwinkle, on Flickr finally finished wiring the under hood lights. 20210828_215345 by jarrod vanwinkle, on Flickr installed the gauges! 20210829_214859 by jarrod vanwinkle, on Flickr |
08-31-2021, 03:20 PM | #114 |
Look'n Good!!!
The green panels will look even better, when all the rest is green!!! |
09-01-2021, 09:27 AM | #115 |
QUOTE>>>>>>>Thanks, Well if my body would quit falling apart, I would have had it finished by now lol, back surgery 2019, 2020 hip surgery, now getting a full hip replacement in a month or so don't have a date yet, with my luck I'll have to have a knee done next year lol. at the moment I am only able to work 2-3 hours a day at most before I can no longer stand. I will probably be down a few months between the surgery and physical therapy. So i'm hoping to get this side done so I can get started on the other side so I can get the truck out of the garage before my surgery.
Buddy, I know what your going through, it kills me that I only get a couple yours in a day. Same situation, numerous back surgerys from 2012 to current, I have 3 rods in my back fusing my spine to my pelvis. I cant bend for **** and when I do i get the Ole sciatica pain doesn't play nice. I sit in a chair most the time it seems. That being said your build is pretty badass and your doing a great job. i Hope your doing well and continue to do so.... don't push it too hard. its very easy to hurt yourself further, just by lifting too much or twisting wrong and set you back further. Ask me how I know. |
09-01-2021, 10:30 AM | #116 |
That's looking really nice! I hope the hip upgrade is going well. My Dad just got his replaced and they had to replace the whole thing. He's been struggling but getting through it.
09-07-2021, 12:38 AM | #117 | |||
The river from the other day from my step fathers tritoon.. 20210829_194610 by jarrod vanwinkle, on Flickr 20210829_195110 by jarrod vanwinkle, on Flickr I made a speaker box the storage unit for behind the seat but ran out of carpet for the top. 20210901_205828 by jarrod vanwinkle, on Flickr 20210901_212940 by jarrod vanwinkle, on Flickr 20210904_145723 by jarrod vanwinkle, on Flickr 20210904_203638 by jarrod vanwinkle, on Flickr I installed a new winch mount. 20210831_194046 by jarrod vanwinkle, on Flickr 20210905_202628 by jarrod vanwinkle, on Flickr 20210905_202924 by jarrod vanwinkle, on Flickr I temporary installed the battery so I can turn the truck around so I can do the other side of the bed. 20210906_200436 by jarrod vanwinkle, on Flickr |
09-15-2021, 09:53 AM | #118 |
Nice views from the tritoon. We are running out of good weather to do stuff like that now. Nice work on the speakers. That's one thing that usually gets put off just to get a project driving. My Camaro still has no speakers in it. I need to finish that.
09-16-2021, 11:46 PM | #119 | |
I took it around back for a few pics before I turned it around. 20210907_174253 by jarrod vanwinkle, on Flickr IMG_82561 by jarrod vanwinkle, on Flickr 20210907_180540 by jarrod vanwinkle, on Flickr 20210907_180601 by jarrod vanwinkle, on Flickr 20210907_180524 by jarrod vanwinkle, on Flickr 20210907_180630 by jarrod vanwinkle, on Flickr 20210907_180621 by jarrod vanwinkle, on Flickr 20210907_180725 by jarrod vanwinkle, on Flickr 20210907_181327 by jarrod vanwinkle, on Flickr 20210907_181403 by jarrod vanwinkle, on Flickr 20210907_181336 by jarrod vanwinkle, on Flickr 20210907_181410 by jarrod vanwinkle, on Flickr 20210907_181426 by jarrod vanwinkle, on Flickr 20210907_181521 by jarrod vanwinkle, on Flickr 20210907_181528 by jarrod vanwinkle, on Flickr 20210907_184913 by jarrod vanwinkle, on Flickr I mounted the gooseneck hitch and cut out the mess over the passenger side rear wheel, I'm going to redo it. 20210910_203339 by jarrod vanwinkle, on Flickr 20210911_203130 by jarrod vanwinkle, on Flickr 20210912_202741 by jarrod vanwinkle, on Flickr 20210912_154500 by jarrod vanwinkle, on Flickr 20210912_211126 by jarrod vanwinkle, on Flickr 20210913_194507 by jarrod vanwinkle, on Flickr 20210913_200311 by jarrod vanwinkle, on Flickr 20210913_200339 by jarrod vanwinkle, on Flickr I made a removable center supports that the wood will go on unfortunately I messed up I made 4 but measured for 3 and had already welded in the first two before I realized what I did. That said nothing really heavy will ever be in the center of the bed. 20210915_211947 by jarrod vanwinkle, on Flickr 20210916_201309 by jarrod vanwinkle, on Flickr 20210916_201537 by jarrod vanwinkle, on Flickr |
09-17-2021, 06:04 AM | #120 |
Nice work on the hitch and the pics out by your barn look very nice!
