06-18-2021, 08:45 PM | #1 |
Tach suggestions, location, but not in dash
Wondering where you guys put your tach? Mounted under the dash or clamped to the column?
Open to suggestions! I know it would be nice to install in the dash, however, I just don’t want to take it apart right now. Thanks!
1963 C20, small window, long bed 292, 4-speed |
06-18-2021, 08:55 PM | #2 |
Re: Tach suggestions, location, but not in dash
I clamped mine to the column and I made it's wiring into a little harness with a plug kit on the end so I could easily remove it for a show or whatever. Thing is I never remove it anyway.
06-18-2021, 09:02 PM | #3 |
Any pics? What brand? Did you buy it on Summit or someplace like that?
06-18-2021, 09:42 PM | #4 |
Who Changed This?
My FiL mounted a tach at the far left of the dash at the bottom of the A-pillar.
06-18-2021, 10:44 PM | #5 |
I mounted mine on the column, but I just zip tied it. Haven't had a zip tie break at all in the approximate 4 years it's been there. Also, if I need to remove the cluster, all I have to do is rotate it over to the side
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
06-18-2021, 11:17 PM | #6 |
Its an old Suntune mini that i bought brand new waaay back when. It came with a big ol' hoseclamp for column mounting. That location provides for a quick unobstructed view too. I kind of use it as a speedometer since mine is hopelessly broken anyhow.
06-18-2021, 11:58 PM | #7 | |
06-19-2021, 02:19 AM | #8 |
You will need a tach for a 6 cyl. Simplest solution is one from eBay that doesn't require a transmitter box. I would look at a Moon Eyes if you want big one or a small one such as the Super Pro 81316. The small one could also be placed in your cluster at a later time with another face on it.....
search 81316 and there's a NIB for 60. shipped |
06-19-2021, 09:02 AM | #9 |
I used an Equus tach that I got from the parts store. One of the LED backlights failed, but other than that, it has worked well for me. It can do 4, 6, or 8 cyl and points or HEI dizzys
It was fairly inexpensive back then
06-19-2021, 12:41 PM | #10 |
I used this one on my 56 PU.
Does 4, 6 and 8 cylinders. Wouldn't necessarily trust it in a high winding 8K small block but in a steady away 6 cylinder it will do you fine. Plus it looks the part. https://www.mooneyesusa.com/MOONEYES.../mpg5000tm.htm As for location attach it to the column as per others or stick it on the top of the dash and use the holes for the speaker to run the wires and secure it. P.
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
06-19-2021, 12:45 PM | #11 |
I was googling around one day for a friend trying to look for a Suntune tach, but all I found that was close to mine was Actron/Bosch. The reviews on Amazon are pretty strong though https://www.amazon.com/s?k=bosch+tac...l_5ttj5aczp2_e This one most closely resembles mine with regard to it's appearance and 2 5/8 inch size. https://www.amazon.com/Bosch-SP0F000...4121142&sr=8-4
06-21-2021, 02:15 PM | #12 |
Junior Member
I made a cluster housing out of fiberglass so I could mount tach, temp, oil pressure and volt gauge. Gauges are small but readable.
06-21-2021, 10:01 PM | #13 |
It's Better With Nitro
Here's where I mounted mine.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
06-21-2021, 10:38 PM | #14 |
I forgot I had mounted it on the bottom of the dash for a bit before I moved it to the column. I like the column mount better because I don't have to take my eyes off the road as much to see the tach on the column compared to below the dash.
Sorry for the sideways pic
06-22-2021, 06:59 AM | #15 |
Very nice Vin!
Do you really swing that Poncho to 6K ++? P.
06-22-2021, 08:41 AM | #16 |
Thanks! It made peak HP at 5900 RPM, and I have taken it up to there a few times.
06-27-2021, 09:50 AM | #17 |
On the column, rotated to the right side.
1966 Custom Camper -327, 3OTT 1968 Chevrolet K20 - 307, 4 speed 1972 K10 SWB - 400, 3OTT 2003 Corvette Z06 - LS6 350, 405HP 2004 Tahoe LT 2015 Silverado 2500HD - 6.0L V8 |
06-30-2021, 10:21 PM | #18 |
I picked up an Auto Tune tach, hopefully, it will work.
06-30-2021, 10:28 PM | #19 |
Cool, it'll be good to know your freeway rpms and shift points and all that. I'm kinda curious myself since you have the overdrive and all, maybe you can keep this thread alive by letting us know.
06-30-2021, 10:31 PM | #20 | |
I also just found out a friend of mine has a good friend that owns a rear end/differential shop in LA. Now I have some place to go, and hopefully, a good source of info!
07-19-2021, 09:53 PM | #21 |
A little late but here is mine
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
07-19-2021, 11:41 PM | #22 |
Now that this thread is back, how did the tach work out Mr Hat? What are your freeway rpms? Overdrive vs. 4th gear and all that
07-20-2021, 12:06 AM | #23 | |
I know I’m just making excuses, best I can do right now. I do mean to keep this thread going and get the rpm info out there, I am also curious what rpm I will be running at 65.
07-21-2021, 08:03 AM | #24 | |
07-22-2021, 10:21 AM | #25 | |
P.
