06-22-2021, 09:58 PM | #1 |
aftermarket heat and ac
I'd like to put ac in my 64 gmc. In the process I'd like to get a unit that has both heat and ac. I have just the basic heater and having to use defrost with the heat on isn't always ideal. Who has done this and are you happy with it?
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
06-23-2021, 12:53 AM | #2 |
Re: aftermarket heat and ac
Vintage AC
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
06-23-2021, 08:25 AM | #3 |
Junior Member
I used Auto Classic Air for both the '64 panel and the wife's '61 Apache. They provided a complete system with good instructions. If I do another conversion, I'll use them again.
06-23-2021, 11:38 AM | #4 |
I have the Old Air "Hurricane" heat/AC system in my 66 for years now and it has performed flawlessly. It does a great job of heating/cooling my large Suburban and the fan is very powerful. They offer vehicle specific systems or universal. The vehicle specific systems fit nicely and appear stock. Their support/service has been very good over the years when/if I had questions or needed to troubleshoot anything.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
06-23-2021, 09:46 PM | #5 | |
06-23-2021, 10:38 PM | #6 |
I have a Vintage air "sure fit kit" in my '66. I have regularly driven it in ambient temps around 110 degrees and still stay rather comfortable. Is it late model Silverado comfortable at those temps? No, but its decent. However, when outdoor temps are more moderate like in the 90's it's very comfortable. As for the heat/defrost part, it does work but I don't often need it. The a/c compressor runs on defrost because the unit only uses recirculated air.
I find the fan is a bit loud but I have tinnitus pretty bad and get irritated with noise anyhow so others may find it to be fine. (It's probably also par for the course when the fan is above the passenger's feet.) I think the key to any of these systems is to have good insullation on the floor and firewall (with no open gaps or holes) and quality weatherstrip. Also be prepared to upgrade your cooling system. I had to get a better radiator and upgrade my fan to an 18 inch 5 blade clutch style. Edit: one last detail...my truck is light colored. I think a dark truck would be an oven in my climate no matter what. Last edited by AcampoDave; 06-23-2021 at 10:44 PM. |
06-23-2021, 11:25 PM | #7 | |
https://www.oldairproducts.com/produ...defrost-system
06-24-2021, 08:53 AM | #8 |
I have had Old Air Products since about 2001, has always worked flawlessly and has only needed periodic recharges.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-24-2021, 09:09 AM | #9 |
Karl, What engine are you using? IF a 305-V-6 you will need to custom make a set of brackets to hold the compressor in the block, no one makes one. I have one that I will use in the future but maybe have a copy made at a local shop.
http://s1299.photobucket.com/user/jb...23904108567829 |
06-24-2021, 09:38 AM | #10 |
i have a 383 in it. doing a serpentine belt set up soon. have most the parts now
06-24-2021, 10:29 AM | #11 |
Also make sure you have an alternator that can handle the increased amperage (the AC/Heat/Defrost fans are a big draw) especially if you also have a stereo, electric cooling pusher/puller fans etc.
06-24-2021, 07:19 PM | #12 |
I'm dropping my alternator off in the morning to get it beefed up and one wire it
06-24-2021, 09:25 PM | #13 |
Moderator
I would use a three wire. - http://www.madelectrical.com/electri...hreewire.shtml
06-25-2021, 07:37 PM | #14 |
That was a good read. No doubt the 3 wire was the OE choice of good reason.
06-26-2021, 09:39 AM | #15 |
Moderator
Yes exactly. I have a 100 amp 3 wire in mine. With the ground it's actually a four wire.
Oh and I'm using the Old Air system too. The footprint (size), CFM and the control panel all sold me.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 06-26-2021 at 03:15 PM. |
07-23-2022, 06:52 PM | #16 |
A year later and I finally got my serpentine belt system installed. I'm leaning towards this here https://www.oldairproducts.com/produ...omplete-system
07-24-2022, 11:40 AM | #17 | |
Moderator
07-24-2022, 12:51 PM | #18 |
Not really sure. Don't know much about this. Is there a better model for our trucks?
07-24-2022, 01:03 PM | #19 |
Moderator
Yes, they have a rear exit that uses the firewall heater opening already on the firewall.
You can search their website by year make model and it will show.
07-24-2022, 07:57 PM | #20 |
They all say lower, upper or side fittings?
07-24-2022, 08:44 PM | #21 |
Moderator
Download the catalog. https://www.oldairproducts.com/articles/pdfcatalog
Around page nine it shows the various exits. And on page 31 or so our series trucks. Also on Monday you can call them to be sure. You won't be making any decisions here anyway.
07-24-2022, 09:10 PM | #22 | |
and here it is https://www.oldairproducts.com/produ...defrost-system
07-24-2022, 10:30 PM | #23 |
Does OldAir have provisions for outside air inlet?
I noticed it mounts in the engine compartment and allows you to keep the glove box. Vintage Air only used recirculated cabin air. No fresh air option like the factory system. It mounts under the dash and makes everything very tight under there. Glovebox is only good for a few papers after the air box is installed. |
07-24-2022, 11:41 PM | #24 |
Moderator
No, mine doesnt.
