10-26-2021, 06:01 AM | #876 |
Re: Ok Boys and Girls it's Storytime
Thanks LT I'm glad you enjoyed it. This kind of racing is very competitive and can be a challenge for sure. My engine is a little on the extreme side for the class but there are plenty of 1000hp and up powered cars out there too. Although most of them are closer to the 2800lb minimum and I'm at 3550lbs. One of the cool things is I have friends all over the country that I only see at the races.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
10-26-2021, 06:12 AM | #877 |
Key off.
Key on.
10-30-2021, 09:07 PM | #878 |
I ripped the cluster back out today. I fixed the speedometer to zero. I also got the the fuel gauge to read closer to my wallet. Just above empty. Lol
10-31-2021, 01:01 AM | #879 |
Heck..I thought the 454 speedo was cool..!!
10-31-2021, 07:52 AM | #880 |
The odometer still is on 454. My speedo was stuck on 30mph. I fixed that and managed to get the fuel needle in a more realistic position. Just above empty, kinda like my pockets.
10-31-2021, 08:05 AM | #881 |
11-02-2021, 11:10 AM | #882 |
oh ...i got ya now..
11-02-2021, 07:54 PM | #883 |
I knew that you weren't no Dummy. On the other hand. I hope that your parents are doing ok. i'm looking forward to updates on the Inny.
11-02-2021, 11:53 PM | #884 |
Thanks Regan... Dads been in and out of the hospital the last few weeks..hes doing good now..
Appendicitis got him..and a few other health issues..but they're doing good I did a small update on the "inny" thread..
11-03-2021, 05:59 PM | #885 |
I thought I had a big problem with my new Alternator setup. It just pans out as ignorance on my part. I got a special pulley that uses an HTD belt just like my Dry Sump Pump. I thought it wasn't going to work. After talking to the guys at Jones Racing where it came from. I thought I was going to have to convert to a different alternator. Nope! I go by the Alternator shop this morning. Tada he plucks out the spacer and my pulley fits lol.
11-03-2021, 06:04 PM | #886 |
This is my new drive setup. It's a 49 tooth on the crank and 22 on the alternator.
11-03-2021, 06:09 PM | #887 |
It's so cute. Lol Hell I'm glad it will work. I ordered two custom length belts today.
11-03-2021, 08:48 PM | #888 |
That's some serious drive power for the alternator.....!!
11-03-2021, 09:04 PM | #889 |
The reason behind the overkill is the instant load coming off the trans brake.
11-03-2021, 09:08 PM | #890 |
I was also turning the alternator too fast with the V belt deal. I couldn’t get a replacement v pulley for my splined drive. So I was kinda forced to adapt.
11-10-2021, 09:27 AM | #891 |
What do you do when you're bored? Find something to entertain you. I repurposed a header tube from Blue and made a custom exhaust extension for Whitey. This tube had over 160hp running through it. I think it will handle the little 350. Lol
11-10-2021, 10:16 AM | #892 |
The 'feel good' moment that makes you chuckle....
11-13-2021, 09:26 PM | #893 |
Well I took apart this erector set of bars today. Then carried my rearend to my friend Tony. Back in go the 4.56's.
11-13-2021, 09:27 PM | #894 |
On a side note. Even if you don't have an ATV or a Motorcycle that little jack is pretty handy.
11-13-2021, 09:41 PM | #895 |
So much easier to just remove a center section, just saying, only thing Ford got right LOL.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
11-13-2021, 10:11 PM | #896 |
Yes Sir you are correct for sure.
11-19-2021, 06:29 PM | #897 |
I went with a Frankland quick change rear end. With my 4:11 ring gear in it I have 128 gear ratios to chose from that I can change in 15 minutes. I think they run from 2.11 to about 8.50 or so. It also looks cool. So there's that. Thank you for your time.
11-19-2021, 06:39 PM | #898 |
You think a Franklin QC would stand up to the torque load that un-light body, BBC, & those tires slap it with?
11-19-2021, 08:13 PM | #899 |
It's a QC-80 case from a guy I pitted for when I was young. I took it to the Frankland factory in Pennsylvania and had them build it for 1000 hp. Moser axles. I'm running a Bicknel torque arm with the triple biscuit to take up some of the shock. I had it made to fit my 53 3100 and my 12.88" Wilwood brakes. It's going behind the 1000 hp blown 292 I'm building. we will see which one blows up first.
11-19-2021, 08:20 PM | #900 | |
