10-20-2020, 02:44 PM | #26 | |
Posted via Mobile Device |
10-20-2020, 02:49 PM | #27 | |
10-20-2020, 03:01 PM | #28 | |
Re: 72 C20 LS Swap/Build
2 things. You will want to drop the tank a little(see my thread if you want) so you don't have to clearance the bed cross rail too much. 2nd thing, check out this powernation episode. It's EXACTLY what your about to do - https://www.powernationtv.com/episod...ls-engine-swap .
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
10-21-2020, 10:04 PM | #29 | |
I had not come across the Tanks Inc. pump - the one with the reservoir tray. I take it that you are also using that in an under the bed tank? I had found a guy that modified his in cab tank, but I didn't want to bother with that. Thanks for the video link. Yeah, that's the plan. Mine is a C20, so I don't know if there will be the same clearance issues, but dropping it a couple inches won't be a problem. I am planning on doing something a bit unusual with the fuel fill. I found this post, #30 where the filler tube is routed all the way to the stock location to the under the bed tank. I like this since it keeps the original look and location as well as convenience next to the drivers side. I think the behind the taillight mounting is a bit weird and wouldn't want to have it in the bed floor. |
12-14-2020, 11:16 PM | #30 |
Some recent work on the truck.
Modified the fuel tank to fit the 09 Silverado fuel pump. I had a 1/4" thick steel ring waterjet cut to weld to the tank which would allow the pump to be bolted down. The tank didn't have enough of a flat area to mount it, so a new pan was made and cut into it. Bolts were welded into the pan through the ring which act as studs to mount the pump. The ring wasn't really necessary, but reinforces the pan to provide a strong mounting location. The original 72 fuel sender was reused since it fit in the sender hole in the tank. The lines were brazed shut since it won't be carrying any fuel. |
12-14-2020, 11:17 PM | #31 |
More.
The fuel tank ended up needing more clearance to allow the filler neck to get above the frame rail. The bed crossmember was notched, filled in and is now high enough to be out of the way. The frame rail had to be heated and bent as well to get the neck above it. |
12-14-2020, 11:19 PM | #32 |
More work.
My plan to run a long line to the original filler in the cab won't work due to the slope required and clearance for the suspension. So it is being routed to be behind the driver side wheel well on the side of the inner bed panel. There will be a steel tube that makes its way to the filler neck on the tank along with a Gates rubber 90 to connect it. This is a work truck for me, so having something straightforward and functional is more important than hiding it behind a taillight or having a hole through the bed floor. I also didn't want to cut into the bed side to install a door since that would mean re-painting the truck which I cannot afford, nor want to do. It will be painted the same blue at least. |
12-14-2020, 11:25 PM | #33 |
Last one for today.
Forgot that the gas filler will also have a lid made up to keep weather off it. The Camaro rad is in. I ordered a set of 3 core radiator bushings and modified the 4 core brackets to fit them since the new rad is much smaller than the original 4 core. The new bushings also needed to be cut a bit to fit the rad snugly. They were cut on a diagonal and RTV'd into the brackets. Upper rad hose fits on from the 09 Silverado. Cooling lines are being bent up to get connected. Once the fuel system is all connected, I suppose the focus will turn to the wiring. Was hoping that HP Tuners would have a Black Friday sale but no luck. Maybe Boxing Day.. Last edited by DM72C20; 12-14-2020 at 11:27 PM. Reason: missing pictures |
12-15-2020, 07:06 PM | #34 |
All good work man! Question, I just finished my custom gas filler(see my thread), welded a vent in the cap neck. Also using rollover vent. Curious how your doing yours. Is that the OE filler your using(already has the in-cap vent that follows the filler line to tank)?
12-16-2020, 12:34 PM | #35 | |
12-16-2020, 07:57 PM | #36 |
Cool man, you will be happy with a stock unit like that. Here's how I understand it all. You need 2 vents. 1 vent for filling your tank, the other vent is for driving and sitting, it's for heat expansion and such. Fill vent allows air to push out during filling so you can use the gas pump nozzle full throttle .
Here's the safety part. Small vent for heat expansion, for safety reasons, gets the rollover valve. Fill vent needs to be connected to your filler cap so the gas nozzle extends past it allowing air to escape back out through it, but seals it off with cap during operation. If you get into a wreck, rollover valve closes the small valve so fuel doesn't spill out and filler cap seals the filler vent. Safe. I would say that's the general idea behind it all for safety and function. There are more sciences to it you can read about elsewhere
12-16-2020, 09:46 PM | #37 | |
09-14-2021, 01:29 PM | #38 |
After an unintentional summer hiatus, work is going again on the truck!
The gas tank is all welded, pressure tested, wired and mostly plumbed. Everything seems to fit nicely including the fill which involves an S bend tube, a rubber 90 and some straight hose. Might pick up an installation tool for the nylon fuel lines and fittings. I've ordered parts from FMSI since they are local for that stuff. Wiring cleanup has been in progress too. Everything should be set to the gas tank and fuel pump. Underhood stuff is close. Gauge swap to the S10 speedo is mostly done. Still more work to do at the dash. I still don't quite get how the ignition 'talks' to the PCM yet... There's an instrument panel connector with some vague sounding wires that remain, along with a VSS wire. I added in a VSS wire to the X1 connector but a bit uncertain about that. I'm quite confused about the alternator after reading the other day that it needs a GCBM and BCM to have the ability to change voltage output based on load. I don't have either module, however that function sounds nice compared to its default at 13.8V. Keeping the alternator stock is appealing from a parts availability standpoint. I've read a thread about changing out the regulator on the back, but that isn't stock anymore... There was some other thread about a PWM signal generator device... Any suggestions would be helpful. |
09-14-2021, 06:26 PM | #39 |
You've been quite busy for having a hiatus..!!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
11-10-2021, 02:20 PM | #40 |
Big news - the truck runs!!!!
