Old 10-18-2021, 07:48 PM   #1
Lugnutz65
Lugnutz65's Avatar
Road draft tube conversion.
I’ve read lots of stuff about converting an engine draft tube to PCV. Some folks put a freeze plug in the big hole where the tomato can baffle goes and just use modern rocker covers with a breather and PCV system. Of course that works just fine and is an option that makes sense.
For me, I wanted to use the original 283 Chevy script valve covers which don’t have a hole for a PCV or oil fill. The 283 oil fill tube up front has a breather cap already.
Vendors sell a road draft tube adapter. It wouldn’t be hard to fabricate a piece that would work just as well as what the vendors sell. Basically it’s a domed cap for the draft tube hole with a nipple on the side. Then you run a 1/2” vacuum hose to a PCV that connects to the carb base with a 45* or 90* fitting. That supplies sips of manifold vacuum to the road draft setup. I hope you like the pics.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 10-18-2021, 08:46 PM   #2
geezer#99
geezer#99's Avatar
Re: Road draft tube CONVERSION!
Nice pics but that’s nothing new.
Chevy 327 had that as a factory set up before they went to the open valve covers.
Old 10-18-2021, 08:51 PM   #3
Lugnutz65
Lugnutz65's Avatar
Not trying to say it’s a NEW idea. I took the pics to show people who don’t already know about this. I just have not seen it laid out with pics with details. I have my engine on a run stand where taking pics was easy.
Old 10-20-2021, 12:09 PM   #4
dagnabbitt
dagnabbitt's Avatar
Great looking engine.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-30-2021, 10:22 AM   #5
kaycee
kaycee's Avatar
Buitiful engine and great pictures, I kinda did the same thing on both my 327
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 11-03-2021, 04:47 PM   #6
mattfranklin
mattfranklin's Avatar
I appreciate the very clear way you documented it.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is online now   Reply With Quote
Old 11-08-2021, 11:47 PM   #7
Accelo
Accelo's Avatar
Look at the 1963 models, it is close to the system you have shown.
The adapter at the rear of the block looks like a reproduction of the one used on 63 models. Some of the Corvette's had a hose that comes off the oil fill tube and goes to the air-cleaner. If you use that system you don't need the breather on the fill tube. It can be caped like the Corvette. The fill tube is available in black or chrome from Corvette dealers. You could use either system. Just depends on the air-cleaner you prefer to run.
Accelo is offline   Reply With Quote
