![]() Join Date: Sep 2012
did 64 have factory powersteering?
I have a 64 with powersteering I bought the truck for parts and I noticed it had power steering and the box physically looks like my 87 steering box but has a different bolt pattern than the newer boxes so I am assuming it is original? but not sure
![]() Join Date: Aug 2008
Re: did 64 have factory powersteering?
the 64 was a slave cylinder type no hoses go into the steering box
60-66 Nut
The '63-'66's that had factory power steering, were actually power assist steering. The pitman arm attached to a valve assembly which controlled a hydraulic cylinder attached to a bracket off of the back of the steering box, and to the draglink. This is the same setup that was used on the Corvette's for many years. I believe it was used thru the end of the production of the C3's.
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Picture of that setup on a junkyard truck.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
that's pretty neat..
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
I have some of these parts hanging off my truck but not the whole system. I don't think I am going to go to the trouble of trying to get it fixed since I want to eventually slide a 73-87 crossmember in and get power steering and disk brakes. Was this system very good?
i have it on both my 66s i love it , but they are prone to weep fuild
My 65 doesnt have a slave cyl. set up. I am pretty sure its original. It only has hoses from pump to steering box. Are you sure all 63-66 had slave cylinders?
yes the factory unit from 63-68 was a slave type unit
I've got one on my 66
Want to convert to the powersteering gear set up because my old one is leaking to much. As I can see it now I will have to use another steering link/bar because the one now is integrated with the powerslave/pitmanarm unit. Does anyone know if this is hard to do and which one I can use for the conversion? Does a 67-72 steering link/bar also fit? Does anyone know if there's a rebuild kit for the whole slave systeem? Is it Identical to the C3 corvette setup? Thanks Tony |
I used the corvette parts they are the same except ffor the hoses . The valve and pump and piston are the same
Picture of mine rebuilt, The Truck Shop carries all the parts to do.
![]() Join Date: Mar 2013
Boy this ol school setup is sweet! Mine was just the typical manual steering.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#15 |
We use to put a ( shot glass ) full of brake fluid in with the power steering fluid to swell the seals back up....!
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#16 |
Looking real good
But I'am going for the newer after market steering conversion with the 69-87 steering gear( with the 3,5 gear ratio) Do you know if I can use the same track rod or do I need a standard one (the ones used without the slave steering power adapters) If I would need another one which one will fit? Are there multiple choices to make a search easyer? Will be rebuilding the old slave powersteering just for fun and keep it so the truck stays complete. Thanks for all your reply's Keep them coming Your a big help Tony |
#17 |
60-66 Nut
You will need a draglink for a '63-'66 truck if you are going to upgrade to the integral power steering box. The '67+ draglink, I believe has a different size taper for the tierods. This might be a good time to upgrade to disc brakes at the same time. I always recommend using the '73+ steering linkage along with the disc brake upgrade. That way all the steering and suspension is of the same vintage, and easy to remember when asking for replacement parts. plus then you don't need those $$ aftermarket aluminum tierod adapters.
#18 |
Thanks Captainfab
That's worth considering I will let you know which way we went Does a 73+ fit the A arms of a 63-66 truck? So I can go for a salvage yard conversion or do I have to get aftermarket parts to make it a whole set? Thanks again Tony |
#19 |
60-66 Nut
No, the '73+ tierods will not fit the '63-'66 spindles. Yes you can do a complete disc brake swap using '73-'87 C10 components, whether from a wrecking yard or a donor truck from an individual. You do not have to use aftermarket parts for a disc brake conversion. There are a few threads all about this in the '60-'6 FAQ Index found at the top of the page.
#20 |
Thanks again for all the info
I'll put it to a hold because the disc brake conversion also sounds good to me Then I don't have to search for a 63-66 track rod for my powersteering conversion. And maybe I can sell the factory powersteering kit as a Whole to someone how wants to stay original Thanks |
#21 | |
Came with the truck like this when I bought it. Previous owner has since passed so no luck there. -Mark |
#22 | |
Moderator
![]() ![]() Join Date: Aug 2011
#23 | |
-Mark |