09-24-2021, 10:51 PM | #121 | |
I picked up a new axle a Dana 80 dually posi with 3:54 gears out of a second gen 3500. The dana 80 is 72.75 hub to hub and the stock axle is around 63 hub to hub. I will need to move the Spring Perchs and shock mounts. The axle had new bearings seals, and brake pads but one seal was leaking really bad and runed the pads. After pulling it apart it looks like the breather was clogged. But there is some wear on the axle where the seal sits, so I will be installing a set of speedi-sleeve 99296. 20210917_204159 by jarrod vanwinkle, on Flickr 20210917_210448 by jarrod vanwinkle, on Flickr this side was not leaking 20210919_210846 by jarrod vanwinkle, on Flickr but where the seal sits has more wear. 20210920_203646 by jarrod vanwinkle, on Flickr this side must have been leaking for a while 20210917_231638 by jarrod vanwinkle, on Flickr 20210920_205511 by jarrod vanwinkle, on Flickr 20210922_233519 by jarrod vanwinkle, on Flickr 20210922_233531 by jarrod vanwinkle, on Flickr 20210923_211942 by jarrod vanwinkle, on Flickr Por15ed the gooseneck mount and center braces. 20210923_163611 by jarrod vanwinkle, on Flickr 20210923_163559 by jarrod vanwinkle, on Flickr 20210923_163621 by jarrod vanwinkle, on Flickr 20210923_164628 by jarrod vanwinkle, on Flickr Pulled out the old axle. 20210924_164216 by jarrod vanwinkle, on Flickr when I removed the drive shaft I found that one of the nuts were missing it looks like it was missing for a while. 20210924_164206 by jarrod vanwinkle, on Flickr The overload spacers I don't know if they were aluminum or magnesium. 20210924_192135 by jarrod vanwinkle, on Flickr 20210924_192601 by jarrod vanwinkle, on Flickr I dont know if this is stock or not but it has a 2.5 lift block 20210924_194418 by jarrod vanwinkle, on Flickr 20210924_200203 by jarrod vanwinkle, on Flickr going to have to wide body the flat bed a few inches 20210924_200047 by jarrod vanwinkle, on Flickr 20210924_200112 by jarrod vanwinkle, on Flickr |
09-25-2021, 05:08 AM | #122 |
Nice find on the D80. You should like that a lot better. The 3:54s just work so well behind a 12v. If you decide to sell the HO rear axle I might be interested in it.
10-02-2021, 12:18 AM | #123 | |
I removed the coil spring perches that were booger welded on. 20210925_150118 by jarrod vanwinkle, on Flickr Fall weather is finally here! 20210925_165858 by jarrod vanwinkle, on Flickr 20210925_172618 by jarrod vanwinkle, on Flickr I also reinstalled parking brake pedal as i'm finally going to have a parking brake, well if fedex every decides to drop off my packages. I was going to make an electric parking brake as the fuse box I made is in the way but I think it will just fit with 3/8 on both sides. 20210925_204051 by jarrod vanwinkle, on Flickr I also had to move the manual fuel shut off on the other side. I think I will like it better here. 20210925_204057 by jarrod vanwinkle, on Flickr I cut off the old spring perches . 20210926_140228 by jarrod vanwinkle, on Flickr I made some shock mount brackets the inside factory mount was the same place as the outside mount on the old axle. so I just had to add one tab to each side and that way II Will hopefully be able to use the dana 80 sway bar. 20210928_183640 by jarrod vanwinkle, on Flickr 20210929_203738 by jarrod vanwinkle, on Flickr 20210929_215026 by jarrod vanwinkle, on Flickr 20210929_215048 by jarrod vanwinkle, on Flickr Imade a spring perch location jig to help locate the nre perches on to the new axle. 20210930_151119 by jarrod vanwinkle, on Flickr I also made a mark where the center of the old perches were before i cut them off. 20210930_151206 by jarrod vanwinkle, on Flickr 20210930_152739 by jarrod vanwinkle, on Flickr 20210930_152440 by jarrod vanwinkle, on Flickr I got lucky they ended up being 7 and 5/8 from the brake flange on each side with the jig. 20210930_152525 by jarrod vanwinkle, on Flickr 20210930_153828 by jarrod vanwinkle, on Flickr 20210930_153835 by jarrod vanwinkle, on Flickr 20210930_153847 by jarrod vanwinkle, on Flickr 20210930_153906 by jarrod vanwinkle, on Flickr My new overload spacers I could not find a set so i'm make my own 20210930_155258 by jarrod vanwinkle, on Flickr 20210930_193404 by jarrod vanwinkle, on Flickr Wire wheeled and painted 20211001_155825 by jarrod vanwinkle, on Flickr 20211001_155846 by jarrod vanwinkle, on Flickr 20211001_210613 by jarrod vanwinkle, on Flickr |
10-02-2021, 08:28 AM | #124 |
Nice work on the jig and getting the new mounts put on. It's nuts how long that stuff takes to get all done.
