Old 05-29-2021, 02:51 PM   #6476
Gregski
Gregski's Avatar
Re: Restoring Rusty
WE NOW INTERRUPT THIS TRANSMISSION REPAIR TO BRING YOU YET ANOTHER STEEL BRAIDED LINE FAILURE !!!
This is now the third line that has failed on me. And I'm not a smart man but when the low pressure side fuel line fails, we know we have a problem. Last time the high pressure side failed and a transmission line failed which I assumed was the high pressure side as well.
What sucks about this is that it is a return home run to the fuel tank, so we got to drop the tank to R n R it, super!
FYI it actually failed above that hose clamp at what appears to be a gentle swoop and not a pinch or kink or it rubbing on anything, and I am just pointing to the line which has the leak just so I know which one to replace, ha ha
Fun Level = * please see the cuss jar *
Gregski is offline   Reply With Quote
Old 05-30-2021, 11:11 AM   #6477
Gregski
Gregski's Avatar
Re: Restoring Rusty
so after fighting with the steel braided lines in an effort to just replace the last 3 feet to avoid dropping the tank I decided to ditch the steel braided hose all together, I never wanted to run steel braided lines to begin with, they are more show than go, and if it's good enough for Holley and their EFI kit it's good enough for me, especially for the low pressure return line
and yes we are using a reinforced fuel injection hose and not just a regular soft rubber fuel line
by the way slipping on AN fitting on to this rubber hose is 7.83 times easier than slicing your thumbs up on the steel braided ones, so there's that
and this is my daily driver so I need to get it out of the garage
Old 05-31-2021, 11:02 AM   #6478
Gregski
Gregski's Avatar
Re: Restoring Rusty
so I go to put the fuel line back on the Summit brand barrel style inline fuel filter (I had to remove it to get to the other line) anyway I get the obligatory gasoline waterfall down my sleeve, so I think what the hewk, and I remove the filter to examine it, and sure enough that flimzy rubber O-ring has failed and the filter now leaks like a sieve
now you know how I feel about aftermarket parts, well I went with this one cause it has 6AN standard male screw on ends unlike the OEM one which is metric female, but I will be going back to the OEM with adapters, shieshs this quick RnR is turning into a Footspagh right quick
and take a look at that "filter" it is a wire mesh the size of a quarter, that's it, that's your filter, can you say Good Bye to your injectors?!
Old 05-31-2021, 11:55 AM   #6479
Gregski
Gregski's Avatar
Re: Restoring Rusty
and this is what a civilized fuel filter looks like, this one happens to be a Product of the USA from AC Delco (lets pause in appreciation for a minute)
some will have an arrow marking the direction of the fuel flow, that is important, some of the aftermarket ones can be installed in either directions but once installed you should not flip them around
if the filters are not marked I noticed the welded end is the outlet side and the nicely curved smooth end is the inlet side
Old 05-31-2021, 11:57 AM   #6480
Gregski
Gregski's Avatar
Re: Restoring Rusty
as mentioned before these AN to Metric adapter doodads are required to plumb the OEM fuel filter and this is where you will spend 73.8 percent of your time whilst carrying out an LS Swap Operation aka LSSO hunting down adapters, converters, and flux capacitors
Old 05-31-2021, 03:20 PM   #6481
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
That hose says SAE J30R7. That's just plain old fashioned carburetor fuel hose. Same as GM and others used for carbureted fuel systems through the end of the age of the carburetor. Max running pressure is 50 PSI, intermittent operating pressure is 75 PSI for Continental hose but not all hose meets this spec, burst pressure is 250 PSI. That's for NEW hose.
The SAE has actually downrated J30R7 to use as EVAP hose but it's still just fine for lower pressure non-fuel-injected vehicles. I use it on my ATV, Motorcycle, riding mowers, and other small engines that don't use Vinyl hose.
You want an operating envelope cushion to deal with aging. The actual operating pressure envelope can be reduced quite a lot by age especially in higher temperature environments with higher ozone levels like West Coast cities. If your operating pressures are right on the ragged edge of maximum you won't get much life out of it.
