Old 04-13-2021, 09:35 PM   #26
BIGglaSS
BIGglaSS's Avatar
Re: Lets get this LS 5.3 running!
I think I got this 95% figured out. Making another push to get this running soon!
I am planning to do a Wrangler fuel tank and blazer sending unit. I see most guys use the EP381 fuel pump. However, this Delco HP 10004 sending unit comes with a fuel pump.
https://www.rockauto.com/en/moreinfo...060579&jsn=481
Will this fuel pump work, or should I get the sender without pump and EP381?
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30
BIGglaSS is offline   Reply With Quote
Old 04-15-2021, 10:22 AM   #27
prodjay10
What kind of pressure is that putting out? If it’s for an ls based vehicle it’ll prolly work. Just gotta make sure it’s the right depth.
prodjay10 is offline   Reply With Quote
Old 04-15-2021, 12:13 PM   #28
BIGglaSS
BIGglaSS's Avatar
I pulled the specs for what vehicles the EP381 pump goes in. The pump in the Delphi unit is for the same vehicles as the ep381. Same specs. 32 gph, 60 psi. Going to give it a try.
Old 04-18-2021, 06:46 AM   #29
jjzepplin
jjzepplin's Avatar
Does the Wrangler tank have internal baffles?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-19-2021, 09:55 AM   #30
BIGglaSS
BIGglaSS's Avatar
Supposedly, yes.
Old 05-07-2021, 09:18 PM   #31
BIGglaSS
BIGglaSS's Avatar
Well, #$@&. Others that have used the wrangler tank say that it is baffled. They're NOT!
Now what? Does it really need a baffle? Is there a way to add one?
Old 05-08-2021, 02:13 PM   #32
jjzepplin
jjzepplin's Avatar
Well no serious experience other than reading. Baffles help with hard cornering and keep gas in the pump when the level gets lower. Some GM pumps recirculate fuel into a sort of cup at the bottom of the pump assembly so that the pump will have access to fuel. Hope that makes sense.
Old 05-08-2021, 04:56 PM   #33
LS short box
I've used non-baffled tanks on my early LS swaps. I just made sure I didn't run the tank too low. The down side to starving a fuel injected engine of fuel is they typically shut off like a light switch when the pick up is uncovered.
Old 05-09-2021, 10:55 AM   #34
clay68c10
clay68c10's Avatar
If the sender/pump assembly sits in a tub inside the tank bottom, then it’s fine. The tub will stay full of fuel. I’ve had my Jeep on plenty of off camber surfaces and it’s never starved for fuel.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 05-09-2021, 11:08 AM   #35
BIGglaSS
BIGglaSS's Avatar
There is no tub on the fuel sender. Originally, I have a camaro pump in a mustang tank that I got with this engine. However, I cant fit the filler tube under the bed floor. The reason I decided to switch to the wrangler tank was to use a remote fill tube mounted in the fender.
I'm thinking, either I use the mustang tank and raise the bed floor a few inches to cover the filler tube. Or, I attach a sump cup to the fuel sender.
I'm also thinking about using the evap system. I can't stand gas fumes in the garage. Also, with the mustang tank, and low filler, there is really no where to run a vent line higher than the tank.
Old 05-13-2021, 02:17 AM   #36
Low Elco
Lots of folks have been known to fab a tub around the pickup sock and zip it on.
Low Elco is offline   Reply With Quote
Old 05-13-2021, 11:37 AM   #37
michael bustamante
michael bustamante's Avatar
i did this exactly and it works great
1992 wrangler tank and 87 blazer sender fits right in
great looking truck. im jealous. how did the harness come out?
i have an untouched one for dbw units if you need it to start over (green blue)
1967custom
michael bustamante is offline   Reply With Quote
Old 05-15-2021, 10:46 PM   #38
jjzepplin
jjzepplin's Avatar
Exactly what did you do?