10-19-2021, 12:11 AM | #125 | |
The jig ended up working perfectly, Its all the little things that take for ever, that and it doesn't help that Fedex ended up losing some of my brake parts for the axle. I installed a pair of Speedi-Sleeves on the axle but they where to long I had to trim them to fit. Not sure If your supposed to but It worked out. 20211002_141406 by jarrod vanwinkle, on Flickr 20211002_141643 by jarrod vanwinkle, on Flickr 20211002_142222 by jarrod vanwinkle, on Flickr I rounded it over so it doesn't cut the seals. 20211002_142848 by jarrod vanwinkle, on Flickr 20211002_142900 by jarrod vanwinkle, on Flickr 20211002_143528 by jarrod vanwinkle, on Flickr 20211002_195554 by jarrod vanwinkle, on Flickr Well..... Waiting on brake parts I finally decided to install the mirrors. So I have be trying to decide on what to do about the mirrors for a few years now. I like the way west coast tow mirrors look but the idea of drilling all those holes in the dor and then in a few year then starting to rust I just could not bring my self to do it. The and I need the mirrors to fold out of the way as I park it in the lower half of our barn and its narrow. After years of trying to decide on how to mount the mirrors I decided to mount them like the way the do on the kodiak trucks on the cowl. My cowl panel is junk It hand a lot of little holes and pitting already so I have no problem cutting it up. 20211005_154319 by jarrod vanwinkle, on Flickr 20211005_154321 by jarrod vanwinkle, on Flickr 20211005_161802 by jarrod vanwinkle, on Flickr 20211005_163509 by jarrod vanwinkle, on Flickr 20211005_163525 by jarrod vanwinkle, on Flickr 20211006_145225 by jarrod vanwinkle, on Flickr 20211006_141516 by jarrod vanwinkle, on Flickr 20211007_193736 by jarrod vanwinkle, on Flickr finished the overload spring spacers. 20211008_144250 by jarrod vanwinkle, on Flickr 20211008_144350 by jarrod vanwinkle, on Flickr 20211008_144411 by jarrod vanwinkle, on Flickr sunset on the tritoon its been a warm october here trees are still green. 20211010_190501 by jarrod vanwinkle, on Flickr 20211010_190659 by jarrod vanwinkle, on Flickr 20211010_190126 by jarrod vanwinkle, on Flickr 20211010_190244 by jarrod vanwinkle, on Flickr finally all the brake parts are in. 20211010_220230 by jarrod vanwinkle, on Flickr 20211010_200234 by jarrod vanwinkle, on Flickr 20211012_202131 by jarrod vanwinkle, on Flickr 20211012_202936 by jarrod vanwinkle, on Flickr 20211014_155107 by jarrod vanwinkle, on Flickr 20211014_160008 by jarrod vanwinkle, on Flickr I modified the cab jacks I made to mount the cab on the frame to mount the axle. 20211014_185024 by jarrod vanwinkle, on Flickr 20211014_191947 by jarrod vanwinkle, on Flickr 20211014_192000 by jarrod vanwinkle, on Flickr I had to wait until I got the axle in be for I mushered for new U bolts. 20211014_192042 by jarrod vanwinkle, on Flickr 20211014_192331 by jarrod vanwinkle, on Flickr 20211015_143238 by jarrod vanwinkle, on Flickr 20211015_143242 by jarrod vanwinkle, on Flickr I test fit the wheel and It looks like I will need to widen the bed 4.5 inches. 20211016_142751 by jarrod vanwinkle, on Flickr 20211016_142806 by jarrod vanwinkle, on Flickr 20211016_142754 by jarrod vanwinkle, on Flickr new long wheel studs so I can finally install all the lug nuts. 20211016_171614 by jarrod vanwinkle, on Flickr 20211016_171810 by jarrod vanwinkle, on Flickr I also started making brackets for helper bags. 20211016_182040 by jarrod vanwinkle, on Flickr 20211016_212638 by jarrod vanwinkle, on Flickr 20211016_212652 by jarrod vanwinkle, on Flickr 20211018_195657 by jarrod vanwinkle, on Flickr I also scored a set of wheel with new tires from the junkyard that are the correct size. well there not 19.5s but they will work until I can save to for 19.5s the chevy inners don't fit the dodge axle so I had to get dodge wheels.the outers where universal lug centric so they fit. 20211018_191800 by jarrod vanwinkle, on Flickr 20211018_202255 by jarrod vanwinkle, on Flickr Last edited by jarrodblake; 10-19-2021 at 12:17 AM. |
Tags |
air ride, c30, cummins, nv4500, ramp truck |
