Old 07-23-2021, 01:55 AM   #4976
daveshilling
daveshilling's Avatar
Re: What did you do with your truck today, Part 3
Originally Posted by Janky59 View Post
Really over the past week, installed a T5 in my ‘59. It all went smoothly, bolted up easily, needed the driveshaft shortened, a great improvement though, a lot more fun to drive.
Man I'd love to do this. I've done quite a bit of searching locally for a used T5 in my area and have failed. I assume you bought a rebuilt unit?
daveshilling is offline   Reply With Quote
Old 07-24-2021, 08:32 AM   #4977
toymanbob
On it's tires, first time
Sitting on it's own tires and wheels for the first time! I like the stance, the wheels look perfect, it is full of fluid and ready for the first test drive but.......................When I tried to shift out of park today, there was no connection to the shift rod. I knew it could happen when I took the el cheapo path to obtaining a short steering column. These steering columns, made by Saginaw and shared by GM and Chrysler, can be shortened easily by just applying enough force to collapse the column to the desired length. The problem is internal, the shift connection between the shift lever and the tab that connects to the trans is two tubes that are locked together by nylon tabs that break when shortened. Tomorrow I'll pull the column, try to locate the hidden connection point, cut a slot and mig weld the two tubes together. Anyway, here it is
toymanbob is offline   Reply With Quote
Old 07-24-2021, 10:48 AM   #4978
mick53
Re: On it's tires, first time
This might be a dumb question but why do you shorten the column? Is it comfort or function?
mick53 is offline   Reply With Quote
Old 07-25-2021, 06:38 PM   #4979
toymanbob
The distance in the cab from my chest to the firewall where the steering goes through is much shorter than the car that the column came out of. I didn't want to pay $$$$ for a short column so I just shortened mine, Bob
Old 07-25-2021, 06:41 PM   #4980
OrrieG
OrrieG's Avatar
Bought the wood for the bed (Ash) and getting ready to mill it and test install. Have not posted for a while, have been in paint primer blocking mode, just when I think I am done I find something I am not happy with.
Old 07-25-2021, 10:46 PM   #4981
DransportGarage
DransportGarage's Avatar
Welocme back OrrieG!
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 07-26-2021, 10:50 PM   #4982
mick53
I got my water pump pulley that I altered back from powder coating today. $20 to strip and coat the pulley and spacer. I dropped it off Friday about noon. This started it's life as a reverse rotation Ford pulley and I redeemed it. This completes my accessory drive. My P/S and A/C is all electric. He did a really nice job. I shaved down the spacer, countersunk the bolts and grooved it for the 8 rib belt. Thank you for your time.
Old 07-27-2021, 05:38 AM   #4983
DransportGarage
How many "Best Engine of Show" trophies do you think your shelves will support?
Bob
Old 07-27-2021, 09:17 AM   #4984
mick53
LOL, I just finished putting up about 50 feet of 4 foot shelving so I should be good. Also a customer of mine bought me all new really nice commercial LED lights for the shop.
Old 07-27-2021, 10:53 PM   #4985
nvrdone
I like the way you fitted the lift thru the ceiling of the garage. Unfortunately if I did that my wife wouldnt like the lift sticking up into the family room.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's
Bought in 1973 for $235.00. Had it longer than my wife & Kids!!
nvrdone is offline   Reply With Quote
Old 07-27-2021, 11:14 PM   #4986
DransportGarage
I don't know... maybe you could make the top of it into a coffee table.
Bob
Old 07-28-2021, 08:10 AM   #4987
mick53
Now that's just funny.
Old 07-28-2021, 09:28 AM   #4988
nvrdone
that might work.
Old 07-28-2021, 08:25 PM   #4989
1project2many
Years ago a friend used an ongoing SBC build as a coffee table. He lived in an apartment so had no real workspace. He'd assemble a little of the engine as he had money and time then he'd put a piece of glass on top of the engine when he was finished.
1project2many is offline   Reply With Quote
Old 07-28-2021, 11:09 PM   #4990
nvrdone
I almost got a lamborghini 12 cyl at an auction. my plan was to use it as a coffee table with a glass top. unfortunatly that didnt work out
Old 07-29-2021, 11:25 AM   #4991
1project2many
That would have been a cool table!
Old 07-29-2021, 11:26 AM   #4992
1project2many
Duplicate post!
Old 07-29-2021, 01:07 PM   #4993
mr48chev
mr48chev's Avatar
Mick raises the bar a few notches when it comes to detailing an engine out.
My ongoing truck projects:
Old 07-29-2021, 01:14 PM   #4994
mick53
Thanks, it's a blessing and a curse.
Old 07-29-2021, 02:38 PM   #4995
DransportGarage
I thought about putting this under my glass coffee table.
Hey, that would look OK on Mick's block (as long as it was at my house and not his)!
Bob
Old 08-01-2021, 01:06 PM   #4996
vintovka
vintovka's Avatar
Fired it up and drove it up and down HWY 101 along the beach. With all this fauxvid bovine excrement i had forgotten how much enjoyment can be derived from driving it. Did not realize how fast the thing was and how good the sea air smells!!
vintovka is offline   Reply With Quote
Old 08-01-2021, 01:12 PM   #4997
vintovka
vintovka's Avatar
Fired it up and drove it up and down HWY 101 along the beach. Bright sunny morning with the waves crashing in on beach . With all this fauxvid bovine excrement i had forgotten how much enjoyment can be derived from driving it. Did not realize how fast the thing was and how good the sea air smells!! Keep plugging on your builds and remember there's memories to be made.
Old 08-01-2021, 01:57 PM   #4998
nvrdone
Todays project is to remove the back window from the cab. A few years ago my wife bought me a sliding rear window. I finally found an old school glass guy who will install it for me on 8/11. Just want to make sure there is no metal repair needed before the install.
Old 08-02-2021, 11:04 PM   #4999
nvrdone
so i didnt get to the glass yesterday. But tonight its out !! Cut the gasket from the out side & gave it a push - it came out & fell in the bed.
Then I decided to check the vacuum and timing. Vac was 14" at 950 rpm. timing was almost 25 deg. advanced. brought timing back to 15 deg advanced and left rpm's at 950. vaccum jumped to 25 ". truck runs much better!!
Old 08-03-2021, 07:56 AM   #5000
evilokc
havent done much in the last few weeks. been driving it when i have time. still have some light body work to do.
evilokc is offline   Reply With Quote
