07-31-2021, 01:22 PM | #1601 |
Re: Post your C/L finds here for all to see
1986 c10 project for sale!
Handles and runs well. 305/ 700r trans. Transmission has been replaced with a rebuilt 700r. Been lowered 3/5 with DJM 2456 3/5 kit with shocks and upper control arms as well! New seat, carpet was pulled out to sound deaden floor and inside of door panels as well. No rust in floor or body. Couple of dents in the body Have a box full of parts I haven't put on yet. https://www.facebook.com/marketplace...4-eaf956e71eac |
07-31-2021, 01:27 PM | #1602 |
07-31-2021, 01:35 PM | #1603 |
1977 C10 Scottsdale, heavy half, 350 4brl, TH350, ps, pdb, ac, cruise control. One owner till 2018, original truck, always maintained, appears to be original sheet metal, very solid and unmolested, runs and drives excellent, new dual exhaust. Please call or text [hidden information] . https://www.facebook.com/marketplace...Anull%7D%22%7D
07-31-2021, 03:54 PM | #1604 |
I picked up these from a guy clearing his new property.
Will be going on my Jimmy.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
07-31-2021, 10:26 PM | #1605 |
08-01-2021, 10:20 PM | #1606 |
08-01-2021, 10:32 PM | #1607 |
08-02-2021, 12:19 AM | #1608 |
08-02-2021, 12:30 AM | #1609 |
08-02-2021, 12:36 AM | #1610 |
08-02-2021, 02:35 PM | #1611 |
- When the Reaper makes his deal, trust in your steel - '77 C10 350/350 2/4 drop and a mild street engine |
08-02-2021, 09:53 PM | #1612 |
08-03-2021, 02:30 PM | #1613 |
08-03-2021, 03:07 PM | #1614 |
I'm selling this 1981 K10 Custom Deluxe, 95 percent original, 350cui motor with a 4spd tranny, 4x4, Warn hubs,tires have less than 300 miles on them, all fluids are fresh, motor has a fresh tune up, this truck runs and drives like a new truck! I'm asking $6500 "OBO" FIVE 0 THREE- TWO NINE 8- THREE 99 ZERO! https://spokane.craigslist.org/cto/d...360316746.html
08-03-2021, 03:09 PM | #1615 |
08-03-2021, 03:13 PM | #1616 |
1981 Chevrolet C10 short bed 2wd. Super reliable truck. Entire build is on Youtube:
https://youtube.com/channel/UC85xPUc7yKzMr-9KIf-oFhw 454 BBC bored .030” over by PO “Tranzilla” RSG built T56 6 spd manual Holley Super Sniper 1250hp EFI Holley Hyperspark Ignition Edelbrock performer rpm aluminum heads Hydraulic roller cam conversion Edebrock performer rpm dual plane Wilson racing tapered bore 4 hole spacer Derale dual electric fans High Amp alternator Ceramic long tube headers Full 3” mandrel bent exhaust with Magnaflow Power steering and 4 wheel disc brake conversion Aluminum driveshaft with 1350 series yokes 12 Bolt (4.11 gears) Eaton Truetrac LSD Mcleod twin disc RST clutch https://www.facebook.com/marketplace...7-e04a3271bde6 |
08-03-2021, 05:02 PM | #1617 |
https://www.facebook.com/marketplace...7-284021439889
1974 Chevy Suburban K20. 3/4 ton, 350, 4 speed, 4 wheel drive. The engine has a 4 barrel Carter carb and headers. Transmission is an SM465. Transfer case is an NP203. Front diff is a Dana 44 and rear diff is a 14 bolt with a factory locker. Some custom pieces on it are the 1974 Warn M6000 winch and the GoRhino front differential truss. It was originally sold new to the US Forest Service in Washington (which explains the color), then moved down to California, and then Nebraska. It recently received new ten ply tires, battery, tune up, and some other parts to make it reliable. This has been basically my daily driver the last two months and has been a ton of fun. The bottom of it is much nicer than a lot of these square bodies that have been in the Midwest all their lives. It still has some dents, rust, and bondo down low, but it’s very workable. Interior mainly needs a good cleaning and a floor mat. |
08-03-2021, 05:04 PM | #1618 |
08-03-2021, 05:06 PM | #1619 |
08-03-2021, 08:46 PM | #1620 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
08-03-2021, 11:41 PM | #1621 |
08-04-2021, 02:15 AM | #1622 |
08-04-2021, 02:17 AM | #1623 |
08-04-2021, 02:22 AM | #1624 |
08-04-2021, 09:51 PM | #1625 |
75 C2500 High Sierra Camper Special with Winnebago camper shell $25950