SAE J30R9 hose is the stuff you want for TBI and TPI fuel systems. It's rated for higher operating and burst pressures and is less vapor permeable than the old J30R7 hose. It's what GM originally used on the TBI and TPI fuel injection systems before they went to Vinyl fuel lines in the mid 90's.
My first choice in clamps are constant tension spring band clamps that everyone seems to hate. They maintain constant tension over a wide temp range without over tensioning and smashing plastic hose barbs or crushing the hose itself and loosening up like worm clamps seem to do. German Fuel Injection clamps are a close second choice.
If you're an SAE member this is the link to the J30 fuel hose standards. It's some pretty dry reading.
https://www.sae.org/standards/content/j30_199806/
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 05-31-2021, 03:33 PM   #6482
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
I believe that AC Delco filter uses a special GM Fuel line fittings. The end is straight with a ring crimped into the tube that the ferrule rests against with a shoulder for the O-ring.
This guy shows how to make GM Fuel Line crimps and Jiffy Tite transmission & oil cooler line crimps.
Old 05-31-2021, 03:37 PM   #6483
Gregski
Gregski's Avatar
Re: Restoring Rusty
Thanks, I am actually running this 30R14T2 on the high pressure side I believe it's rated for 225PSI
Old 05-31-2021, 03:53 PM   #6484
Gregski
Gregski's Avatar
Re: Restoring Rusty
You all won't believe this, so I button everything up and turn the key to prime the fuel pump and I hear a gush of fuel hit the pavement, I'm like Noooo can't be
Yup, a fourth line has failed on me, this time the high pressure hose that runs from the fuel tank to the fuel filter, and I did not touch this line!!!
It is so UNBELIEVABLE I made a video for it, so avoid this AMAZON steel braided hose at all costs
https://www.youtube.com/watch?v=dwd68TfculU
Old 05-31-2021, 04:17 PM   #6485
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
SAE J30R14 is the new J30R7. It's an updated low pressure fuel hose spec with the lower vapor permeability of J30R9 and better ethanol breakdown resistance in the spec with the lower operating and burst pressures of the J30R7 hose. Most manufacturers already met or exceeded the ethanol resistance spec in their J30R7 offerings but not the vapor permeability ratings.
The stuff you want on the pressure side is still SAE J30R9.
Gates used to have a comparison tool but I can't find it.
Old 05-31-2021, 04:22 PM   #6486
Gregski
Gregski's Avatar
Re: Restoring Rusty
Are you serious?
Old 05-31-2021, 04:35 PM   #6487
rgunlock
rgunlock's Avatar
Re: Restoring Rusty
That is definitely unbelievable! Hate to say it, but if you haven't already I'd replace every last bit of that braided hose on the truck. That could have had a VERY bad ending!
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 05-31-2021, 04:36 PM   #6488
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
Sure am.
https://www.underhoodservice.com/cor...-installation/
J30 is the SAE fuel line standard with R numbers for specific types.
  • R7 is emissions hose. Used to be low pressure fuel hose but high vapor permeability likely makes it illegal in California for fuel hose.
  • R9 is high pressure low permeability Fuel Injection hose
  • R10 is high pressure in tank fuel hose. Submersible fuel line for in tank fuel pumps. Don't use this stuff out of the tank as the jacket isn't compounded for operation in air.
  • R14 is low pressure low permeability fuel hose. Likely released to deal with tightened air quality standards.
Ignore the comment in that article about using J30R9 fuel hose for oil. J30R9 doesn't have the temperature rating for an oil or transmission cooler. It might work for cold oil but not for an oil or transmission cooler at operating temp. SAE J1019 hose is actually designed for that job.
Old 05-31-2021, 04:46 PM   #6489
Gregski
Gregski's Avatar
Re: Restoring Rusty
Sure am.
I hear you brother, I just can't find any J30R9 locally they all point at the R14 just like the dude at the NAPA counter sold me and I told him what I was doing and I wanted the high pressure stuff
Old 05-31-2021, 04:55 PM   #6490
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
Yeah. That's one of the reasons I educate myself before getting stuff from the parts guys.
