Mice proofing engine bay ideas
My blazer has to sit under the carport this year and already found some mouse poo. The only thing I could find is to use peppermint or cedar. Any other ideas. I don,t want to use mice traps and attract them and I don,t think you could trap all the mice outside. I also don,t have wheel tubs up front
Re: Mice proofing engine bay ideas
Mothballs work.
I use the mint repellant. Works well even in the barn
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
![]() Join Date: Mar 2014
Those little bastards like dark places and love to eat wire insulation. Leaving the hood popped can help keep they from nesting in your engine bay. Adding some LED lights can help but make sure they don't produce much heat because thel like heat too.
Made in America by Americans |
R.I.P. E.S.L.L.
![]() ![]() Join Date: Aug 2005
Get a mean cat.
1971 Custom C/20 ![]() 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
I have been using a multi layered approach for a few years after noticing evidence of rodents. Peppermint oil all around the perimeter of the storage area. Inside and out. A few bars of Irish spring soap scattered under the vehicle. Mouse poison bait blocks around all perimeter walls. Dryer sheets in the engine bay and any other area they might go, peppermint oil laced rags also. Steel wool in the exhaust pipes.
I have moving blankets that I lay on when working on the ground. I have found evidence they were nesting in some of those blankets. Better there than the vehicle?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
I prefer hungry cats.
My dad had problems with Mice eating wiring, and other things in his hobby car. I got him to feed the local feral cats, and they quickly disappeared. He gave the cats a area to shelter in to keep them close at hand. Going on 5 years now with no issues from mice, and no needing to spray. |
![]() Join Date: Oct 2016
Well if you can lure them into the air cleaner and then start it up, that fixes one problem.
It took me way too long to figure out why the old girl wouldn't start. I found a good chunk of his nest down in the carb. No sign of the little guy since. I guess it could be worse. I was starting it to get it into my garage to begin the engine swap. I have no idea how he even got in there as it's sealed up tight and the element doesn't have any holes chewed through. I put a few traps in the cab of the truck and a couple in the engine compartment. I'm pretty sure he's lodged in the intake valve of one of the cylinders though. |
#9 | |
R.I.P. E.S.L.L.
I'm not really a cat person. But I liked that cat. He was tough. That cat wouldn't go near me for about 5 years then one day he just walked up to me and meowed. I couldn't believe it. After that he was my buddy. It only took 5 years.
Thanks , how often do you change moth balls ?
I might be opening myself up to a shot of my own humor here, but I remember one member recommending rubber snakes. He put them around the truck on the ground, kind of parked in the middle of them and the rats would leave his truck alone. I thought about getting a couple to put on top of the radiator. Can rats and mice see in the dark?
I've been leaving the hood popped to make the underhood environment less protected. It's kind of hit and miss on my vehicles - sometimes they'll nest in there anyway - and unfortunately leaves your battery and underhood components at risk. |
I've had good luck with placing Bounce dryer sheets around, but need to swap them out every few months.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
#15 |
Robert Olson Transport
![]() Join Date: Oct 2002
i throw bags of moth balls around and something called cab fresh available at tractor supply never see mice
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
#16 |
![]() Join Date: Nov 2018
I do not endorse, personally use or have any affiliation with this product but they advertise it to work. You be the judge!
https://www.amazon.com/Mouse-Blocker...01856881&psc=1 |
#17 |
![]() Join Date: Dec 2009
#18 | |
Who Me?
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#19 | |
![]() Join Date: Feb 2000
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#20 | |
It's actually a pleasant smell in the cars and trucks . Dryer sheets make me puke . My dad used them and it's like getting into a car with someone who puts on way to much perfume or cologne .
#21 | |
#22 |
![]() Join Date: Dec 2015
My Honda was attacked, again. There is a fuzzy sound deadening mat under the hood they like, should rip it out. I have a few moth balls stuck around the engine bay. So far so good, but not digging the smell.
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet |
#23 | |
They will find something else. I bought one of the bucket top traps in the link below. It works great. Link: https://www.rinnetraps.com/product-p...ket-compatible They are Made In The USA. There are cheaper versions of these, Reviews say that they are poorly made, and won't fit the top of the bucket Etc Etc.
