Old 06-07-2021, 12:10 PM   #1
rnrdthefox
Fold down license plate holder
I'm looking for recommendations for a solid fold down license plate holder that would work with the TripPlus Automotive role pan. From the location of the filler neck, it looks like the hole behind the license plate will be at the top - center area of the opening where the license plate will mount. Thanks.
rnrdthefox is offline   Reply With Quote
Old 06-07-2021, 02:22 PM   #2
youngrodder
youngrodder's Avatar
Re: Fold down license plate holder
A lot of cars from the 80's like a Chevy Caprice had fold down license plates. I used one on my last build (48 truck) with a roll pan.
I used one like this from eBay. It worked great.
https://www.ebay.com/itm/35250737815...rd!49088!US!-1
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 06-07-2021, 02:36 PM   #3
rnrdthefox
Thanks. The holder on Ebay looks like it mounts at the bottom correct? I'm concerned the area where the bracket mounts isn't big enough for that bracket. The dimensions for the area is 13" wide and 5.25" tall. My CO license plate is 6" tall so if the bracket is roughly the size of the plate, it will hang down below the edge of the roll pan too far to bolt it on? Did your roll pan have the same dimensions?
Old 06-07-2021, 03:09 PM   #4
youngrodder
I'm pretty sure you can set them up as flip up or fold down. I don't recall the dimensions of my rollpan . You can trim it to fit I bet.
Marc
Old 06-07-2021, 03:13 PM   #5
rnrdthefox
Marc
Ok. Thanks. I need it to fold down or else it will be hard to use I think.
Old 06-07-2021, 03:25 PM   #6
youngrodder
I later remade mine out of a flat plate of 1/8" steel with a small hinge at the bottom. I added magnets to the upper corners to hold it closed to the roll pan. I don't recall why I later made my own. That might be better than modifying an off the shelf solution.
Thank you
Marc
Old 06-07-2021, 06:02 PM   #7
mr48chev
mr48chev's Avatar
Note I had to correct this as I was way off>>> ( don't think any 80's cars still used the behind the plate gas filler. ) it looks like a lot of GM rigs used the behind the plate gas filler a lot longer than I remembered.
Some of the aftermarket ones I am finding that cover hidden hitches say that they are pretty flimsy.
Not as cheap as the aftermarket ones but this 69 Camaro unit should work pretty well.
https://www.ebay.com/itm/5Pc-69-Cama...8/163600195481
Summit has it for 23.99 rather than 39.00 https://www.summitracing.com/parts/GMK-4012-885-68
My ongoing truck projects:
Old 06-07-2021, 07:14 PM   #8
rnrdthefox
Originally Posted by mr48chev View Post
I don't think any 80's cars still used the behind the plate gas filler.
Thanks for the reply's. This is the one I ordered ( I think )
Old 06-07-2021, 07:20 PM   #9
mr48chev
mr48chev's Avatar
If you ordered an oem style one the main difference might be the locations of the mounting holes between models of vehicles. When you are drilling your own that is a non issue.
Old 06-08-2021, 12:37 PM   #10
joedoh
joedoh's Avatar
caprice used a folding license plate for gas filler 77-90
https://www.ebay.com/itm/1977-1990-C...-/133399641348
Old 06-08-2021, 01:45 PM   #11
mr48chev
mr48chev's Avatar
I'm going to have to back up and say that they used them a lot longer than I thought. My wife had a 79 Caprice for several years.
Old 06-08-2021, 02:06 PM   #12
youngrodder
Weird...I heard that somewhere before... ha ha
Marc
Old 06-08-2021, 04:30 PM   #13
1project2many
G-body also had rear fill tank fill w/ fold down plate. 1970 - 1988.
1project2many is offline   Reply With Quote
Old 06-08-2021, 07:57 PM   #14
rnrdthefox
Thanks for all the comments!
Old 06-08-2021, 09:06 PM   #15
e015475
e015475's Avatar
Late, as usual, but here's mine.
I think the holder is from a G2 Camaro. I weakened the spings so that the license plate would lay horizontally while I filled the tank - I remember fighting with them and trying to wedge the gas cap to hold it open.
The magnets sit where the rubber-bumpers would be on the Camaro. I had to play with it a little to get the plate to be a uniform distance from the roll pan.
The lights are from Kuryakin (I see I didn't hook up the ground - added that to my list)
e015475 is offline   Reply With Quote
Old 06-08-2021, 10:01 PM   #16
rnrdthefox
Thanks for the reply. I think that's the holder I ordered. The magnet idea I like and you are the second person to mention it. I looked at Kuryakin. Looks like nice stuff. What lights are your referring to? Are those screw in lights holding the plate? If so, that's cool and do you have the part number? Also, is that a rubber boot around the opening or just a rubber strip?
Old 06-09-2021, 09:03 AM   #17
e015475
e015475's Avatar
Yes, the license plate is held on with these Kuryakyn led bolts-
https://www.kuryakyn.com/products/52...te-bolt-lights
The edge of the hole for the filler neck is some stuff called "trim loc", not a rubber boot
Old 06-09-2021, 05:06 PM   #18
rnrdthefox
Awesome. Thanks
