Old 08-31-2021, 08:32 PM   #1
7D2N
7D2N's Avatar
Brake in oil question
I had the engine for my Blazer rebuilt and was broke in on a stand. I still have the brake-in oil engine and start it regularly. Should I drain it and add new oil or keep running because it's not road-ready.
Just for the fun of it
7D2N is offline   Reply With Quote
Old 08-31-2021, 09:06 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Brake in oil question
I would leave it in there...
If the rebuilt engine is a flat tappet cam, any replacement oil MUST contain a ZDDP oil additive, as modern oil do not have Zinc content due to it causing catalytic convertor failures.
If the engine has a roller cam and lifters you would be fine with a modern oil...
Have fun!
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 08-31-2021, 11:38 PM   #3
truckster
truckster's Avatar
Generally you'll run 500 miles before the first oil change. Unless you're running it for a long time each time you start it, it's going to take a while to equal as many running hours. Plus, putting a load on the engine helps break it in. I'm with Aussie; leave it in there until you get the engine in the truck and then make sure you use the proper oil when you do change it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 09-01-2021, 11:33 AM   #4
geezer#99
geezer#99's Avatar
Compared to a lot of other things, Oil is cheap!
I’ve always changed it after break in. Partly from piece of mind. Mostly to look for metal in the oil and filter.
Old 09-02-2021, 04:55 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Me too. Since this oil ZDDP fiasco started, I now break in a flat tappet engine with break-in oil, drain it, change oil and filter and use ZDDP additive, and then change oil and filter and add ZDDP again after 500 miles.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 09-02-2021, 09:51 PM   #6
7D2N
7D2N's Avatar
It was broke in with good grade oil and the motor is now in the blazer. I start it fairly regular and I move it around some, but it's not ready for the road yet.
new oil can't hurt too much.
Thanks guys.
Old 10-09-2021, 04:47 PM   #7
7D2N
7D2N's Avatar
Okay, guys. I drained the original break-in oil (mainly to see if I had metal stuff) and it showed to be really clean. My question If it was broken in with 30wt and because they sent me 20-50wt instead can I run it.
Did I mention it was in the Blazer.
Thanks for any info.
Old 10-09-2021, 05:15 PM   #8
geezer#99
geezer#99's Avatar
You live in cold country.
No need for heavy oil.
I’d run 10w30.
Old 10-09-2021, 05:24 PM   #9
7D2N
7D2N's Avatar
Thanks geezer. I'll have to send the Lucus 20-50 back and get the 30wt.
Old 10-10-2021, 05:57 AM   #10
The Rocknrod
Moderator
The Rocknrod's Avatar
10W30 is suitable for varying temperature ranges and also works well in cold weather. Not SAE 30 or 30W.
Old 10-12-2021, 11:14 PM   #11
toolboxchev
Valvoline VR1, hands down a great oil in my book. 100k on my rebuilt engine with it. Flat tappet cam.
toolboxchev is offline   Reply With Quote
Old 10-14-2021, 11:15 AM   #12
GASoline71
GASoline71's Avatar
I used to run straight SAE 30wt in all my rigs until about the mid 1990's. Now I run 10w30wt in all my rigs.
30wt for one is hard to find. It is also specified for break-in oil because it used to be a non-detergent oil. Not so much anymore. Don't run 30wt in your rig. Your lifters and bearings will thank you for using 10w30 in cold weather.
Gary
