Where to buy Vortec heads
Looking at putting vortec heads on my 350. Where is the best deal on a set of new vortec heads? Considering pulling some from the junkyard but seems like it may be a hassle because from the sound of it I may pull six before I find two good ones. Thanks.
Posted via Mobile Device |
Re: Where to buy Vortec heads
I,ve seen them at summit but was expensive if I remember right
Scoggin Dickey supposedly has good prices. I’m not sure they are GM heads but are better than stock stuff. Can get em in 225cc I think too.
#4 | |
The big "Vortec" heads are bowtie, and the only downside is there are iron. |
#5 | |
driving is in my blood
I remember buying my set of vortecs from Scroggin back in like 1998. $400/set fully assembled. Ahhhh the good o'l days.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
![]() Join Date: Jun 2012
Blue Print makes some aluminum Vortec style heads for a reasonable price. Have no idea how good they are but they have good reviews.
https://www.summitracing.com/parts/mll-h8002k
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
#7 | |
#8 | |
![]() Join Date: Dec 2011
Summit also makes a reproduction iron Vortec with their own house brand for $364 each:
https://www.summitracing.com/parts/sum-151124 Also high ratings. Quote:
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
I got mine from summit then after I found i could have got them from skogen with machine work and upgraded springs for higher lift cam
I have gotten a like new set from ebay and picked up a free express van that the po was determined the heads where blown really bad intake gasket good motor and tranny for free The l31 had a very bad intake gasket that failed often and is most likely the cause for vortec heads to crack from overheating to many times with no antifreeze |
![]() Join Date: Jul 2015
You can also make a stock vortec head take .525 lift with a cheap ls6 valve spring a special comp retainer, and a different valve seal. No machining required.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
Thank you all for the replies!
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies 53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793 http://67-72chevytrucks.com/vboard/s...d.php?t=771679 |
