Old 04-15-2021, 11:11 PM   #6426
Gregski
Gregski's Avatar
Re: Restoring Rusty
ladies and gentlement... The Digital Cambermatic 3000
Gregski is offline   Reply With Quote
Old 04-15-2021, 11:18 PM   #6427
Gregski
Gregski's Avatar
Re: Restoring Rusty
and here it is in action
Driver side has 1.20° of Negative Camber which is OK(ish)
Texter side has 2.10° of Negative Camber which is Too Much
however now at least we know in degrees how much out of whack we are
Note: I believe back in the day the Manuals for these 60s and 70s vehicles read something like +1° or -1° of camber was acceptable, which is redunculous, you go ahead and set your driver side wheel to -1° and your passenger side to +1° and I'll meet you at the telephone pole
Old 04-15-2021, 11:22 PM   #6428
Gregski
Gregski's Avatar
Re: Restoring Rusty
so it was time to bust out the shims, and when it comes to Camber, don't over think things, first if you struggle with remembering which is Negative camber and which is Positive camber, just remember In and Out as in the top of the wheels lean In or the top of the wheels lean Out
and just use the alphabet trick
N in Negative comes before P in Positive just as I in In comes before O in Out
You're welcome
Old 04-15-2021, 11:26 PM   #6429
Gregski
Gregski's Avatar
Re: Restoring Rusty
remember we are focusing just on the passenger side, so here is what the current shimming situation looks like
and if all you are doing is addressing the Camber then always add or remove the same amount of shims to both the front and the back of the upper control arm
Note: there are more shims in the back of the upper control arm that is to set Positive Caster a topic for another day
Old 04-15-2021, 11:30 PM   #6430
Gregski
Gregski's Avatar
Re: Restoring Rusty
some shims come with a little hole in them mine did not, now they do
this makes it zip tie friendly and keeps the profanity down to a minimum
Old 04-15-2021, 11:32 PM   #6431
Gregski
Gregski's Avatar
Re: Restoring Rusty
mandatory stare and compare of the ol' analog Cambermatic 300 and the new and improved digital Cambermatic 3000 shown with the Pro Plus option second magnetic level attachment used to ensure verticability
Old 04-15-2021, 11:51 PM   #6432
Gregski
Gregski's Avatar
Re: Restoring Rusty
so adding two shims to front and back of the upper control arm got me in the OK(ish) ballpark with the same negative camber on both sides, I may revisit both sides after some shake down driving and see if I can get them both slightly under -1°
Old 04-16-2021, 06:44 AM   #6433
4u2nv
Re: Restoring Rusty
I like your method .
4u2nv is offline   Reply With Quote
Old 04-16-2021, 09:40 PM   #6434
Gregski
Gregski's Avatar
Re: Restoring Rusty
it's that time of year again...
Annual Seat Sale!
Old 04-17-2021, 10:16 AM   #6435
Wgesnerjr
Wgesnerjr's Avatar
Re: Restoring Rusty
Oooh!
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 04-17-2021, 01:50 PM   #6436
Gregski
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by Wgesnerjr View Post
Oooh!
You mean Oooh! Oooh! Oooh!
Old 04-19-2021, 10:41 AM   #6437
Wgesnerjr
Wgesnerjr's Avatar
Re: Restoring Rusty
You're right!!
I cant wait for a Gregski install write up on these!!
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 04-19-2021, 11:33 AM   #6438
Gregski
Gregski's Avatar
Re: Restoring Rusty
You're right!!
probly not what you had in mind, but her you go...
http://67-72chevytrucks.com/vboard/s...&postcount=525
Old 04-19-2021, 04:13 PM   #6439
LT7A
Re: Restoring Rusty
"you go ahead and set your driver side wheel to -1° and your passenger side to +1° and I'll meet you at the telephone pole"
Hahaha, good call. I like the tool you made and your process. Is Rusty getting some new shoes? I couldn't help but notice some white raised letters - well, blue at the moment.
Old 04-19-2021, 08:48 PM   #6440
Gregski
Gregski's Avatar
Re: Restoring Rusty
Rusty recently got sum, so I'm adjusting the camber to see if I can get more than 10,000 miles out of these, ha ha jk
the blue high heels in the pic were from my '54 they came off the front cause they were to wide at 245 micronmeters so I went with 215s
Old 04-21-2021, 11:10 PM   #6441
texxxan
texxxan's Avatar
Re: Restoring Rusty
Someone has been quite busy lately.
texxxan is offline   Reply With Quote
Old 04-22-2021, 02:25 AM   #6442
Schroedum
Re: Restoring Rusty
1984 C10 with cammed vortec 350
Schroedum is offline   Reply With Quote
Old 05-12-2021, 05:22 PM   #6443
Gregski
Gregski's Avatar
Re: Restoring Rusty
Finally it was time to replace them shift solenoids
Old 05-12-2021, 05:26 PM   #6444
texxxan
texxxan's Avatar
Re: Restoring Rusty
Don't forget the obligatory stare and compare.
Old 05-12-2021, 09:32 PM   #6445
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
Make sure the internal harness isn't leaking fluid around the pins through the connector.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
hatzie is online now   Reply With Quote
Old 05-13-2021, 12:58 AM   #6446
Gregski
Gregski's Avatar
Re: Restoring Rusty
you talking about the big round shower head style one?
Old 05-13-2021, 01:02 AM   #6447
Gregski
Gregski's Avatar
Re: Restoring Rusty
so this is where the solenoids live, I know it's upside down, but better than nothing
the one on the left (driver side) is the 1-2 and the one on the right (passenger side) is the 2-3
but they are both identical same part number
Old 05-13-2021, 01:07 AM   #6448
Gregski
Gregski's Avatar
Re: Restoring Rusty
yes this transmission has a drain plug and yes the P.O. (pronounced: "guy who had it before me") tightened it as hard as she could plus a quarter turn, and stripped the head of the bolt so that I had no chance of getting it out
but since this was my first gear box with a drain plug I was determined to have one that works, even if it took me 3.5 hours to get it out
Old 05-13-2021, 01:10 AM   #6449
Gregski
Gregski's Avatar
Re: Restoring Rusty
so the first test I did (right or wrong) was the Click Test, basically you hook up a solenoid to a car battery and listen to see if it clicks
the 1-2 solenoid had a loud(er) click than the 2-3 one so I think that's the one we are trying to replace
Old 05-13-2021, 01:14 AM   #6450
Gregski
Gregski's Avatar
Re: Restoring Rusty
the second test and the more official one was the Horse Shoe Test
this is where we put our Multimeter on the horse shoe icon and check for The Reistance
the 1-2 solenoid measured at 23.1 ohms
the 2-3 solenoid measured at 23.3 ohms
both seemed within range, remember if you know nothing but have two of something, compare them
then here's how the new ones tested
the new 1-2 solenoid measured 25.6 ohms
the new 2-3 solenoid measured 27.7 ohms
