10-05-2021, 08:16 PM | #1 | |
Re: 14 bolt conversion to disc questions/options
I'm on the fence about replacing the bearings, I just thought that since I was this deep in, I should maybe change them out. That puller set from Harbor Freight still requires a slide hammer, so I still have to get one of those. Geez - nothing is ever easy.
1963 C20, small window, long bed 292, 4-speed |
10-05-2021, 09:24 PM | #2 | |
If you're pulling the pumpkin anyway, it opens up another option. With the pumpkin out of the way, you could square the end of a piece of 1/2" rebar, and drive each bearing out from the opposite end of the axle. I doubt it's possible to do this with the pumpkin in place, but it might be. This diagram shows one possible method using rebar. You'll need a second person to hold the rebar in place against the bearing with a large screwdriver.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
