06-20-2021, 01:19 PM | #76 |
Re: 2wd swap
I liked the look of OE sized front rotors in 18" wheels & the HD drums in 20's. I had that combo on my old 74 & thought the proportions looked fine (= WTF out of place).
07-02-2021, 11:24 PM | #77 |
At the body shop.
Re: 2wd swap
It's going together with the parts we have. If it stops weird I'll put the slotted stuff on my 73 and do something different on the k5
Was looking at afco calipers 1.25 rotor 4 piston deal.
" That didnt make it any newer " " Dont antique the equipment " |
07-03-2021, 01:01 AM | #78 |
Re: 2wd swap
I imagine it will stop just fine.
07-03-2021, 02:05 AM | #79 |
At the body shop.
Re: 2wd swap
Looking at something like this
07-03-2021, 11:44 AM | #80 |
Re: 2wd swap
Just need to calc the dual smaller pistons vs. a D52 big piston & see what difference there is.
07-04-2021, 06:14 PM | #81 |
At the body shop.
Re: 2wd swap
Happy 4th of July
Some more mock up stuffs These 20's don't look to bad on my pos either
07-05-2021, 02:12 AM | #82 |
Re: 2wd swap
Not bad @ all.
07-05-2021, 02:59 AM | #83 |
At the body shop.
Re: 2wd swap
Big moment this evening.
Didn't lay frame by about 1" but figured that after we didn't get the 18" wheels
07-05-2021, 10:58 PM | #84 |
At the body shop.
Re: 2wd swap
Oof I likey
07-13-2021, 03:20 AM | #85 |
At the body shop.
Re: 2wd swap
Bag plate questions.
Bolt bag to plates then bolt the plate to crossmember? The fit seems kind of sloppy
07-13-2021, 09:40 AM | #86 | |
Re: 2wd swap
Some plates I've seen are shorter & don't make it to the area of the curve so it just depends on the plates. Either works. I get the plates bolted in place on the outside perimeter of the x-member. Then get the lower arm w/bag bolted in place. This allows the bag to be optimally placed in the a-arm pocket/area. Then I use a template that's reference marked from the bag for the orientation of the top mounting hardware hole locations.
07-14-2021, 09:39 PM | #87 |
At the body shop.
Re: 2wd swap
I'm thinking we're gonna cut the bag plate to fit in the spring bucket hole and weld it in.
Poke 2 holes in the top of the spring bucket for a socket with 2 studs in the air bag.
07-19-2021, 12:43 PM | #88 |
Re: 2wd swap
Its hard to tell what it is but is that a piece of tube welded to the top of the c notch?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
07-19-2021, 01:01 PM | #89 | |
Re: 2wd swap
I did something similar to my 99 OBS to retain as much of the uncut OE rail strength.
07-19-2021, 02:26 PM | #90 | |
Re: 2wd swap
Just make sure you are able to seal it up well so it doesnt build up a bunch of moisture and rust out.
07-19-2021, 03:03 PM | #91 | |
Re: 2wd swap
My logic is if water can get in there, so can air. I stitch welded mine so I'm not worried in my Southern spot on the map but it is something to keep in mind.
07-19-2021, 04:42 PM | #92 | |
At the body shop.
Re: 2wd swap
Baby step notch if you will
07-20-2021, 12:37 AM | #93 |
At the body shop.
Re: 2wd swap
Its stitched in and if it sees any water I'd be surprised. That's what a daily beater is for.
07-23-2021, 09:20 PM | #94 |
At the body shop.
Re: 2wd swap
Floor is going to get hacked now. Ha
Diff is hard in to it. Axle tube is still 6 inches from the floor yet. And a looks like a driveshaft tunnel maybe required
07-23-2021, 09:59 PM | #95 |
Re: 2wd swap
Sweet jeezus. Looking nice....
07-24-2021, 12:36 AM | #96 |
At the body shop.
Re: 2wd swap
Thanks, Jay had a similar reaction.
Now to un bolt the floor and raise it. Or cut the floor and quarters. I think the tubs alone are high enough but where the quarter bolts to the tub is in the way.
07-24-2021, 03:20 PM | #97 |
Re: 2wd swap
From the couple of burb threads I've watched on here, I believe you are correct (floor & quarters are the initial limitations).
07-24-2021, 04:40 PM | #98 |
At the body shop.
Re: 2wd swap
Good thing it's not a last year 2wd jimmy or anything.
Time to break in our new plasma Cutter
08-03-2021, 04:16 PM | #99 |
Re: 2wd swap
looking good
1995 k3500 cclb srw 6.5 turbo diesel. The lessons that hurt are the lessons that teach. There is always a price to pay. You are free to make any decision you want. You are not free from the consequences. |
08-04-2021, 10:20 AM | #100 |
Re: 2wd swap
On my 78 I raised the floor 3 inchs and there was one piece of the tunnel I had to cut out just behind the seat. Looks likes a cross brace I replaced the whole floor as was rotten in all 4 corners but made the floor removable just in case. Also with the raised floor I could run full exhaust, was too loud for me even with quiet mufflers. Hope it helps.
