Old 05-06-2021, 02:26 PM   #1
BBPanel
Anyone use OEM electric park brake
The E-Stopp system seems to get a lot of praise but they are certainly proud of their stuff. Thinking by now someone has probably used a oem system in their truck - would like to hear from those that might have done it. I don't know what the oem units look like or their dimensions so if anyone has info on that it would be appreciated also. Thanks. -Bob
BBPanel is offline   Reply With Quote
Old 05-06-2021, 06:18 PM   #2
slammed57
slammed57's Avatar
Re: Anyone use OEM electric park brake
Check my build page out. I did a electric e brake for around $60 if I remember correctly. page 12 post#284
http://67-72chevytrucks.com/vboard/s...662590&page=12
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 05-06-2021, 08:01 PM   #3
layinrocker65
layinrocker65's Avatar
I used some Tesla electric parking brake calipers.
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 05-06-2021, 09:30 PM   #4
BBPanel
Yes, I found one other example of using a linear actuator (which is essentially what E-Stopp is). Do you know if the actuator is worm gear drive?
I'm concerned what Plan B is if on the road and it won't dis-engage, I guess cutting or dismantling are the only choices.
Old 05-06-2021, 10:31 PM   #5
svr
svr's Avatar
I used a linear actuator also. Pulls cables on my 88 C4 rear. I made a turnbuckle style adjuster in the cables. If its stuck on i can reach under and loosen the adjuster.
57 short box, 235, T5, C4
http://67-72chevytrucks.com/vboard/s...d.php?t=739132
svr is offline   Reply With Quote
Old 05-07-2021, 08:31 AM   #6
slammed57
slammed57's Avatar
it looks to be a worm gear
My 57 current build
