05-09-2021, 04:53 AM | #1 |
How do I read the date codes on a starter?
05-09-2021, 05:44 AM | #2 |
Re: How do I read the date codes on a starter?
Probably first digit is year,
Then the second is a letter(they skip the letter I) Because it looks to much like a number. Then day of the month Example:9M15 would =December 15th 1969 A - January B - February C - March D - April E - May F - June G - July H - August J - September K - October L - November M - December .
05-10-2021, 02:15 PM | #3 | |
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
05-10-2021, 02:50 PM | #4 |
Keep in mind that unless you know for sure that a particular starter is original, all you are really decoding is when the casting was made. Most starters on older vehicles are rebuilt ones using a mix of original and new parts. Many have probably made several trips from vehicle to rebuilder and back to a different vehicle.
IIRC - the rebuilt starter on my C10 does have a AC-Delco stamping on the body but when I bought it, it was a mid level Autozone rebuild. |
05-10-2021, 03:05 PM | #5 | |
05-10-2021, 03:22 PM | #6 |
Whats your application? Model, engine size, transmission, etc
05-10-2021, 03:28 PM | #7 |
05-10-2021, 03:36 PM | #8 |
My book has this starter number for that truck application:1109065
Also used on 1978 truck 400 sbc and 1979 350's. Same one used on 1978 cars with 350s and auto trans, '79 passenger cars, '79 Corvette, Nova, 79-81 Camaro with 350/auto trans Looks like its obsolete and reman is probably your only option http://www.delcoremy.com/find-a-part...etails/1109065
05-10-2021, 03:44 PM | #9 | |
05-10-2021, 03:54 PM | #10 |
Catalog of Chevy V8 Engine Casting Numbers 1955-93 and stamped numbers
https://www.goodreads.com/book/show/...tamped-numbers Double checked the GM parts catalog too (you can download pdf copies here http://67-72chevytrucks.com/vboard/s...d.php?t=545416)
05-10-2021, 08:16 PM | #11 | |
thank you for the help. |
05-10-2021, 08:23 PM | #12 |
Just referencing my book of casting and stamped numbers.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com Last edited by MJN; 05-11-2021 at 08:31 AM. |
08-25-2021, 01:20 AM | #13 |
Wow! This has been most helpful. So 1109065 would be my starter. As for the date code is there anyway I could know what the original date code would have been? Perhaps that would have been on the build sheet.
