Old 09-06-2021, 03:04 PM   #1
kwmech
AC Blend door "clip"?
Taking the heater core out of my dads 83 Truck and found a broken plastic connector that moves the blend door via the vac pod from the opposite side. I know GM has them for about 3-4 dollars, but I've found one out of either aluminum or steel--but really 30 plus dollars each? yikes!! Any vendor on the board here have it?? Looking to get a couple of them for future endeavors and one for my suburban if there is ever an issue with it.
kwmech is online now   Reply With Quote
Old 09-06-2021, 03:07 PM   #2
kwmech
Re: AC Blend door "clip"?
This little jewel
Old 09-07-2021, 06:13 AM   #3
Dead Parrot
Post #35 in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=460942 shows my homemade metal solution. It is still working today.
Dead Parrot is offline   Reply With Quote
Old 09-15-2021, 04:46 PM   #4
Jeepwm69
I just ordered one of the aluminum ones off of ebay. Buy once, cry once.
But can someone tell me how the blend door works? Is there a way to test function?
I have my dash all pulled apart at the moment and want to make sure everything is working properly when it goes back together.
Jeepwm69 is offline   Reply With Quote
Old 09-15-2021, 08:21 PM   #5
hatzie
Moderator
hatzie's Avatar
It's controlled by the COLD <----> HOT lever.
Vacuum on newer machines and cable on the older machines.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 09-15-2021, 09:54 PM   #6
kwmech
I sucked it up and got 2 aluminum ones. One for my suburban and one for the dads truck. They arrived today as a matter of fact
Old 09-16-2021, 05:10 PM   #7
Jeepwm69
This is an 83. I have the cable for hot/cold working well, but the blend door (assuming I'm using the proper term for the door that the clip attaches to) just seems to flap back and forth.
Guessing the engine has to be running (to produce vacuum) but what else makes it move back and forth? I want to make sure everything is working as it should before I put all the ductwork etc back in place.
Old 09-16-2021, 05:51 PM   #8
hatzie
Moderator
hatzie's Avatar
You can apply vacuum to the HVAC vacuum accumulator tank and test the operation of the control valves and motors.
This is supposed to be the HVAC Vacuum diagram for a K5.
Name:  HVAC K5 Vacuum.jpg
Old 09-20-2021, 01:10 PM   #9
Jeepwm69
Attachment 2131574
Thank you! That's great info!
Old 09-26-2021, 03:39 PM   #10
Pontiac1976
Pontiac1976's Avatar
Taking the heater core out of my dads 83 Truck and found a broken plastic connector that moves the blend door via the Vac. pod from the opposite side. I know GM has them for about 3-4 dollars, but I've found one out of either aluminum or steel--but really 30 plus dollars each? yikes!! Any vendor on the board here have it?? Looking to get a couple of them for future endeavors and one for my suburban if there is ever an issue with it.
Try LMC Pg.180 #7 $5.95 If that that the part "Connecter-Diverter link for A/c
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 09-26-2021, 04:06 PM   #11
kwmech
Yup, but it is still plastic and now chinese plastic.
Old 09-27-2021, 08:36 PM   #12
Pontiac1976
Well then just get a solid round alum rod big enough from home depot. Cut off a section use hack it with Dremel Tool and Accessories. Cut and grind in to shape in 2 hour you should be able get it rough out the Chinese alum test fit fine tuning it for fitment. You can spend as much to finish it to your liking. I did not know you did not want Chinese plastic. The shape is not hard to make. The other option is pc 3D printer buy one or try calling 3D printer shop to do some up for you.( but Plastic again)
Old 09-27-2021, 11:42 PM   #13
kwmech
Good grief see post number 6
Old 01-01-2022, 06:18 PM   #14
Hart_Rod
Hart_Rod's Avatar
link?
Hart_Rod is offline   Reply With Quote
Old 01-02-2022, 09:34 AM   #15
TKCR
TKCR's Avatar
Originally Posted by Hart_Rod View Post
link?
Go to Ebay, type in a/c heater blend door clip. Several pop up.
Old 01-03-2022, 01:28 PM   #16
hatzie
Moderator
hatzie's Avatar
If you can run a grinder and MIG you can DIY one out of steel.
Old 01-05-2022, 01:17 PM   #17
Hart_Rod
Hart_Rod's Avatar
Thanks! I ordered one of the aluminum pieces. Hopefully I will never have to replace it again. On another note, where are you guys sourcing quality heater cores? TIA!