The wiring proved to be rather tricky to get that Gen 4 engine to run, but we perservered. I started a thread about it here where the specifics are discussed: http://67-72chevytrucks.com/vboard/s...d.php?t=827216 We took it for a little spin after cleaning up all the underhood wires and it is so smooth and quiet! There is some programming yet in order to get the speedo and tach reading - so far nothing. Still need to clean up the dash wiring as well and connect the oil pressure sender - it started leaking oil on my shoes once it finally started to crank, so it was temporarily capped off. The alternator is outputting 13.8V which is its default or limp mode and I would like the variable output capability. I'm not running a BCM, so will need to figure out where to run the wires from the negative cable sensor. |
11-10-2021, 02:24 PM | #41 |
Some pics from the last while..
Underhood wiring. The alternator PWM generator is the small box with buttons. The 09' fusebox has been modified to fit into place. The S10 speedo before installation into the cluster. Thanks to Ls1nova71 for the kit. Dash wiring in progress. A new fuseboard was wired in place with blade fuses rather than the old one. Fixed up the instrument lights that never used to dim. |
11-10-2021, 02:35 PM | #42 |
And some pics of the fuseboard stuff.
A couple weeks ago, when we tried getting it started, I had the idea to connect a wire to the starter relay from the ignition. It was pink and I think it may have accidentally went onto the powertrain relay. It started to smoke and melted part of the board instantly! It was not a great moment. Another used board was picked up and we checked through each and every contact to determine how the relays should be oriented. The crazy thing is that the manual shows one thing and the second donor relays didn't align, nor did my Dad's running 09' truck. His doesn't even seem to have a fuel pump relay or fuse??!? Anyway, after testing for current, we oriented the relays so that 30 was battery hot in each case. Pink wire is signal from key on to 86 on the run/crank relay which powers up the ECM. Purple is signal from key crank/solenoid which goes to 86 on starter relay. These two wires were all that was needed to get it running. There is relatively little wiring coming into the fuseboard, but it still makes use of the factory connectors and board. If there is any issue, these parts can be swapped out. |
11-11-2021, 05:30 AM | #43 |
Wow! You have great patience sir. Congratulations are in order!!!
01-17-2022, 03:13 PM | #44 |
Update on the truck. Some observations on having a working LS swap done.
It took many attempts to get the speedometer setting to work properly. There isn't much in the way of guidance for this sort of thing. Part of the problem I was having was relying on the HP Tuners Scanner speed rather than reading it from a separate GPS speed on my phone. It's now set within 1mph on the speedo and is around 2% high on the odometer over a long distance when compared with the GPS distance. I might modify the setting yet again to try and get it within a %. The truck starts instantly, no matter what. I had it parked outside in -18C (around 0F) weather and no problem at all. In that cold, I found that it was a bit stiff to shift into drive from park, but the engine had no trouble whatsoever. There is so so much power on tap! Even though it is just a 4.8, it is fast! I'm loving that aspect of it. Mileage has been a respectable 12.8 - 13.8mpg. I've been having fun with it, so I'm sure I could get it even higher if that was the priority. It's got new Cooper AT3 tires now which were part of an attempt to eliminate vibration at highway speed. The old tires weren't worth balancing apparently. The vibration is certainly distracting when cruising along at 75mph. The mirrors all shake so much it makes you dizzy. Might get it in for an alignment next, and possibly replace suspension bushings and whatnot. The motor and trans mounts are all new with the swap. Cab mounts were replaced in the last few years. Also trying to reduce the wind noise at highway speed. I added some cut to width pipe insulation along the top edge of the door frame hoping to cut down on potential entry points for noise. The insulation is EPDM and actually looks quite good. I adhered it with double sided tape. It made a slight difference, but could be so much better. The engine is whisper quiet now which at least rules that out at speed. |
01-24-2022, 11:38 AM | #45 |
Enjoying this. You are doing great work. Looking forward to the progress and updates.
02-03-2022, 02:43 AM | #46 |
On Vibration- That factory shaft is huge around for a reason. the added diameter keeps the long shaft from "whipping" at speed. A bigger shaft helped me.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
02-05-2022, 01:33 PM | #47 |
Nice looking truck. Have you checked the slip yoke and bushing for excessive play? That would make a driveshaft vibration. Bent rims also comes to mind.
1970 k20 6.0l/nv4500/np205/14bff in progress build linkhttp://67-72chevytrucks.com/vboard/s...d.php?t=677014 |
02-05-2022, 02:23 PM | #48 | |
Although on my C20/LS swap I did not change to a one piece shaft but I did have a couple tries at balancing the shaft just right. Since I am just joining the fun-- that is a great looking C20, you have done a real good job with it. It would have taken all the wind out of my sails for a week if I smoked my board. Glad you kept at it.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 Last edited by Mike Bradbury; 02-05-2022 at 02:38 PM. |
02-05-2022, 06:03 PM | #49 |
Another thing comes to mind if the truck had a carrier bearing driveshaft previously(plus the fact it has a new drivetrain with output possiblyin a new location). You want the working angle of your u joints to be equal while going down the highway.. Your rear pinion was not angled correctly for a non carrier driveshaft.for leaf springs that means having the pinion a degree or two lower than the trans output so it rises under load. A cheap magnetic base degree measuring unit will let you check both ends with the driveshaft out on the yoke and trans to compare and adjust with a shim in the back or reweld the perches
02-05-2022, 10:44 PM | #50 |
^^ yes
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
