Old 09-12-2021, 11:47 PM   #1
drumyn61
What do stock master cylinder brake lines look like
I need to bend new 1960 chevy truck master cylinder brake lines for my truck but can't find any pictures of original.
drumyn61 is offline   Reply With Quote
Old 09-13-2021, 08:51 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: What do stock master cylinder brake lines look like
Not sure if all our years are the same but here is a pic from the Lambrect thread
Old 09-13-2021, 12:19 PM   #3
60-66
60-66's Avatar
He has a 4x4 1960 with the dual brake clutch master
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 09-22-2021, 09:22 PM   #4
JPBrecheisen
1962 GMC 4x4
1960 GMC K1500 LB Fleet Side
1962 GMC K1000 LB Step Side
1988 Chevrolet C2500
JPBrecheisen is offline   Reply With Quote
Old 09-22-2021, 10:05 PM   #5
drumyn61
Originally Posted by JPBrecheisen View Post
1962 GMC 4x4
Thank you
Old 09-22-2021, 10:45 PM   #6
JPBrecheisen
Originally Posted by drumyn61 View Post
Thank you
Welcome
Let me know if you need more angles or better lighting.
Old 09-22-2021, 10:53 PM   #7
drumyn61
Thank you
do you have a picture where the parking brake cable mounts to the chassis near the rear end?
Old 09-22-2021, 10:59 PM   #8
JPBrecheisen
I can snap a few. Cables on the 4x4s plug into the cross member behind the t-case and hooks and spings from the next cross member back hold them up and out of the way.
I can snap a few pictures tomorrow for you. My 4x4s are GMC with the spicer axles but the only difference should be how they connect to the backing plate.
This picture shows a little. I can get a dfew more.
Old 09-22-2021, 11:04 PM   #9
drumyn61
saweet, thank you.
Old 09-23-2021, 11:13 PM   #10
JPBrecheisen
saweet, thank you.
Didn't forget your pictures. Got tied up but will get some soon.
Old 09-23-2021, 11:17 PM   #11
drumyn61
Where did you buy snubbers for the rear end frame.
Old 09-24-2021, 07:23 AM   #12
JPBrecheisen
Not sure what you mean by snubbers?
Old 09-24-2021, 08:24 AM   #13
JPBrecheisen
Let me know if this shows what you're asking. Cables don't attach to frame near rear axle, they're only held up by spings and hooks.
I have several trucks like this so I believe this is factory method.
Old 09-24-2021, 10:33 AM   #14
drumyn61
Originally Posted by jpbrecheisen View Post
let me know if this shows what you're asking. Cables don't attach to frame near rear axle, they're only held up by spings and hooks.
I have several trucks like this so i believe this is factory method.
so helpful, thank you!!
Old 09-24-2021, 10:34 AM   #15
drumyn61
these
Old 09-24-2021, 11:13 AM   #16
JPBrecheisen
these
Those are original to the truck. Bumpers/stops look same front and rear. Only difference is the rears have a block of wood as a spacer. Again, most of the trucks I have are like this so I feel that its factory.
LMC Truck shows they might be available # 30-1828
GM Parts book search shows # 3700034.
Did a quick search and it looks correct.
Old 09-24-2021, 11:14 AM   #17
cwcarpenter98
cwcarpenter98's Avatar
these
Try searching bump stops. I know you can get them for 2wd, but not sure if the 4wd are different
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 09-24-2021, 04:32 PM   #18
drumyn61
60 4x4 hydraulic hoses
Looks like I need one for my clutch, does anyone know where I can buy one?
Old 09-24-2021, 07:27 PM   #19
JPBrecheisen
Re: 60 4x4 hydraulic hoses
I've gotten them from Inline Tube out of Michigan
They're not "factory looking" because they come in braided hose, but they work.
Old 09-24-2021, 07:31 PM   #20
drumyn61
You spoil me.
Old 09-24-2021, 07:39 PM   #21
JPBrecheisen
Don't mind helping. Been own the path on some of it.
If your original is intact you can send for them to copy if for some reason they don't have the application.
I had to make minor adjustments to mine when it came.
Keep them in mind for parking brake cables also. I've had them make a bunch.
Same drill. Send em yours, and they'll copy and send back. Had good luck with them.
Old 09-27-2021, 03:06 PM   #22
drumyn61
This is my balance bar but does the main cable attach to a bracket somewhere between the handle and the balance bar?
Old 09-27-2021, 03:07 PM   #23
drumyn61
does anyone know what these 2 brackets are for?
Old 09-27-2021, 11:33 PM   #24
JPBrecheisen
Yes.
Main cable bolts to the t-case cross member with a simple clamp. It runs on the drives side. Will try to get you a photo.
Old 09-27-2021, 11:36 PM   #25
JPBrecheisen
does anyone know what these 2 brakes are for?
Left behind muffler mounts.
The trianglar shaped one with the slot in the end i think is the original. Some trucks had these and ran a metal band arount the muffler body.
My `60 apache has one similar although it is 2x4 variety.
Hard to tell from the pictures but any mysterious heavy duty brackets could be remnants of a pto driven accessory. By suburban had a few that used to support a pto driveshaft for a pto driven winch. They are commonly on divers side since that is the pto side of the SM420 which i asume is what your truck has.
Last edited by JPBrecheisen; 09-27-2021 at 11:40 PM. Reason: Additional information