They mean well but they'll also offer you fuel hose for transmission coolers and regular fuel hose for in tank fuel pumps.
You might want to get the spec sheet for the exact hose you have. Manufacturers can and often do exceed minimum specs.
Old 06-01-2021, 10:18 AM   #6491
Gregski
Gregski's Avatar
Re: Restoring Rusty
so I wrote to the seller on Amazon since I bought three hoses from them over the last two years, and I sent them pics of my hose failures and the link to this video, I was not rude, I was honestly concerned for other peoples safety, and they kindly replied and promised a full refund
Old 06-02-2021, 11:23 AM   #6492
Rich84
Rich84's Avatar
Re: Restoring Rusty
"Hope nobody hurts"..
I used junkyard factory hard lines with a small piece of rubber at the sender with double FI clamps.
Rich84 is offline   Reply With Quote
Old 06-02-2021, 02:37 PM   #6493
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
If you bead the end of the tube you don't need to double clamp it.
The ATS Parker Beading Tools are darn nice but the price is pretty dear. Here they are FWIW
I have seen similar bead forming tools made from modified pipe cutters. Depends on your tooling availability and skill set.
The Earls tube beading tools work fine for a few tubes.
Old 06-02-2021, 06:20 PM   #6494
SCOTI
SCOTI's Avatar
Re: Restoring Rusty
http://www.youtube.com/watch?v=nxZTe2Rs-X8
http://www.youtube.com/watch?v=O9hTleI8a9I
Many of us use steel tubing for various lines. Not sure if that EZ Beader does just aluminum or if it can do steel as well.
For the part-time/shade-tree builders, brass compression fittings also work as an easy way to get it done on steel tubing w/o a bead forming tool. Put a ferrule + the male/female portions of a brass fitting together on the tube. Tighten the male/female portions to locate & 'crimp' the ferrule in place. Loosen the male/female portions. Then grind/cut the female portion off as needed using an angle grinder.
The crimped ferrule is left on the tube & the hose can be forced over it w/a single worm gear clamp to keep it firmly in place.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-02-2021, 07:38 PM   #6495
mongocanfly
mongocanfly's Avatar
Re: Restoring Rusty
dang...that could have been disastrous
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-03-2021, 08:34 AM   #6496
daddyjeep
daddyjeep's Avatar
Re: Restoring Rusty
I always just do a bubble flare with a normal cheap flaring tool. I even did a video on it a few weeks ago when I made new trans lines.
https://www.youtube.com/watch?v=ASeGM7FWQng
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 06-03-2021, 08:42 AM   #6497
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
I would think they could do thin wall Ni-Copp and steel brake and fuel line. Just take smaller bites at a time and lube it.
Interesting idea using ferrules as a small tube bead.
I stay far away from worm clamps on hoses smaller than 1". I use constant tension spring clamps and fuel injection clamps for smaller hoses.
I'm moving away from worm clamps to spring clamps on larger stuff like radiator hoses at this point. Toyota has been using them for a couple decades and they don't leak. I hate the locations the thoughtless line workers tend to put the ears at the factory, and I'm not the only one that does, but they can be moved to a location that's accessible so they work for fine the rest of the life of the vehicle.
Old 06-03-2021, 09:09 AM   #6498
SCOTI
SCOTI's Avatar
Re: Restoring Rusty
Much agreed on the worm clamp avoidance when/where possible & I prefer the use of the FI style clamps. I haven't found a good local source for them in a high quality material & I have readily available access to SS worm gear hardware so it's more of a default thing.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-06-2021, 11:51 PM   #6499
Gregski
Gregski's Avatar
Re: Restoring Rusty
got sum fuel filter adapter that don't suck! so that I don't have to use 9 yards of thread tape to get those black ones above to stop leaking
Old 06-07-2021, 07:56 AM   #6500
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
Knowing what the proper fuel line ends should look like helps a great deal.
Russell makes some good hot rod stuff. I've used their drilled and 1/8NPT threaded banjo bolts to add an oil pressure gauge to my ATV.
