Old 10-27-2021, 06:23 PM   #1
chadzilla500
67 C10 want to do coil over conversion.. bye bye air bags
anyone here in the suspension community have any ideas for me?
looking for 1" narrower arms with a coilover kit..removing air bags and dont have any room due to the wheel offset.
Thanks!!
chadzilla500 is offline   Reply With Quote
Old 10-27-2021, 09:24 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: 67 C10 want to do coil over conversion.. bye bye air bags
You should only have 1 thread going at a time. It can get confusing.
http://67-72chevytrucks.com/vboard/s...d.php?t=827288
http://67-72chevytrucks.com/vboard/s...d.php?t=827289
Old 10-29-2021, 12:11 PM   #3
chadzilla500
Thanks!!
Old 10-29-2021, 02:28 PM   #4
tinydb84
tinydb84's Avatar
Thanks!!
Ridetech makes a coilover kit. I dont believe they offer a narrowed option though. You can go with the CCP modular spindles to get .5'' though.
The other option would be to go with any of the aftermarket full crossmember setups. Most will narrow the track width 1.5'' on each side. Modern steering, lighter, etc. Only issue is the cost.
David
Instagram: myfabguy
Old 10-29-2021, 05:15 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Thanks!!
Porterbuilt makes them, but you need their crossmember to keep the low ride height.
This will also center the front wheels in the wheel opening, which it looks like you need.
Look at this thread.
http://67-72chevytrucks.com/vboard/s...+blue&page=100
This is the lowest Porterbuilt ride height with coil overs.
Keith
Convert to disc brakes.
Old 10-31-2021, 09:01 AM   #6
darkhorse970
darkhorse970's Avatar
I can tell you from first hand experience that GringoLoco’s truck rides and handles better than any stock frame static dropped truck that I’ve ever ridden in.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
