Old 05-26-2021, 06:05 PM   #1
Jmoney01
PTO swap question
I am putting a nv4500 in my 1980 1 ton. I swapped the unit from the old 465. Problem is, the nv4500 housing is larger and will not allow the drive shaft to bolt up to the pto. Do they make different PTO units that space this out farther? Is there a different solution?
Thanks guys
Jmoney01 is offline   Reply With Quote
Old 05-26-2021, 06:35 PM   #2
kipps
Re: PTO swap question
I will admit, I didn't think the pto units would be compatible between a sm465 and a nv4500. Make sure that the gears are definitely compatible before you run it, otherwise you'll ruin both the transmission and the pto unit.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 05-26-2021, 10:26 PM   #3
v30crewcab
v30crewcab's Avatar
yes they take different internal gears. and they have different offset housings as well. also depends on what year your nv4500 is. the early and late ones take a different gear too. one is 25 teeth I believe and the other is 30, due to the different 1st ratio. I have one off a 92-93 nv4500 here, but its only touching half of the tooth as it needs a 30 tooth gear in it. I was mocking it up to see if it would work but it won't.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 05-27-2021, 05:29 AM   #4
Jmoney01
I'm not positive on the year of transmission. Tag on top, correct?
Old 05-27-2021, 07:01 AM   #5
sweetk30
sweetk30's Avatar
Shifter tower style help id it .
Early is pop in like 465
Late is 4 bolt newer style .
As said you NEED the correct pto parts for the change over from trans to trans .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 05-27-2021, 09:08 AM   #6
Jmoney01
The shifter itself is not bolted in, it's like the 465
Old 05-27-2021, 05:51 PM   #7
1976gmc20
Wow, I must have been lucky!
Almost 40 years ago I bought a PTO out of the junkyard and slapped it on an SM420 and it worked just fine
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 06-27-2021, 06:30 PM   #8
Dodgeguy1942
Thanks guys
are you interested in selling the pto
Dodgeguy1942 is offline   Reply With Quote
Old 06-29-2021, 09:39 PM   #9
Jmoney01
Sure
Old 06-30-2021, 01:09 AM   #10
kwmech
I've got a brand new PTO and kit for an early 4500 that I never used. Current orientation is Left side rear facing. I was going to install the 4500 in my tow truck replacing the 465, but I ended up selling the truck before install.
Old 06-30-2021, 07:29 AM   #11
kipps
If it was a late 4500, I'd be quite interested in that. Where do you go to buy a new pto kit?
Old 06-30-2021, 11:25 AM   #12
kwmech
I got mine from 6 states
http://www.sixstates.com/products/ca...p?category=PTO
Old 06-30-2021, 02:15 PM   #13
Jmoney01
I bought one from a local truck supply house
