05-15-2021, 01:48 PM | #1 |
The Older Generation
Dana 60 3.54 in the '68 Chevy C20
Well, I finally finished up the Eaton HO52 / Dana 60 rear end swap. The Dana was a coil spring rear end so that made the swap pretty easy. I had a few delays but it worked out good. I didn't have to cut my drive shaft. There are two different length rear shaft sections. The Eaton was 35 inches long and I had 4 or 5 different shafts I had saved and one of them had a rear section that was 33 inches long, it fit perfect. The front section of the original shaft used the small "U" joint at the carrier bearing and the front of the 33 inch rear shaft used the large "U" joint. All I had to do was purchase a Precision Brand #348 Combination "U" joint, and everything fit right together. It made a world of difference in the driveability of the truck. Now I can hear the radio over the engine..... Part number list is in post below All of the pictures are of the Eaton rear end as I was taking it out. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 05-17-2021 at 05:09 PM. |
05-15-2021, 02:06 PM | #2 |
Re: Dana 60 3.54 in the '68 Chevy C20
Thanks for the post! We need to see more of these simple swaps that involve little or very little modifying. Or we could wait and wait and wait till the aftermarket decides to manufacture a HO 52 3.54 ring and pinion set for '48 thur '72 Chevy C 20's. Those 16.5's with correct era caps look great!
05-15-2021, 03:11 PM | #3 |
Roadtrip!
That should be a great upgrade for drivability.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
05-15-2021, 08:06 PM | #4 | |
I need to get some stock type lug nuts before I can put the rear caps on. The ones I have on there are too long. Thanks Eric. I drove it to town and back this morning and it ran really good. LockDoc
05-16-2021, 08:21 AM | #5 |
You're a half a turn ahead now. Let it roll!
I wish someone would make ring and gear sets for HO52s while there are still so many out there. It's such a great rear. Brakes are no problem as long as there are 14-bolts all over the place. A simple swap. Someone (Patrick's) made gear sets for the HO32/33s way back in the '80s to help the '50s 1/2 tons run hiway speeds. As it is our choice is rear end swapping. That's why I keep a collection of rears.
05-16-2021, 08:19 PM | #6 |
DND Trucks
Great job Leon! Was the HO52 a 4.57 open rear
05-16-2021, 09:36 PM | #7 | |
Not sure at this time Dave. I couldn't find any numbers on it and I haven't removed the cover yet. LockDoc
05-17-2021, 04:57 PM | #8 |
Here are the different part numbers for the Dana 60 coil spring rear end. Brake Shoes = Bosch BS419R Hardware Kit = Raybestos H7128 Wheel Cylinders = CENTRIC 13462015 Rear Right; Rear Leaf springs CENTRIC 13462016 Rear Left; Rear Leaf springs Yes, I know they say for Leaf Springs but they fit the coil rear end and were exactly the same as the ones I took off.... ------------------------------------- I ordered these wheel cylinders on the first try and they were the wrong ones. CENTRIC 13466009 CENTRIC 13466010 LockDoc
05-18-2021, 07:45 AM | #9 |
...Thanks again for including the part numbers here.
('interesting' that the wheel cylinders that didn't fit, are listed for coil spring) Did you by any chance replace the wheel seals? (I ordered Timken 455860 from RockAuto, hoping they are the right ones.) Thanks again, Kevin
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
05-18-2021, 09:40 AM | #10 |
6>8 Plugless........
Nice swap. The D60 coil rear ends are probably a little more rare aren't they? Most were in leaf spring trucks from what I've seen because they were camper special big block trucks. I've seen pics of coil spring 6 lug D60s in these but never found one in the wild yet.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-18-2021, 09:52 AM | #11 | |
My truck came from the factory as Cab & Chassis, with Utility body installed (most likely from day one) with it's original 396, NP435 4-speed and a Dana60 Coil spring rear. Along with Special paint, I guess I was lucky to find it : ) https://imageevent.com/hvclassics/au...=1&n=1&l=0&z=9
05-18-2021, 10:24 AM | #12 | |
05-18-2021, 12:17 PM | #13 |
From the research I did a while ago, big block trucks got the D60. I'm guessing that was because the Eaton's did not have a 3.54 gear ratio available.
05-18-2021, 12:37 PM | #14 | |||
LockDoc
05-19-2021, 03:36 AM | #15 |
Location: Herculaneum MO (20 minutes south of St. Louis
Please someone correct me if I'm wrong but I believe Centric 123.66024 is the correct drum for the Eaton HO52. Multiple vendors list them as in stock.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
05-19-2021, 10:45 AM | #16 | |
LockDoc
05-19-2021, 02:09 PM | #17 |
If we assume that only the Eaton HO52, and Dana 60 was on those trucks (C20), that is likely true. Centric and Rock auto list two drums 123.68001 appears to be for the Dana 60 (12 inch dia), and 123.66024 shows 11.2 diameter. If in doubt check diameter of your drums. I made the mistake of ordering a set of shoes from Rock Auto for "coil spring" rear axle, and appears I have a set of Delco shoes for the H052, and cannot use them. Probably also why the brake hose going to the rear axle also would not fit, but I "engineered" an adaptor fitting and am using it anyhow. Hope this helps, but I would go by drum diameter and cross reference the part as necessary. It would seem just going by coil or leaf springs is not a good indicator as they apparently built coil and leaf spring axles in both Eaton H052 and Dana 60, and they are significantly different. I am learning as I go but it is expensive. Need a set of AC Delco shoes for the H052??
05-19-2021, 02:34 PM | #18 | |
05-22-2021, 12:13 PM | #19 |
I believe the odd ball bigger drums came out on '72 only 3/4 tons. There is the possibililty that '68-'71 drums are one part # and the '72 drum is the other another part #. In '73 GM abandoned both axles for their own inhouse corporate axles.
05-22-2021, 06:33 PM | #20 |
Just received Napa UP UP419R Brake shoes yesterday, and as someone else posted both front and rear shoes (have not figured out which are supposed to be rear facing) are the same length. They are correct for the 12 inch drum and 2.5 inch width, but I have never seen this. Normally the rear shoe lining is longer. Not so here. These are riveted relined, labeled "made in china". I am done testing, and these will go on the truck, as this truck will not see heavy use or high miles, but am disappointed, as they have far less lining than what came off. I will try to get a photo of old and new when I attempt to figure out which is which -- the linings are not centered on the metal that the lining is riveted to, which leads me to believe it does matter on placement. Perhaps FLT FT419R (fleet) would have been correct???
05-22-2021, 07:35 PM | #21 |
short shoe forward
05-22-2021, 07:43 PM | #22 |
agree, but what in my case where both are same length?
05-22-2021, 07:44 PM | #23 | |
I don't know, It's hard to tell by the pictures. LockDoc
05-22-2021, 07:46 PM | #24 |
It looks like one shoe has the lining closer to the top and one shoe has the lining closer to the bottom on each side..... LockDoc
05-22-2021, 07:58 PM | #25 |
