09-20-2021, 05:05 PM | #1 |
low n' slo
Easy way to remove motor and trans from donor?
Looking to see whats the best/easiest way to do this? my donor truck is a 2001 yukon DBW 2WD. im needing the engine, trans, wiring harness, TAC module, and gas pedal assembly.
ive started with the obvious, front hoses, intake and filter box, clutch fan, belts, A/C hoses, alternator. i know i will still need the power steering lines disconnected, and i will probably pull the top intake to give me more room. also planning on cutting the exhause right under the pipes. also, are you guys pulling engine and trans together or seperate? just trying to find the easiest route.
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
09-20-2021, 07:18 PM | #2 |
Re: Easy way to remove motor and trans from donor?
Sounds like you got a handle on it..pulling all at once is easier to me
09-21-2021, 12:04 PM | #3 |
Cut exhaust down stream of primary O2 sensors so you can re-use the down pipes with the O2 bung. Keep trans and engine together. Remove all hoses and wires but leave wire harness on engine. Pull front end of vehicle off: bumper, grille, lights, radiator, condenser, core support, engine stands, etc. Lift engine trans slight and pull straight out the front.
Usually, hood can be placed in the service position and not need to be removed. |
09-21-2021, 01:22 PM | #4 |
Don't bother trying to cut the exhaust with an acetylene torch. There's enough anti-oxidizing properties to the metal that GM used in the exhaust that's it's practically impossible to burn it away with a torch. You have to blow it away with the o2, which is slow and expensive. Instead, cut the exhaust with a grinder or a reciprocating saw.
Remove the radiator support. Remove everything you can off the engine. Most of it comes off very quickly. The front accessories, intake, and coil packs should all be gone within an hour or so. By removing this stuff, you reduce the risk of damage while pulling the engine, particularly if you pull it with a skidloader like I did.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
09-21-2021, 02:28 PM | #5 |
low n' slo
I thought the 02 sensors get deleted?
09-21-2021, 05:26 PM | #6 |
Only rear O2 sensors are typically deleted. Saws All on the exhaust. If the cats are there cut them off and use them or sell them to the recycler. Have extra blades on hand. I would remove the engine/trans wiring harness, pull the engine/trans as one and then disconnect the wiring harness from the engine compartment. Take all small parts (bolts,clips) just in case.
09-21-2021, 08:57 PM | #7 |
low n' slo
good advice. I pulled the steering pump and bracket, the intake, and fuse box tonight. getting closer
09-21-2021, 11:59 PM | #8 |
What about “where to lift from?”
I’m about exactly the same point as Kev currently. Old SBC I’d use a couple bolts in the heads. Will that be fine with aluminum heads? I’m leaving the trans connected. Thanks and hope you don’t mind the hijack
1951 GMC 250 Open Express Pickup 1968 Suburban C10 1971 C20 Olive “People are shocked when they find out I’m not a good electrician” Dad told me “Son, never strike a man in anger- unless you’re certain you can get away with it” |
09-22-2021, 01:54 AM | #9 |
i made a couple of lifting brackets similar to whats on a smallblock..that bolt to the end of each head..they hold just fine..depending on what harness you go with those factory o2 sensors may not work anyway..i know on the PSI harness they give you the #s for the ones you need
09-22-2021, 07:36 AM | #10 | |
low n' slo
fourspeed , they sell ls lifting plates that bolt under where the intake mounts. I believe you pull that plate and then bolt on the lifting plate. I will be needing that soon myself
09-22-2021, 03:58 PM | #11 |
I like to use an engine leveler on my cherry picker. 4 some what short chains attached to the front and rear of both heads. The leveler helps with adjusting the engine tilt. The four chains seems to help keep the engine more level from left to right.
09-22-2021, 04:04 PM | #12 |
low n' slo
I actually bought a leveler earlier this year for this project but then seen that valley plate lift so I ordered one
09-23-2021, 06:55 AM | #13 |
6>8 Plugless........
I really despise removing the engines out of the 4x4 ones. There is little to no room to get the bell housing bolts out. This especially sucks doing it in a pick n pull.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
09-23-2021, 07:33 AM | #14 |
low n' slo
ya I hear they are tougher lol.
I completely got my harness and pcm out yesterday...wasn't all that bad. think all I have left is to cut the exhaust, pull the driveshaft, and unbolt the motor mounts and trans mount. I pulled the radiator but nothing else up front so I'm hoping the trans will clear the core support coming out.
09-23-2021, 10:21 AM | #15 |
Most LS engines have a lifting bracket on the left rear head (intended, I believe, for a special clamp). I drilled the bracket to be able to bolt a chain to it. This worked well when I first installed the engine completely dressed. Later I learned it is much easier to bolt a leveling bar to each head with the engine naked...ie no intake manifold, coil packs, or accessories.
FWIW, the front or primary O2 sensors are necessary as they fine tune the air/fuel mixture. The rear or secondary O2 sensors have no affect on the air/fuel ratio and cannot control anything. Their only purpose is to monitor the efficiency of the catalytic converters. |
09-23-2021, 02:08 PM | #16 |
low n' slo
good thing I asked you guys, I was going to cut it right under the headers
got the front core off and have plenty of room now.
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 09-23-2021 at 06:06 PM. |
09-23-2021, 06:50 PM | #17 |
David..do you have a pic of the lifting bracket you said comes on the engine?...I've never seen one on any of the engines I've pulled
09-23-2021, 07:28 PM | #18 |
low n' slo
I wonder if it's this one?
09-23-2021, 07:39 PM | #19 |
Could be..maybe assembly line bracketry?...none of mine have that though
09-25-2021, 05:13 AM | #20 |
It's actually a guard for the fuel rail. If the vehicle is ever in a bad enough front end collision, that bracket is supposed to protect the fuel rail from being shoved into and through the firewall preventing an inside the passenger compartment fire. I've removed the ones I've LS swapped. I actually used one to make a Z bar ball stud mount on my Camaro.
09-25-2021, 01:08 PM | #21 |
09-25-2021, 01:11 PM | #22 | |
09-26-2021, 06:36 PM | #23 |
low n' slo
finally got it out. wasn't all that bad for my first time pulling the core support and radiator made it sooooooo much easier. thanks for all the help guys....can't wait to start the repairs
09-26-2021, 11:30 PM | #24 |
Good deal
09-29-2021, 11:26 AM | #25 |
low n' slo
I'm getting ready to post this donor for sale but I'm having trouble getting the tac wiring out. I have the pedal pulled and tac module but I do t see how the wiring harness comes out and what's supposed to get cut. any help?
