Old 09-17-2021, 08:51 PM   #1
Dagobah
anybody using Porterbuilt control arms with a No Limit sway bar?
We are wondering about two things: what kind of endlinks to use, since the endlinks provided with the sway bar have rod ends, but the tab on the Porterbuilt control arms are horizontal. It should be easy enough to find some endlinks that will work, but someone mentioned a loss of articulation.
The other thing is the difference in width: the No Limit sway bar is 43.25 inside to inside, but from what we measured, the tabs on the control arms will be around 41.5. Do y'all think that will be a problem?
Dagobah is offline   Reply With Quote
Old 09-18-2021, 11:19 AM   #2
HO455
HO455's Avatar
Re: anybody using Porterbuilt control arms with a No Limit sway bar?
Since no one else has responded I will throw my 2 cents worth of knowledge out there
I do not know the specific answer to the question you have posed but, I will say that there may be a interference with the wider sway bar and the tire/wheel at or near full lock of the steering. If that was not a problem I would remove the existing sway bar mount and install the No Limit links in a vertical position. Angled connecting links are like angled shock the greater the angle the less effective they are.
You might consider asking a moderator to move this thread to the suspension section where the big brain suspension guru's hang out.
Good luck.
RIP Bob Parks.
Old 09-18-2021, 04:02 PM   #3
SkidmoreGarage
I advocate for using matching parts when doing suspension work, if you can return any parts- that may be a good option.
The other option is to just replace the lower control arm endlink mounts and place them in the correct location. It shouldn't be too difficult, as they appear unpainted. In my opinion, it would be an upgrade to move away from a stud mount and move to a double shear.
SkidmoreGarage is offline   Reply With Quote
Old 10-06-2021, 09:50 PM   #4
Dagobah
Thanks for the input fellas.
Can any mods move this to the suspension forum? Or I can make a new thread...
Old 10-06-2021, 10:58 PM   #5
leddzepp
Moderator
leddzepp's Avatar
Moved to suspension forum.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 10-07-2021, 07:45 PM   #6
Dagobah
Thank you sir!
Old 10-08-2021, 06:03 PM   #7
SCOTI
SCOTI's Avatar
Sometimes parts from the same manufacturer don't play well together either. Making the mounts work as intended (plumb) is the way to go if @ all possible.
Spohn Performance has sway bar end links that allow connecting the two different type mounts. Sometimes you have to be creative as they're not an 'application specific' item here....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-01-2021, 12:14 PM   #8
Dagobah
oh man I appreciate it. that's actually what I had in mind. It looks like the other variable here is that our sway bar ends are wider than our control arm mounting points. so we'll see how that goes.
Old 11-01-2021, 01:55 PM   #9
SCOTI
SCOTI's Avatar
I'm not 100% done on my set-up & I'm using a modular splined style sway-bar but as far as the end-link mounting tab location it's quite possible they will get altered on my PB lower arms. I will change things as needed just to keep the links as plumb as possible.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
