Old 11-13-2021, 02:03 AM   #1
steveimpala
Active Member
Patch panel
I pulled up the carpet on the '69 C20 and I found some rust that will need to be cut out and patched up. Seems to be a common location right below the high-low dimmer switch. What size gauge metal would you recommend for this location ?
Thanks !
steveimpala is offline   Reply With Quote
Old 11-13-2021, 12:50 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Patch panel
Thanks !
I don't know a lot about sheet metal but that spot isn't too big so I would say 18 or 20 ga. should do it.
LockDoc
Leon
Old 11-13-2021, 01:10 PM   #3
72c20customcamper
72c20customcamper's Avatar
Re: Patch panel
Thanks !
It is relatively small as it sits but once you start cutting it will be much larger. I'll bet once you start cutting it will be well up into the firewall floor pan pinch weld . Mine was just a bit till I started working it . I made all the pieces by hand with 16 guage sheet metal . I wouldn't go higher than 18
See your in Wappingers falls I have a house in the Riverview area off of Channingville rd .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 11-13-2021, 08:41 PM   #4
57taskforce
All about them K’s
57taskforce's Avatar
Re: Patch panel
That’s pretty nice work Mark. I did the same repairs on both sides to my K20 along the lower firewall pinch weld and all four floor supports, and inner/outer rockers. It’s a pain in the ass but not hard to do. I used actual patch panels though.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 11-13-2021, 08:49 PM   #5
steveimpala
Active Member
Re: Patch panel
yes, been here since 1995..... born down in Cold Spring NY
