Old 08-11-2021, 09:02 AM   #451
skymangs
skymangs's Avatar
Re: Orson the 49 GMC ~ Chris C.
Thank you, I try
skymangs is offline   Reply With Quote
Old 08-11-2021, 06:32 PM   #452
skymangs
skymangs's Avatar
We finished with the quad gauge
Here’s the back all wired with the capalaries attached
Here’s Wyatt wiring them in
Here’s the speedometer complete with faceplate
Old 08-11-2021, 06:33 PM   #453
skymangs
skymangs's Avatar
now we didn’t get the speedometer in, I forgot a light socket in my Tahoe. But the quad gauge sure looks great!
Tomorrow: install speedometer and rework tail lights. (I’m not happy with the installation)
Old 08-12-2021, 09:04 PM   #454
skymangs
skymangs's Avatar
so today I had Christian change the tail light disks from surface mount to mounting inside the bedrail. I am much happier with the appearance of them now!
Old 08-12-2021, 09:06 PM   #455
skymangs
skymangs's Avatar
And of course here is Wyatt, hard at work, Wiring this thing!
The gauges are installed and all the interior wiring is complete
The seat was installed to mark the holes.
Tomorrow bolt the seat down, find the mysterious vacuum leak that’s bogging the engine down at high rpm, and get the window reveal trim installed.
Old 08-12-2021, 09:54 PM   #456
NorCalGal
NorCalGal's Avatar
Nice, what’s the seat out of?
Jan's 53
NorCalGal is offline   Reply With Quote
Old 08-12-2021, 11:22 PM   #457
skymangs
skymangs's Avatar
2004 Durango 2nd row
Old 08-13-2021, 11:04 PM   #458
skymangs
skymangs's Avatar
Today we got the seat fully mounted, including welding the 5/16” hooks for the outside corner
Old 08-13-2021, 11:05 PM   #459
skymangs
skymangs's Avatar
We also finished up with the tail lights. I think that looks much better!
Old 08-13-2021, 11:11 PM   #460
skymangs
skymangs's Avatar
Old 08-16-2021, 10:33 PM   #461
skymangs
skymangs's Avatar
We got a whole bunch of little stuff done today, we also discovered that several of the AC fittings we crimped were non O-ring. The proper fittings were ordered. Don’t know how they got mixed in my AC fittings, I’ve gone through them all so this won’t happen again!
Settled ride height is right at 5.25
Here’s the overall look of the truck
Here’s a shot of the interior And a shot of the dash, nearly complete
Old 08-16-2021, 10:34 PM   #462
skymangs
skymangs's Avatar
we had to remove the intake for the mechanical water and oil metric to SAE adapters
Wyatt pushed the button to set the odometer and the lens cracked. We’ll replace it with plexiglass if you insist, but getting those gauges in really sucks. Wyatt's excuse was it gives it character, and I have to say I don’t disagree.
Old 08-16-2021, 10:42 PM   #463
skymangs
skymangs's Avatar
Old 08-17-2021, 11:02 PM   #464
skymangs
skymangs's Avatar
so today we got the oil and water cappalarys installed
we put the intake back on
fixed the AC lines
And applied our mark to the tailgate
Old 08-18-2021, 10:32 PM   #465
skymangs
skymangs's Avatar
Today we focused on a whole bunch of little things
we insanely a dummy throttle cable to fill the hole
We installed a working cigarette lighter
We started figuring how we were going to install the 55 TF tail lights
Old 08-18-2021, 10:38 PM   #466
skymangs
skymangs's Avatar
We finished installing all the window trim
Old 08-19-2021, 09:51 PM   #467
skymangs
skymangs's Avatar
We were having issues with the tail lights, discovered we had no continuity between the seat bolt and the neg post on the battery. Means bad body ground. So we replaced the 10ga ground with 4ga battery cable. That solved most of the problems. Still have no power to the right turn, I suspect column wiring, will check tomorrow.
We also got the tail lights installed today.
Old 08-20-2021, 09:25 PM   #468
skymangs
skymangs's Avatar
We had a horrible day at the shop today! I think we actually managed to go backwards!
We struggled with the turn signals all day to no avail (there’s a ground issue somewhere, but I’ll be damned if I can find it)
so we decided to do things we could accomplish, the MAF Adapter got here yesterday so we put it on
then we put together and installed the temp sending unit
Thought we’d start it to see that it ran better. Turned the key and nothing! So we finally discovered that the starter had gone bad and grounded out the windings. Changed it, and it made no difference. So for the first time ever we are working Saturday, not on my projects, but this truck! I am bringing in my expert.
Old 08-21-2021, 11:02 PM   #469
skymangs
skymangs's Avatar
we got the truck running. The battery had 12v but no cranking amps.
https://www.facebook.com/10635701173...70777727858252
We also fixed the signals. Those front signals looked primo on the ouside, but were corroded hot garbage on the inside! After totally disasembling them, and several hours of cleanup/rebuilding them, they work!
And now for the not so good news. When we went to back it out, no reverse. Now, reverse worked before the fire. Apon inspection it appears that the PRnD switch got a little toasty and may have caused some internal damage.
Old 08-23-2021, 07:56 PM   #470
skymangs
skymangs's Avatar
we got the AC sucked down and charged today
Old 08-24-2021, 07:41 PM   #471
skymangs
skymangs's Avatar
Upon further research we discovered that even in limp mode with no wires connected it should have drive and reverse. It was decided that the transmission was bad. So we pulled it and tomorrow we’ll put a new one in.
We also discovered a leak on the back of the water pump, so that will need to be pulled and replaced.
Old 08-24-2021, 11:43 PM   #472
joedoh
joedoh's Avatar
ugh! thats super suck.
Old 08-25-2021, 12:49 AM   #473
skymangs
skymangs's Avatar
Tell me about it! Every time we fix something, two more things go wrong! I’ve never built a truck that put up such a fight against being made roadworthy!
Old 08-25-2021, 07:44 PM   #474
skymangs
skymangs's Avatar
Here’s the new transmission
We’re about 95% done installing it. All that’s left is the exhaust and driveshaft.
Tomorrow we’ll finish that and put in the new water pump.
Old 08-26-2021, 07:55 PM   #475
skymangs
skymangs's Avatar
the Transmission is in and we have reverse!
We found a leaky rear brake line we had to deal with, it’s fixed
we are going in at 10 instead of noon, to change out that water pump
better video tomorrow
https://www.facebook.com/olesarge201...24536115273177
