Old 05-18-2021, 12:49 PM   #26
Asshat
Asshat's Avatar
Re: Quick question on fitment - power steering gear
Originally Posted by The Rocknrod View Post
If that's your box in post 21 then yes you need the inverted flare fittings. Same type I used.
This pressure hose does fit this pump, however, it looks like a regular flared fitting.
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 05-18-2021, 01:08 PM   #27
The Rocknrod
Moderator
The Rocknrod's Avatar
Yep that's inverted flare. In my notes I have me using: Pressure - Edelmann 70917. I made the return line.
But I have a small block chevy, short water pump brackets.
Old 05-18-2021, 02:08 PM   #28
Asshat
Asshat's Avatar
I will get one of those and try it.
How did you make the return hose?
Would I need an inverted flare tool?
292, 4-speed
Old 05-18-2021, 02:17 PM   #29
The Rocknrod
Moderator
You know I think I found the "pig tail" from the box end from inline tube. It didnt fit very well so I had to adjust the bends, so much so I creased the tube. So I had extra 3/8 tube around and made my own. If I had to do it over again I'd use copper nickel. Yes you have to have a crimper. I have a hydraulic unit I purchased on a previous build, love it. My hose section (from my notes) is Edelman 71236.
Old 05-18-2021, 02:18 PM   #30
Asshat
Asshat's Avatar
You know I think I found the "pig tail" from the box end from inline tube. It didnt fit very well so I had to adjust the bends, so much so I creased the tube. So I had extra 3/8 tube around and made my own. Yes you have to have a crimper. I have a hydraulic unit I purchased on a previous build, love it. My hose section (from my notes) is Edelman 71236.
71236 is the return hose?
292, 4-speed
Old 05-18-2021, 02:22 PM   #31
The Rocknrod
Moderator
Yes I was discussing the return hose.
LMC shows the pig tail section item #6 here: https://www.lmctruck.com/1967-72-che...ing-components
Old 05-18-2021, 02:22 PM   #32
Asshat
Asshat's Avatar
Can you post a pic?
292, 4-speed
Old 05-18-2021, 02:54 PM   #33
The Rocknrod
Moderator
Can't seem to find any right now.
Old 05-18-2021, 03:44 PM   #34
Asshat
Asshat's Avatar
So, if my 3/8 tube fitting is 0.61" (OD), would this be a 7/16 fitting?
And, the tube in the pic is not called an inverted flare, is it?
292, 4-speed
Old 05-18-2021, 03:48 PM   #35
The Rocknrod
Moderator
Throw that away, its not for your box.
The picture in your post 26 is the type if fitting.
Old 05-18-2021, 04:04 PM   #36
61K10
61K10's Avatar
this one--goggle power steering return line fittings----------
one part# edelman 39135
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-18-2021, 04:46 PM   #37
Asshat
Asshat's Avatar
Ok. Thanks.
Just ordered this one.
292, 4-speed
Old 05-18-2021, 04:58 PM   #38
The Rocknrod
Moderator
A 3/8 Tube flare nut (if your going to make your own) is 5/8-18 threads - 1st pic.
The screwed up tube I made - 2nd pic.
Old 05-21-2021, 03:06 AM   #39
Asshat
Asshat's Avatar
Well, for the bracket and power steering pump installed; just gotta get a belt that will fit.
Hoses seem to fit well too.
292, 4-speed
